Sealed Subwoofer Build ProjectsDiscuss New diy sub in the DIY Subwoofers and Build Projects forum; New diy sub No idea on the 0.3 meter issue. As for the low levels, post the problem in the REW forum. I'm ... |
Views: 11301 - Replies: 477
| | #291 | ||||
| Re: New diy sub No idea on the 0.3 meter issue. As for the low levels, post the problem in the REW forum. I'm sure someone will help you with that. We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | ||||
| | #292 | ||||
| Re: New diy sub The distance thing just sorta happens sometimes with multi eq. Do a couple runs to check the consistency of the results your getting with Audyssey, and make sure that when you run it, you do it the correct way with the mic. Following the method correctly I get very good results and they are pretty much identical every time. With the levels, from what youve told me so far everything your doing is correct, and the only thing I can see where you could be making a mistake is the amps master volume before measuring. Onkyo 875 + CA Azur 640A | AV15-X Dual Push/Pull DIY Sub | Bose 203 Fronts | MA R250 Center | MA R270 Rears Is there a cure for this addiction Click Here for the new Gaming Forums | ||||
| | #294 | ||||
| Re: New diy sub Telling you that is pointless, all levels are relative. Things like the distance from the mic will change the exact figures. Onkyo 875 + CA Azur 640A | AV15-X Dual Push/Pull DIY Sub | Bose 203 Fronts | MA R250 Center | MA R270 Rears Is there a cure for this addiction Click Here for the new Gaming Forums | ||||
| | #295 | ||||
| Re: New diy sub Heres a new graph I have just done for the sub only. I changed the sub distance to 1.5metres as it was slightly better than 0.3 metres. I can't seem to get my speakers levels up enough. I have the onkyo on -3db and the channel levels on +12 and i am only getting about 60db on the spl meter. The sub levels were ok. cheers graham | ||||
| | #296 | ||||
| Re: New diy sub So is this graph a max output graph, surely not? If its a normal graph running at the 75db cal level, then its not a bad base from which to eq from. Onkyo 875 + CA Azur 640A | AV15-X Dual Push/Pull DIY Sub | Bose 203 Fronts | MA R250 Center | MA R270 Rears Is there a cure for this addiction Click Here for the new Gaming Forums | ||||
| | #297 | ||||
| Re: New diy sub dan, how do you do the sub and speaker together. I cant remember. I have done the speaker one. Do I still have to check the levels of the sub/speakers together. Yes that is based on 75db cheers graham | ||||
| | #299 | |||||
| Re: New diy sub Quote:
![]() We're all in this together! Members DIY Subwoofer Database Enclosure Volume Calculators Driver Wiring Diagrams | |||||
| | #300 | |||||
this forum is nice and friendly and certainly does not tolerate any kind of abuse...Enjoy ! ![]() | |||||
