So I'm wondering why my project failed kinda failed, I've got an subwoofer with the following specs:
Qes: 0.419
Qms: 4.888
Qts: 0.386
FS: 21.7
Vas: 335L
xmax: 8mm
SD: 855,3 cm² (15 in)
I tried a sealed box with about 140L, got a really nice response curve, simulations predicted -13db @20hz and that's kinda what happened.
The issue is, whenever I turn up the volume while playing 20hz, it seems the THD rises a lot as soon as I get an audible response, probably due to the harmonics being played.
So now comes the question, is that subwoofer weak for 20hz? I've been told that because of the low qts it couldn't produce extended bass with closed enclosures. Is that true or is it because of the "low" xmax?
Would stuffing my box help?
I can change my sub, got those in mind:
first specs:
Imgur: The most awesome images on the Internet (12 in, xmax: 14.5mm, qts: .47, fs: 28hz )
second specs:
Imgur: The most awesome images on the Internet (12 in, xmax 18mm, qts .48 fs: 31hz)
I am a afraid their fs might be too high, the first is half the price of the second, so I could get 2, seems like a better deal, but I would get away with one if I could in order to have a smaller box.
Btw, I made a box with 140L inside it but it came out way too big, I would stick 70 or less, 100L tops. Less is better. Otherwise I'd build an Transmission Line for the 15in that I already have.
Response and THD tests where measured with a Dayton EMM-6, calibrated by Cross Spectrum
Qes: 0.419
Qms: 4.888
Qts: 0.386
FS: 21.7
Vas: 335L
xmax: 8mm
first specs:
second specs:
