why does my microphone calibration file look like this - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss why does my microphone calibration file look like this in the Subwoofer Equalization | Calibration forum; why does my microphone calibration file look like this Picture 1.jpg it seems to get noisier at the higher frequencies equipment macbook rew (latest version) mic behringer ecm 8000 ...
Old 04-05-08, 08:34 AM   #1 (Link)
New Member
Alias: stef
Loc: worcester, ma
User: #7856
Since: Mar 2007
bwana is offline
equipment
macbook
preamp maudio fast track pro
i also tried to make adjustments in the
Applications>Utilities>Audio Midi Setup application but there are restrictions.
Even when i set all the drop down menus for the fast track pro (input,output,properties),
I cannot configure the Audio Input or output sections much.
I can set source and format for audio input and only format for audio output.
I cannot set levels. Is this because thesignal is digital from the laptop
and the actual analog parameters are set in the maudio box?
Old 04-05-08, 09:39 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: why does my microphone calibration file look like this
The microphone calibration file is simply a file of values loaded in REW to compensate for mic inaccuracies. There's no measuring involved.
The ECM8000 mic has a calibration file we provide on the download page.
Can you explain what you're doing - I'm confused?
Old 04-05-08, 10:30 AM   #3 (Link)
New Member
Alias: stef
Loc: worcester, ma
User: #7856
Since: Mar 2007
bwana is offline
i am following the 'getting started' instructions for REW.
First get a loopback cable. In my case it goes from the RCA output on the back of the maudio fast track pro to a TS jack that fits into the combo jack on the front of the maudio fast track pro.
Then i go to settings and start with the sound card calibration. The first step is setting the level. I do this by adjusting the knob on the front of the maudio box so that the measured level matches the output level in the little vu meter bars.
Then i hit calibrate and the thing gives me a curve which sort of looks like the thing i posted but rolls off at the high (>20khz). What bothers me is how the 'noise' (jiggliness?) increases during the frequency sweep.
Old 04-05-08, 11:12 AM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
So this is a soundcard calibration you're having trouble with and not a microphone calibration as your thread title indicates?
If that's a soundcard calibration response chart you've posted, I would say you're not getting any signal over the loop.
Are you selecting the correct channel in REW as you are using for the loopback cable - right channel ?
Old 04-05-08, 11:25 AM   #5 (Link)
New Member
Alias: stef
Loc: worcester, ma
User: #7856
Since: Mar 2007
bwana is offline
sorry, yes, this is a soundcard calibration.
yes, the loopback cable is properly inserted. when i intentionally select the wrong channel, the db is much lower, i cannot match it to the output signal on the vu meter that pops up, and the program warns me that the level is too low if i try to calibrate. have you ever seen such a problem before?
Old 04-05-08, 12:10 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
Did you select the RCA output that your cable is plugged into on the back of the unit (1/2) or (3/4)?
I see the switch that toggles between line and mic. Did you set it for line?
Instrument/Line Selector Button (Inst/Line) – This button selects the input level of the front panel 1⁄4” inputs. In the out position,
the inputs are set to accept an instrument level signal (such as that from a guitar or bass) while in the in position they are set to
accept a line level input (such as that from a keyboard or drum machine). Please note that the XLR input level is unaffected by
this switch.
Old 04-05-08, 12:17 PM   #7 (Link)
New Member
Alias: stef
Loc: worcester, ma
User: #7856
Since: Mar 2007
bwana is offline
i repeated the same process on a windows machine (in fact it ws the same macbook booted into windows) and without changing anything on the fasttrack pro-here is the result
this is the expected graph. obviously the mac os (leopard) is not handling things properly.
and btw, flipping that little switch does not change the result-same curve is obtained.
Old 04-05-08, 12:21 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
That's what it is supposed to look like. Save it..............
Similar Threads
should i calibrate the ecm8000 or use the calibration file jeremy7 SPL Meters | Mic's | Calibration | Sound Cards 3 02-08-08 07:11 AM
Professional Microphone and SPL Calibration Sonnie SPL Meters | Mic's | Calibration | Sound Cards 0 02-04-08 08:58 PM
C-weighting and calibration file questions stokasz REW Forum 2 01-29-08 04:28 PM
Calibration file AND c-weighted box? cnjvh REW Forum 2 01-31-07 10:26 PM
TES model 1350A calibration file wanted goldeneye243 SPL Meters | Mic's | Calibration | Sound Cards 0 10-01-06 03:48 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
