Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > DIY Speakers | DIY Subwoofers > DIY Subwoofers > Sealed Subwoofer Build Projects
Donations Reviews Vendors
Views: 75571 - Replies: 427
Old 02-12-10, 02:19 PM   #51
corock's Avatar
corock
Since: Sep 2009
saskatchewan
My Photo Gallery
  corock is offline
I started this thread.
Re: Maelstrom-21 giveaway build
I'm using plywood because I want to stain the wood so the lines and texture are still visible. I'll be using sanded plywood because it doesn't have chunks missing from the edges like the standard sheets. Its about $45 a sheet. in Canada.
Old 02-13-10, 03:27 PM   #52
corock's Avatar
corock
Since: Sep 2009
saskatchewan
My Photo Gallery
  corock is offline
Here's some renderings on how I plan on building the box. It's 24" wide x 28" high X 29" deep and should be between 7.5-8 cu ft. I designed it to highlight the size of the M-21.
Name:  top angle.jpg
or here is a bit different version and would add about 1 cu ft
Name:  think side angle.jpg
Old 02-13-10, 04:49 PM   #53
Drizt's Avatar
Drizt
Since: Aug 2006
Melbourne, Australia
  Drizt is offline
, that will look excellent. Looks very difficult to build ???
Source: SB Duet, Pre/Pro: Integra DHC-9.9, Speakers: SGR MT3FSL (active), Sub Amp: Crown K2, Subs: 2x SGR Maelstrom-X (125L Sealed)
Old 02-13-10, 05:31 PM   #54
Banned!
Ryan
Since: Jul 2009
sfsd
  Ryan Anderson is offline
um...wow?
Old 02-13-10, 05:43 PM   #55
smoggysky
Since: Aug 2009
los angeles
  smoggysky is offline
nice, can't wait for the pics
Old 02-13-10, 06:49 PM   #56
matt
Since: Sep 2009
San Antonio, / Duluth MN
  mj79 is offline
smoggysky wrote: View Post
x2.. Page 3 and not even 1 pic
Old 02-14-10, 02:07 AM   #57
HTS Moderator
gperkins
Since: Aug 2008
  gperkins_1973 is offline
I agree too that is going to test anyones skills. How are you going to do the curves?
cheers
Graham
Old 02-14-10, 09:12 AM   #58
corock's Avatar
corock
Since: Sep 2009
saskatchewan
My Photo Gallery
  corock is offline
The box will be made of horizontal cross sections of 3/4 " plywood stacked on top of each other and glued together. The main bend in the box is easy as that is on the same plane of the pattern cut into the plywood. The curve around the driver gets a bit trickier as it on an opposite plane. Essentially I will have to widen the pattern 5/16" as I approach the widest part of the circle. Widening the tube part of the pattern will increase the area before it intersects the main box giving it that blend as it approachs the rear of the box. That will leave me with a rough pattern of the tube around the driver, from there its a lot of sanding. Right now i'm leaning toward the bottom design with the square back half of the box.
There won't be any pics until after the driver arrives. It should be here next week. I need to actually see this thing and physically use it as I make my patterns. This design will take lots of careful thought...measure 6 times and cut once in this case.
Old 02-14-10, 12:32 PM   #59
Raven
Since: Aug 2008
Bolingbrook, IL
  Lonely Raven is offline
Awesome! I look forward to seeing this built. I love ambitious designs and clever woodworking!
Old 02-14-10, 03:52 PM   #60
corock's Avatar
corock
Since: Sep 2009
saskatchewan
My Photo Gallery
  corock is offline
I'm leaning towards design 1 because its 1.5" shorter than design 2 but still the same volume. But I've been looking at these so much my perspective might be out of wack; I would appreciate your opinions on which design you like better 1 or 2?
If you want to do a 3D spin around the boxs, download Google Sketchup and go to this link http://sketchup.google.com/3dwarehou...3e&prevstart=0
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > DIY Speakers | DIY Subwoofers > DIY Subwoofers > Sealed Subwoofer Build Projects »
build, giveaway, maelstrom-21
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
