| REW Forum Waterfall: scale bug?Discuss Waterfall: scale bug? in the Subwoofer Equalization | Calibration forum; Waterfall: scale bug? Hi,
starting from version V4,10 but also in version V4,11 the waterfall seems to have a compressed x-axis. For example ... |
| | #1 (Link) | |||
| Waterfall: scale bug? Hi, starting from version V4,10 but also in version V4,11 the waterfall seems to have a compressed x-axis. For example if I take a sweep from 20 to 180 Hz the waterfall will be compressed to a range from 20 to 67.5 Hz. Is this just my system or can you confirm? Hannes | |||
| | #3 (Link) | |||
| Re: Waterfall: scale bug? Thank you brucek, but that does not solve my problem unfortunately. What I mean is that the data of the waterfall are compressed to 20 - 67 Hz. Everything is there, dips and peaks, but compressed on the frequency axis. Or with other words, the waterfall ends at 67 Hz. This is even true when I open old measurements. Right now I opened a measurement that goes up to 20 kHz, but the waterfall ends at 3 kHz. Hannes | |||
| | #5 (Link) | |||
| Re: Waterfall: scale bug? This is my first post here so first let me say that I think REW is a great program and I really appreciate the authors making this available for free. I think I have seen what Hannes is talking about as shown below squished REW graph.jpg I get this by using the minus (-) zoom when viewing a plot. Zooming back in or using the graph limits button usually fixes it. In the above graph I set the limits to 100-200 and started clicked the (-)zoom. It is more pervasive if you use wide X axis like 100-1000. I think I've seen it under other conditions but I can't recall the exact circumstances. | |||
| | #6 (Link) | |||
| Re: Waterfall: scale bug? Erich, thank you for chiming in but unless you say which your original frequency response limits were it may be something else. brucek, here is a frequency response measured from 20 - 180 Hz of a full range monitor, no smoothing applied. The waterfall shows all the peaks and dips but is compressed with to a range from 20 to 92 Hz. ![]() When I switch the frequency axis to logarithmic then it looks better: ![]() I think it is clearly a bug concerning the linear presentation of the waterfall. Regards Hannes What can I do? Hannes | |||
| | #8 (Link) | |||
| Re: Waterfall: scale bug? Hasse, thank you for the reply. This double arrow hides or shows the information window but does not cure the problem. Please somebody try this: Open a waterfall, go to Graph -> Frequency Axis Log/Linear Is your scale still correct after that? Hannes | |||
| | #9 (Link) | |||
| Re: Waterfall: scale bug? I can confirm what Hannes is seeing as this is what's happening to me also. All settings appear to be correct but I didn't dig deeper than that. Interestingly enough, mine is also cutting off at 90Hz. Also, I can confirm that the log graph is correct so it does appear to be a problem with the linear scale. Bob "There is always hope, even if it is just a fool's hope." Last edited by Bob_99; 03-14-08 at 07:12 AM. | |||
| | #10 (Link) | |||
| Re: Waterfall: scale bug? There is a bug in the waterfall display when you have the frequency axis set to linear and the left hand side of the axis is below about 50Hz. I've already fixed it for the next release, but in the meantime the workaround is to use the log axis setting. | |||
| | #11 (Link) | ||||
| Re: Waterfall: scale bug? Quote:
As you mentioned, I only see teh problem using the linear scale on the x axis | ||||
| | #12 (Link) | ||||
![]() Bob "There is always hope, even if it is just a fool's hope." | ||||
| | #13 (Link) | ||||
It never came up in my beta testing since I never use LIN scale for Waterfalls. The frequency response is in LOG, so I like to use LOG for the waterfall. Then I can move the slider back to 1 slice and see a match of my frequency response, then slowly move the slider up to 30 slices and watch the decay. brucek | ||||
| | #14 (Link) | ||||
Great, thank you! | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Why not Radio Shack for full scale measurements? | mkoijn9 | SPL Meters | Mic's | Calibration | Sound Cards | 7 | 02-11-08 07:32 PM |
| Bug, or am I and idiot? | Anthony | REW Forum | 4 | 01-31-08 12:01 PM |
| REW trouble with LF Waterfall | jhuang | REW Forum | 5 | 04-26-07 09:44 AM |
| Did I do this right? Waterfall Graphs | cyberbri | REW Forum | 3 | 02-07-07 11:06 AM |
| Waterfall interpretation | brucek | REW Forum | 9 | 10-30-06 05:43 PM |
