Check Levels, System Delay - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Check Levels, System Delay in the Subwoofer Equalization | Calibration forum; Check Levels, System Delay Hi John, Thank you for sharing your knowledge with us by this program. I did notice that in the measurement ...
Old 03-11-08, 08:02 AM   #1 (Link)
Alias: Mike
Loc: Michigan
User: #5271
Since: Jan 2007
mstailey is offline
Re: REW V4.10 release
Hi John,
I did notice that in the measurement window when selecting Check Levels the SPL control shows 74-76db with a sweep level of -12 but the program comes back with a "Level to High" If I select check levels 2 or 3 times in a row (not changing anything on my AV unit, mic preamp or sweep level) it then comes back with Level OK.
After brucek's info on the system delay / speakers distance under the RTA post I tried this cool feature however it comes back to equal a distance of 18.08 feet. Actual distance from the front of the speaker to mic is 10ft 1 inch. Only 1 front speaker is being measured with all the other speakers and subwoofer disconnected in my example.
I'm sure in both cases it's something I'm doing wrong either by operation or setup?
Old 03-11-08, 11:38 AM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: Check Levels, System Delay
Hi Mike,
Check levels in the measurement panel warns if the input level exceeds -12dB FS, to make sure there is some headroom for the effects of room resonances. What level was the warning showing?
The delay measurement includes any delays within the processor, so if the processor is applying a delay (to account for another speaker that is further away) or if there is processing delay for the input you are using this will be added to the actual distance. What distance was reported for the other front speaker? It is also important to use a sufficiently wide sweep for that measurement, e.g. to 5kHz or more.
Old 03-11-08, 12:45 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
You can also verify that the System Delay function is being correctly reported by simply using a loopback cable on the soundcards right channel (from line-out to line-in) and do a full measure sweep.
It should return ~0.0 msec = 0.0 feet................
Old 03-11-08, 02:27 PM   #4 (Link)
Alias: Mike
Loc: Michigan
User: #5271
Since: Jan 2007
mstailey is offline
Wow! The light bulb just turned on! Thanks brucek. After John's reply, re-reading your post on the RTA and reading over the highlights for version 4.10 it finally clicked.
JohnM was spot on. I'm using the loopback instead of the soundcard .cal file so I put the right channel sound card output into my right channel aux input. Now I've set the system for mono operation but noticed I've selected 7 speakers to play on the mono channel even though I had only 1 speaker physically hooked up. So, the delay was working (which all 7 channels are set at different lengths) coupled with the fact that I'm running the front 3 (L/C/R) thru a Rane THX44.
Now the lightbulb part - Based on the measurement you suggest (which I will do) and I get the expected results I should be able to add the Rane to the chain and that will give me the delay of the Rane, No?
I'll bet there is more fun to be had as the Rane should introduce a delay and I've not added that to the measurement(delay) distance in the A/V processor.
Man, when I grow up I want to be like brucek, JohnM and Wayne P.
Old 03-11-08, 02:41 PM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
Well exactly.
Do your baseline check with a cable first and be sure you're at ~0.00msec. (The larger the bandwidth, the more accurate it will be, so sweep up to 20KHz).
Myself, I tested the BFD, (which we all claim adds a DSP delay of 0 msec or 1 foot), and indeed it measured exactly that. You can test all sorts of stuff. But, the interesting part is all your speakers. It's nice to be sure they are the same as tested with a tape measure.
Similar Threads
sub delay randyman BFD Forum 1 11-27-07 08:03 AM
use of pink noise generator to check relative channel levels terry j REW Forum 3 10-02-07 12:00 PM
Check levels with Sub Problem avaserfi REW Forum 5 07-20-07 08:59 AM
Check levels too low CdnTiger REW Forum 3 02-27-07 09:44 PM
REW - sets up right but then "check levels" too low Schwingding REW Forum 16 02-20-07 08:03 AM
Mach 5 Audio
