| REW Forum Filtering, Audyssey and what have youDiscuss Filtering, Audyssey and what have you in the Subwoofer Equalization | Calibration forum; Filtering, Audyssey and what have you I got my first filter applied and the resulting measurement isn't too bad (first attachment). But then I connect the ... |
| | #1 (Link) | |||
| Filtering, Audyssey and what have you I got my first filter applied and the resulting measurement isn't too bad (first attachment). But then I connect the mains and whoops!, a nasty dip at 82Hz (second attachment). I should mention that, at this point, Audyssey is turned off and tone controls are disabled. I have manually set all my speakers to small and the x-over at 80Hz. Since my dip is at 82, I tried various x-over points on either side of 80Hz and settled on 100Hz (for now). The final graph is Audyssey flat, 100Hz x-over and all speaks set to small. Now, this Audyssey curve was derived from before I EQ'd my sub. I obviously need to re-do my Audyssey and I will (hopefully, it'll fix that nasty dip at 151Hz), but before I do, I want to run something by you all. In the past, Audyssey tended to knock my sub levels down. I'm hopeing this had to do with the peaks from the room resonances and will be less of an issue now. But I'm wondering if I should "game" Audyssey a bit? That is, apply a filter without the house curve, run Audyssey and then apply the filter with the house curve. My thought is that Audyssey will see the level of the sub without the house curve, set it's levels and then I come back with a bump in the bass. Thoughts? Thank you, Michael | |||
| | #2 (Link) | ||||
| Re: Filtering, Audyssey and what have you Quote:
I'm never thrilled about a 100Hz cross. I think it localizes the sub too much. In addition to phase adjustments to correct the dips around a crossover cause by interaction between the sub and mains, you can also alter time delay on the sub using your receiver trim for distance. This can be quite successful. brucek | ||||
| | #3 (Link) | |||
| Re: Filtering, Audyssey and what have you I'm not too thrilled about it either, but I'm even less thrilled about a ~20db notch at 150; as narrow as it might be. My sub only has a phase "toggle", being (I assume) 0 and 180. I'll try reversing phase as well as moving the sub around a bit. I also need to see what Audyssey will do with the EQ'd sub. I don't want to jump to conclusions using a curve set before I EQ'd the sub. What I also need to do is some listening, since that's what this is all about. I'll post the results of my experiments as they become available. Thank you, Michael | |||
| Thread Tools | |
Similar Threads | ||||
| Thinking about Audyssey -- experiences? | Anthony | Home Theater Components | 1 | 03-13-08 01:37 PM |
| What are you using for subsonic filtering? | Ricci | DIY Subwoofers | 3 | 01-31-08 09:04 AM |
| Audyssey | Donald | Home Theater Components | 12 | 01-26-08 09:14 PM |
| YPAO vs MCACC vs Audyssey vs... | aceinc | Home Theater Components | 18 | 01-26-08 04:40 PM |
| Comb Filtering Confusion | Dain Bramaged | Home Audio Speakers | 31 | 05-20-07 03:01 AM |
