20 to 40 hz responses - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss 20 to 40 hz responses in the Subwoofer Equalization | Calibration forum; 20 to 40 hz responses I notice in this thread http://www.hometheatershack.com/foru...unt-ahead.html that in most of his plots the low freq. curves remain the same. I ...
Old 02-27-08, 08:12 PM   #1 (Link)
jpv
New Member
Alias: vman
Loc: Terre Haute Indiana
User: #15731
Since: Jan 2008
jpv is offline
I notice in this thread http://www.hometheatershack.com/foru...unt-ahead.html that in most of his plots the low freq. curves remain the same. I have noticed this in my measurements also. As long as I stay within a certain area the response curve remains the same, higher frequencies will show variation. My question is why are these frequencies not affected by placement on my subs or seating position?
Old 02-27-08, 08:53 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: 20 to 40 hz responses
It's certainly not normally the case. Moving a sub or the listening position can affect any frequency.......
Old 02-27-08, 11:44 PM   #3 (Link)
Alias: Mike Bentz
Loc: Chicago
DrWho's Avatar
User: #2782
Since: Sep 2006
DrWho is offline
Lower frequencies have longer wavelengths, which will naturally disperse the peaks and nulls of the modal response over wider regions in the room.
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 02-28-08, 09:35 AM   #4 (Link)
jpv
New Member
Alias: vman
User: #15731
Since: Jan 2008
jpv is offline
Then the hump I have in my room at those freqencies can only be tamed by an EQ. Bass traps are not effective that low. Is this a result of the room or the speakers, I have two M&K subs. These frequencies fall below my room modes, The size of my room is 18.5 x 13.5 x 10.
Could I not be measuring it correctly?
Old 02-28-08, 09:49 AM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
I suspect it's the room. You could take a near-field measure of your subs. Try and remove as much influence from the room as possible when taking the measure. Perhaps drag one sub to the center of the room away from boundaries, or better yet, take it outside....
Mach 5 Audio
