| REW Forum Any test case available ?Discuss Any test case available ? in the Subwoofer Equalization | Calibration forum; Any test case available ? I just downloaded the software and I am going to install it and try a few things as soon as ... |
| | #1 (Link) | |||
| Any test case available ? I just downloaded the software and I am going to install it and try a few things as soon as I send this email. My purpose for downloading the software is to use it in my home theater to have sound within the room to be very similar in all locations (That would be the ideal solution but probably unattainable). Can anybody point me to some test case(s) where someone has documented this process ? There must be a set a measurement that needs to be done before starting on the treatment of the room. Freq response, waterfall, etc... Thxs | |||
| | #2 (Link) | ||||
| Re: Any test case available ? Quote:
Normally you would attempt to get as smooth as possible a response and decay at your listening position using treatment and some equalization. Even averaging for multiple listening positions requires sacrifice to a single sweet spot. brucek | ||||
| | #3 (Link) | ||||
It shouldn’t be hard to get the sound similar to all seating in the room, as long as your speakers have adequate dispersion. Bass response uniform to each location – that’s another story. That will largely depend on your room, where the seating is in the room, etc. For instance my room is a large, open family room with the seating some distance from any boundaries. It’s been my experience in a room like this that it’s not hard to get the bass to sound uniform, even if it doesn’t measure quite the same at all seated locations. At the other end of the spectrum, if you have an enclosed room with shoebox dimensions, it can be very problematic getting the bass to sound the same at all locations, especially if there are seats near boundaries. Even if you equalize for average response, the situation often is one of different levels of bass at the dead center of the room vs. closer to boundaries. Still, some people have overcome this with the use of multiple subwoofers in the room (our “head honcho” Sonnie is one such case, I believe). The news isn’t all bad, though. Fortunately, bass in movies mostly is nothing but “boom,” so even if you do set things up to sound best at a single sweet spot, the bass often will nonetheless be perfectly acceptable at the other locations. As far as treating the room, treatment for the upper frequencies is different than that for the lower frequencies. The means of measuring improvements is different, too. As I understand it, improvements in upper frequency treatments are measured with RT-60, and waterfalls are most useful for lower frequencies. (You might check in at our Acoustics Forum for clarification and qualification on this – I know just enough about acoustics to be dangerous. ) If you’re going to apply treatments, some “before” measurements would be helpful, not only to see if you actually do need treatments, but also to register the improvements when you do. REW can generate low-frequency waterfalls from a frequency response measurement, and I think I’ve heard that the latest version can also do RT-60 as well.Good luck, and keep us posted. Regards, Wayne | ||||
| | #4 (Link) | |||
| Re: Any test case available ? Generally you will need to treat all the front wall (for HT experience) with 1" (at least) thick insulation material specially if you have a big screen in a faux wall. REW is an excellent program to tell you how far (or close) you are from good sound. Learn how to use it, use it then come with a problem that we can discuss. It is possible (easier) to have near identical sound in a row of seats using at least 2 identical subs (depending on your room...), but not even thinkable to have same sound qualities everywhere in the room, and anyway, you don't need that. ![]() Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Looking for a rack-mountable CPU case | thekl0wn | Computers | Games | HTPC | Digital Devices | 6 | 10-27-07 10:52 AM |
| test tust test | DrPainMD | Testing | 4 | 03-30-07 09:03 AM |
| HTPC Case $110 | toecheese | Computers | Games | HTPC | Digital Devices | 8 | 08-07-06 02:55 PM |
| DWJ's HT, or The Case For Divorcing DWJ | DWJ | Home Theater Equipment | 0 | 07-20-06 03:57 PM |
