REW V4.10 and V4.11 Release - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss REW V4.10 and V4.11 Release in the Subwoofer Equalization | Calibration forum; REW V4.10 and V4.11 Release Nordo wrote: Do you install 4.10 over the top of 4.0, or do you have to uninstall 4.0 first? Just ...
Old 03-10-08, 04:25 AM   #26 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: REW V4.10 release
Nordo wrote: View Post
Just install over the top.
Old 03-10-08, 12:14 PM   #27 (Link)
Alias: Bernard
User: #36
Glyptoron is offline
Merci beaucoup, John !
Thank you very much, John !
Old 03-10-08, 12:24 PM   #28 (Link)
Alias: hasse_swe
Loc: Sweden
User: #15149
Since: Jan 2008
hasse_swe is offline
JohnM wrote: View Post
You don't need to do anything to get it to work, waterfalls cover the full range over which the measurement was made, e.g. do a sweep to 20kHz and the waterfall you generate will extend to 20kHz. Were you measuring a main speaker or just the sub? If it was a sub the response would be off the bottom of the plot, could see it by moving the axes.
hi!
got it working now!
(error was on my side.....had the freq axis in wrong mode... )
thanks!...exellent program update btw!..
Old 03-10-08, 12:53 PM   #29 (Link)
Alias: Bob_99
Loc: New Hampshire
Bob_99's Avatar
User: #460
Bob_99 is offline
JohnM
I just want to add my voice to the others to thank you for the work that you have put into this excellent program. It is very much appreciated.
Thank you.
Bob
"There is always hope, even if it is just a fool's hope."
Old 03-10-08, 01:02 PM   #30 (Link)
Alias: Shervin
Loc: Florida
ssabripo's Avatar
User: #3688
Since: Nov 2006
ssabripo is offline
This is great.
but man, I was hoping JonM or someone would have added the connectivity to the DEQ2496! still hoping and waiting.
Old 03-10-08, 02:21 PM   #31 (Link)
Alias: Kevin
Loc: Dublin, OH
User: #8492
Since: Apr 2007
Kevin_Wadsworth is offline
I used REW 4-5 years ago for the first time and thought it was an amazing program. All the extra additions since then are impressive.
Thanks a lot!
Old 03-10-08, 08:39 PM   #32 (Link)
Alias: Bob
Loc: Lytham-St-Annes, UK
Malice's Avatar
User: #304
Malice is offline
JohnM, is it possible to do a "manual" install without the need to run windows setup? There is a possibility that although Java may be installed on a work laptop, privileges to install any programs are revoked. It would be neat if one could just "unzip" from the set up EXE, but much depends on what else that gets written to the registry other than uninstall info.
Great work BTW!
Bob
| Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant|
Bob - "Malice" was my Quake 2 CTF name
Old 03-11-08, 04:19 AM   #33 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Malice wrote: View Post
You can download the zipped jar files, unzip them to a convenient location and run REW by double-clicking the roomeqwizard_obf.jar file. Java stores application preferences in a registry key as described in the help files, no other registry usage.
Old 03-11-08, 08:02 AM   #34 (Link)
Alias: Mike
Loc: Michigan
User: #5271
Since: Jan 2007
mstailey is offline
I have moved this post to http://www.hometheatershack.com/foru...tem-delay.html
JohnM
Old 03-11-08, 09:08 AM   #35 (Link)
Alias: brucek
User: #6
brucek is offline
I'm sure in both cases it's something I'm doing wrong either by operation or setup?
mstailey, perhaps best to start a new thread about your problem.
Old 03-11-08, 10:28 AM   #36 (Link)
Loc: Lower Alabama
YES! PLEASE! Let's keep this thread restricted to comments related to the new release and issues relating to the download files themselves.
Please start a new thread for general REW issues. THANKS!
Old 03-11-08, 01:53 PM   #37 (Link)
Alias: Rafael
Loc: Orlando
User: #17740
Since: Mar 2008
rafaelsmith is offline
I just recently d/l REW 4.10 and I am also noticing the issue with it only producing sound once...have to restart. I am using a SB Live 24bit USB External.
Old 03-11-08, 03:43 PM   #38 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
I've uploaded a revised version V4.11, with the following changes:
New features
  • Level of sweep on left ref channel automatically adjusted to get ref input to -6dB FS
  • System delay measurement compensates for measurement bandwidth for sweep end frequency >= 200Hz
  • Added label to show distance equivalent to the System Delay
  • Data import tolerates a mixture of decimal delimiters
Bug fixes
  • Start time of captured data on scope plot was incorrect when using left channel as ref
  • Meters were not being disabled properly when the sig gen or spl meter stopped
  • When REW was used with a Creative X-Fi (and some other Creative cards) the signal generator would only work once
The main reason for this release is to fix the problem with the Creative X-Fi. The changes when using the left channel as a reference mean REW will check the level on the ref input before making a measurement and apply an adjustment to the sweep level on the left channel output to try and get the reference input level to -6dB FS. That improves the measurement S/N a little, though the additional check adds just under a second to the measurement time. REW also gives a warning if the left reference input is too low or seems to be missing.
Old 03-12-08, 03:01 AM   #39 (Link)
Alias: Bernard
User: #36
Hi John,
ETF5 data are working fine with the new V4.11 release.
Merci beaucoup (in French),
Thank you very much (in English),
Thank you very mooch (in Liverpoolian !).
Old 03-13-08, 11:40 PM   #40 (Link)
New Member
Alias: jiji the master
Loc: Romania
User: #10450
Since: Jul 2007
DARKNIGHT is offline
Re: REW (Room EQ Wizard) V4.11 Updated Release
nice software
Old 03-14-08, 09:36 AM   #41 (Link)
Moz
New Member
Alias: Moz
Loc: Lisboa
User: #3423
Since: Oct 2006
Moz is offline
Hi.
I've installed rew 4.11 over 4.10 but "AboutREW" pull-up menu still shows 4.10. Is that right?
thanks,
Moz
Old 03-14-08, 10:08 AM   #42 (Link)
Alias: brucek
User: #6
brucek is offline
Is that right?
Nope. It shows 4.11
Try Delete Settings and Shutdown option, and then try again. Maybe reload the software again.
Old 03-24-08, 04:16 AM   #43 (Link)
New Member
Alias: zeevj
Loc: israel
User: #7798
Since: Mar 2007
zeevj is offline
Re: REW V4.10 and V4.11 Release
V4.11 - when i did a sweep in size of 1M the graph i got bed measurement, the volume on the chart raised in about 50 db in the 1 kHz area, the measurements in the size 256k & 512k are fine
in V.4.10 it work just fine in 1M
great program!!!
zeev jelinek
amd athlon xp 3000
nforce 4 ultra
RME fireface 800
win xp pro
Old 04-03-08, 02:31 PM   #44 (Link)
Moz
New Member
Alias: Moz
Loc: Lisboa
User: #3423
Since: Oct 2006
Moz is offline
Hi Bruce,
It's very strange. I have "deleted settings and shutdown" like you advise, download a fresh 4.11 version instaled after trash "4.10" and the result is the same: 4.10.
I have not find any Preferences file from RoomWizard in Library to trash...
Am I the only one with this problem?
My sistem is: OSX.4.8 in a Powerbook 1.67GHz with 2GB RAM.
Thanks for your support.
Moz
Old 04-03-08, 04:01 PM   #45 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
The properties of the OS X application bundle show 4.10 but if you go to the REW Help -> About... menu you should find that the code is actually V4.11.
Similar Threads
REW (Room EQ Wizard) V4.11 Updated Release JohnM Forum Announcements | News 0 03-11-08 03:43 PM
Lawrence of Arabia - 2008 release? Owen Bartley Movies | TV Shows | Hollywood 11 09-04-07 01:13 PM
Mach 5 Audio
