REW Forum
Distortion readings for 2nd and 3rd HD??
Discuss Distortion readings for 2nd and 3rd HD?? in the Equalization | Calibration forum; Distortion readings for 2nd and 3rd HD?? i'm using a behringer ecm8000 and i'm wondering if the distortion readings for 2nd and 3rd harmonic are accurate. It ...
Views: 581 - Replies: 1
Old 07-14-06, 12:59 PM   #1
Alias: martin
kramskoi's Avatar
Loc: Louisiana
User: #1511
  kramskoi is offline
i'm using a behringer ecm8000 and i'm wondering if the distortion readings for 2nd and 3rd harmonic are accurate. It seems to start out at an extremely high percentage...then it drops with increasing signal level then starts to rise again as output level reaches maximum. Is this right?
Anyone with experience in this area is welcome to respond...thanks
Old 07-14-06, 01:47 PM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
Re: Distortion readings for 2nd and 3rd HD??
Can be the case, depending on what your setup is and what you are measuring. At very low signal levels noise contaminates the measurement, as the signal rises clear of the noise a truer picture of the harmonic levels emerges, as you start to approach saturation/clipping levels distortion components rise again (especially 3rd where clipping is involved). Bear in mind that approaching limits anywhere along the chain will cause distortion - i.e. the subwoofer input stage, the subwoofer amp, the subwoofer driver, the microphone, the mic preamp and the soundcard input. Can even introduce distortion with the test signal if its level is higher than the driven input can accommodate (unlikely with most sound cards though).
