Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > DIY Speakers | DIY Subwoofers > DIY Subwoofers > Sealed Subwoofer Build Projects
Donations Reviews Vendors
Views: 75563 - Replies: 427
Old 02-11-10, 03:10 PM   #31
Michael
Since: Jan 2010
Milford PA
  gmichael is offline
Re: Maelstrom-21 giveaway build
corock wrote: View Post
oops! I don't live in a mansion. That's cubic feet not sq ft.
Thank you. I was feeling mighty small....
Old 02-11-10, 03:12 PM   #32
HTS Moderator
gperkins
Since: Aug 2008
  gperkins_1973 is offline
And if your worried about size then here's a 10 cu ft ported sub. Now try to imagine two of these bad boys.
Believe me two ported subs have much more impact than one. I was really surprised how much better the bass sounded. Much deeper and much more sure footed and really clean.
Mmmm Yum Yum.
cheers
Graham
Old 02-11-10, 04:18 PM   #33
Banned!
Ryan
Since: Jul 2009
sfsd
  Ryan Anderson is offline
fackamato wrote: View Post
I don't know if a sealed 21 will be enough for that room. Maybe two ported 18s?
the guy won the 21" so this all has to pertain to the 21"
Old 02-11-10, 05:01 PM   #34
corock's Avatar
corock
Since: Sep 2009
saskatchewan
My Photo Gallery
  corock is offline
I started this thread.
from the modelling I did, it looks like I'll have to keep the amp down around 1000W if I want to use any eq. How do companies like Paradigm use big 3000W amps on sealed subs?
Old 02-11-10, 05:24 PM   #35
HTS Moderator
gperkins
Since: Aug 2008
Oops good point.
Here you go with the 21" sub. Both subs with 2000 watts. Sealed not going over max excrusion and the ported not until 12hz.
Guess again, which is the ported.
Tune this to 14.5hz and you will still see a gain with the ported. Unless you are going to listen or watch your stuff at reference you won't need a hpf but even with a hpf you will still be up on the sealed.
The first graph is without a hpf and the second with.
cheers
graham
Old 02-11-10, 05:46 PM   #36
Banned!
Ryan
Since: Jul 2009
sfsd
graham, my friend, I fear this battle and war to be lost. The only way for anyone to grasp the truth is experience. Until they themselves simply try it, all the graphs and plots and verbage will go nowhere. No one is going to stick a port in a box with a 21.
corock, I think you should aim for a 3000 watt amp. The sub I'm told loves 3000 watts... maybe 8 cubes is too large to use all 3000 watts, but that makes room for dynamics...headroom... effortlessness... ease of wear and tear on equipment. I wouldn't sell myself short with just 1000 watts even if plotting suggests it to be all you need.
Old 02-11-10, 10:20 PM   #37
corock's Avatar
corock
Since: Sep 2009
saskatchewan
My Photo Gallery
  corock is offline
Okay, lets go away from simulation and take a look at some real life results. Here are the measurements for one of my PB-13U's.
First ported and tuned to 15hz
Then sealed
I'm not using any eq on either of these
Thoughts?
Old 02-11-10, 11:00 PM   #38
corock's Avatar
corock
Since: Sep 2009
saskatchewan
My Photo Gallery
  corock is offline
gperkins, when I try to port an 8 cu ft box I end up with a 57" port, and how did you use 2000W sealed without getting the excursion to high? I might be doing something wrong with WinISD.
Old 02-12-10, 12:36 AM   #39
HTS Moderator
gperkins
Since: Aug 2008
When doing a ported you need to do a slot port to get that size port I quoted and not a round one as it will be long. The 21" sealed is fine in a 8 cu ft box and give a qtc of 0.760. Larger than 8 cu ft will go over max excursion and will lower qtc giving you better low end and smaller box will give you less excursion but higher qtc (tighter bass, less low end). Hence the reason going ported to give you more.
I will drop you some more diagrams tonight but it depends what you want your subs for.
cheers
Graham
Old 02-12-10, 09:22 AM   #40
corock's Avatar
corock
Since: Sep 2009
saskatchewan
My Photo Gallery
  corock is offline
I use my system for music, movies and tv. Music will be the emphasis of its use though. I like all music, but lean toward hip hop, pop, rap, etc with lots of artificial bass. That's definately what I listen to if I got the volume cranked up.
This build will be about compromise, as is all builds I guess. Aethetics do play a big part of my decision making and I'm not a big fan of slotted ports. From the in-room measurements of my SVS it looks like I'm getting pretty good results down to 15hz out of a sealed box. Sure, the ported box has more spl from 15-20hz but I don't think I'm willing to give up my sealed box design ideas for it.
Kevin H. says not to bother with any less than 2000W to power this thing. The amp has to be black so that rules out the 2700W Face Audio amp. I was thinking of the Behringer EP4000. That's overkill but I guess I don't have to use all that power.
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > DIY Speakers | DIY Subwoofers > DIY Subwoofers > Sealed Subwoofer Build Projects »
build, giveaway, maelstrom-21
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
