| REW Forum EqualizingTwo SubsDiscuss EqualizingTwo Subs in the Subwoofer Equalization | Calibration forum; EqualizingTwo Subs I answer to myself. I realized that no need to ask when I can test that myself. (it's so easy ... |
| | #26 (Link) | |||
| Re: EqualizingTwo Subs I answer to myself. I realized that no need to ask when I can test that myself. (it's so easy to ask and not do it ).So what I noticed is that inside the area of frequencies covered with calibration file, the C-tick has no effect. It takes effect outside of those frequencies. I edited RS cal file and added topmost line 0.00 -27.00 <------- this one 7.00 -27.00 8.00 -22.55 9.00 -19.37 .... That removes the C-weight box effect completely with low frequencies. Now ticking C box has effect only on frequencies above 3kHz and those should not be measured with RS SPL anyway. I think this one line addition (0 hz value) should be added to "official" RS cal file. ps. Thanks for everyone doing this REW software. It's wonderful tool. ![]() | |||
| | #27 (Link) | ||||
| Re: EqualizingTwo Subs Quote:
As I said, it will be obviated by the new version of REW which will be released soon. brucek | ||||
| | #28 (Link) | |||
| Re: EqualizingTwo Subs WHEN??? ![]() Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #30 (Link) | |||
| Re: EqualizingTwo Subs I'm Back !! ![]() Got caught up with work .But I have done a bit of reading of the REW stickies. I've also had to make some new patch cables for my BFD. I've re-read this thread, but I'm not too sure about something. I can't really co-locate my subs unless I stack them about 39% along the left hand side wall of my "shoebox" HT room (and re-wire my room). Unless someone thinks this position is a good idea, I will keep the rear one against the rear wall, and the front one somewhere in front of the front seats. (If I stack the two subs in front of the front seats, they will get in the way of the sound coming from the front mains.) BUT, I can possibly fit them in the two front corners, as suggested by Wayne. My combined un-EQed subs look quite good on the SPL graph (see previous post). The individual SPL graphs are quite different to each other, but when played together, the two subs obviously cancel out much of their individual problems. My question is, should I EQ each sub individually, then EQ them together. Or should I EQ the combined SPL readings, applying identical filters to each sub, regardless of their individual graphs. I will be designing a hard knee house curve for my EQing based on Wayne's article. I will be fine tuning the location of the front sub before I add filters. After EQing, I will check the integration of the subs with the mains, and adjust if necessary. Does all this sound logical? | |||
| | #31 (Link) | |||||
![]() brucek | |||||
| | #32 (Link) | ||||
![]() Now the only challenge is how to say “logarithmic interpolation” without getting tongue-tied... ![]() Regards, Wayne | ||||
| | #33 (Link) | |||
| Re: EqualizingTwo Subs Thanks Guys ![]() I'm going to have a go this weekend. BTW, I developed a hard knee house curve (for practice) by printing the default curve. On the print I drew the straight line I wanted. As the vertical scale is linear, I just measured the vertical gap between the curve and my straight line, adjusting the measurement to dB using, say 10dB on the axis as a reference. I had to add more lines to the frequency scale between 30 and 50 Hz. That's a bit more difficult, but not impossible. My resultant txt file gave me a near perfect straight line first up. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| How many subs is too many? | Tiny | DIY Subwoofers | 18 | 10-27-07 10:22 PM |
| two subs | bobgenie | BFD Forum | 15 | 10-22-07 03:07 PM |
| First real measurement subs, subs+main, subs+main large | frockc | REW Forum | 13 | 03-17-07 11:42 AM |
| Best Way to EQ 2 Subs? | Tukkis | Home Audio Subwoofers | 13 | 07-25-06 10:51 PM |
| One or Two Subs | Tommy | Home Audio Subwoofers | 42 | 06-01-06 11:06 AM |
