| REW Forum Weird Waterfall chartsDiscuss Weird Waterfall charts in the Equalization | Calibration forum; Weird Waterfall charts I have measured frequency response of my subwoofer sucessfully with room eq. However when trying to get the waterfall charts ... |
Views: 911 - Replies: 13
| Weird Waterfall charts I have measured frequency response of my subwoofer sucessfully with room eq. However when trying to get the waterfall charts there seems to be a problem. Below is the kind of plot i obtain. Is this Right ? even when i measure other speakers in another room the decay is so long. ![]() | ||||
| | #2 | |||||
| Re: Weird Waterfall charts Quote:
Set vertical Graph Limits scale to 45dB-105dB. Set horizontal Graph Limits scale to 15Hz-200Hz. Click Log graph. brucek | |||||
| | #3 | ||||
| Re: Weird Waterfall charts Even with more usual scale settings I doubt that is a valid measurement. You need to go back and make sure you can make a valid loopback measurement of your soundcard then check you are getting proper measurements of your system. | ||||
| | #4 | ||||
| Re: Weird Waterfall charts yes, otherwise that sounds like there is no decay at all... ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #5 | |||||
Wow, it feels like I’m looking into a fish tank... ![]() Regards, Wayne | |||||
| | #6 | ||||
| Re: Weird Waterfall charts After reading the post on hard knee house curve played around with BFD. Then i got the following graphs. Waterfalls look so horrible. I dunno how to solve this problem. I thought eq could help. Looks like it didn't. ![]() ![]() | ||||
| | #7 | ||||
| Re: Weird Waterfall charts It’s not as bad as you might think. For one, your level is really high. If it were down at the 80 dB range, as is more typical, it would look more like what you’re used to seeing on other threads. Also, switch the window to a longer duration, like 500 or 600. Regards, Wayne | ||||
| | #8 | |||||
(I kinda feel 300msec time scale is best to use so you don't fool yourself into thinking all is well) Lower the target so you have a more reasonable view of what's happening. Either way, you can see how the signal at ~40Hz only drops about 8dB in 300msec. Even after 300msec, that signal will be quite present in the room. It starts to muddy the sound a bit. ![]() brucek | |||||
| | #9 | ||||
| Re: Weird Waterfall charts What EQ settings did you try? What effect did they have? | ||||
| | #10 | ||||
| Re: Weird Waterfall charts Supposing the measurments are correct, he need a BFD fast. ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #12 | ||||
| Re: Weird Waterfall charts I have redone all the eqing from start after reading the hard knee house curve. Thankz alot for such a fantastic information Mr Wayne. Now the low bass sounds powerful. I have used house curve values given by Ayreonaut. These house curve values sounds the best for my room. Below are the new freq response and waterfall chart. Still got 40hz ringing. Any idea how to solve this ? ![]() ![]() | ||||
| | #13 | |||||
Do a no signal spectrum to take a look. See here. Note the furnace noise in my spectrum....... brucek | |||||
| | #14 | |||||
For another, your first graph showed ringing in the same place as the second one – only the signal level changed. A 600 ms window will show you what’s happening “long term,” whether the ringing eventually plays out or not. Regards, Wayne | |||||
