How integrate the mains and the sub? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss How integrate the mains and the sub? in the Subwoofer Equalization | Calibration forum; How integrate the mains and the sub? Hello, here a newbe question. The question is how the mains are configured, SMALL or LARGE? I think that you ...
Old 07-19-06, 08:16 PM   #1 (Link)
New Member
Alias: Fer
Loc: I ain't tellin ya!
User: #952
Since: Jun 2006
Phobitos is offline
I think that you put SMALL to the mains with the crossover the same for the sub in order to achieve an integration low dependent of the sub volume?
If the mains are very low frequency capable, it should be better to put mains LARGE in order to reinforce the stereo imaging, the stereo scene?
Also, if the mains are LARGE, a full (mains + sub) smooth frequency response have associated a non smooth response for the sub curve, mainly in the frequencies below sub crossover where the mains have an appreciable presence?
Which is the best option for a combined music-stereo and home-cinema system?
I´m sorry my bad english.
Thank you very to all of you. This forum and the subject it contains are a wonderful gem.
Old 07-19-06, 10:08 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: How integrate the mains and the sub?
Well, with capable mains you might go as low as 60Hz, but they will still always be configured as small. You'll obtain much better integration this way. If the mains and sub are both producing the same frequencies, there is a greater chance of cancellation. There's not much imaging happening below 60Hz. Sound below that frequency is not localizable.
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
