| SoundSplinter RLP-18" LLT boxDiscuss RLP-18" LLT box in the DIY Speakers and Subwoofers forum; RLP-18" LLT box hello everyone I'm building a subwoofer box.it is about 698 liters before subtracting for the port. driver. bracing. etc. it ... |
Views: 3180 - Replies: 39
| RLP-18" LLT box hello everyone I'm building a subwoofer box.it is about 698 liters before subtracting for the port. driver. bracing. etc. it will be my fist sub build. I got it from ss around last November while i was waiting for an sr-71 speaker kit. now I'm ready for a sub. I never tested the rlp-18 when I got it because I didnt want to hurt it. how should I test it to make sure it works? also what to line the box with premium carpet pad. ridged foam insulation. mattress foam. rigid fiberglass. fiberboard. acoustic ceiling tiles. and how thick? it would be nice to use something I could buy in a store here in town. the box or enclosure is in a perminit location boarded by a closet, wall back of fireplace,wall on the side front firing. port in side wall. rear projection TV on top. 8"port 28"long. I have wire terminals but I'm thinking of just ruining wire Thur the box it would be one less connection whatdaya think. I have very much enjoyed reading these threads and building, then reading, then building. then hearing some good sounding music. I will try to put some pics on here. I,m not so good on my computer yet. something about pic to large. anyway thanks very much to all of you . bill | ||||
| | #2 | ||||
| Re: RLP-18" LLT box Welcome Bill, Box sounds big for a rl-p18. What's the tune? ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #3 | ||||
| Re: RLP-18" LLT box The net volume would be around 645 liters, depending on how much bracing you used. Tuning would be 13.5 hz. For lining the cabinet, I use mattress foam, just make sure it's the open cell type. It's cheap and easy to install. If you have the wire terminals, use them. It's easier to connect and disconnect if the sub would ever need to be serviced. If your pics are to big to upload you'll have to make them smaller. If you're using Windows XP, you can download a program to resize them. http://www.microsoft.com/windowsxp/u...schelman2.mspx | ||||
| | #4 | ||||
| Re: RLP-18" LLT box I used 625 L net and tuned 13.5. Very nice! ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #10 | |||||
| Re: RLP-18" LLT box Quote:
![]() If you will be placing a TV on the sub, I strongly suggest you add some shelf bracing to your box. You don't vibrations transfered to your TV. | |||||
| | #11 | ||||
| Re: RLP-18" LLT box that's as far as I got so far. more bracing to come. I can subtract the driver and port volume and 1cubic ft of bracing that maybe close to 650L. is bigger than that bad?. 26.5 h 29.D 54.5w. | ||||
| | #12 | ||||
| Re: RLP-18" LLT box Woah that is a box. But I would not put a TV on it. I built a sub that fits into my entertainment cabinet (measly ported 12" driver) and even at less then half volume it causes sympathetic vibration in the TV cabinet. I am in the process of trying to isolate/dampen the cabinet now. | ||||
| | #13 | |||||
| Re: RLP-18" LLT box The setup is in a good location. A shelf just above the sub should work. Quote:
http://www.hometheatershack.com/foru...-database.html | |||||
| | #14 | ||||
| Re: RLP-18" LLT box holly smokes! you guys. I never thought about the poor TV. if the vibretions killed my wifes big old tv I might have to get a front projector. hey mike, what would the shelf sit on? maybe I could put a matress between the box top and the tv. its very big and heavy. it will take a forklift to get it up there. I think I'l look inside that monster and see if I can take some stuff out. like the speakers. ect. I'll wait till the wife leaves. | ||||
| | #15 | ||||
| Re: RLP-18" LLT box Post the make and model of your TV so we know what we're dealing with. | ||||
| | #17 | ||||
| Re: RLP-18" LLT box Well that changes things a bit! I was not expecting it to weigh 240 pounds! I'm not sure what to suggest here. Hopefully someone will join in with an idea on how to isolate the TV from the subwoofer. | ||||
| | #18 | ||||
| Re: RLP-18" LLT box How bout building a heavy duty shelf above the sub. You have 3 sides so it should be pretty easy to support the shelf. Use 2x4s on edge, sort of like a sub floor. Attach a sheet of plywood on top.Cover the front of the 2x4 with a nice piece of 1x6 ripped down to 5 inches or so, for aesthetics. You can try putting 2 auralex subdudes on the shelf under the TV. That might help a little. | ||||
| | #23 | ||||
| Re: RLP-18" LLT box I,m not sure they make a kit for open cell foam. when retro foam came out an sprayed the inside of my garage roof it was open cell. what about the canned foam called great stuff. it dose not say opened or closed. no one at manards knew what I was talking about. but if its going to be bad to use closed cell foam wont use it. I sent for a greenfoam kit already I,ll use it for something else. it would be nice to spray on something. thanks for the heads up. MIKE P. also said make sure its open cell foam so that makes it unanimous. | ||||
| | #24 | ||||
| Re: RLP-18" LLT box Hi Bill, you definitely want open cell foam, otherwise you aren't giving the air any room to move. You can use fiberglass, polyfill (I think it's used for crafts and available at WalMart), or anything similar, but for a ported sub, you shouldn't need much. Maybe just a thin layer to line the inside of the sub. Usually sealed subs get stuffed to fool the driver into thinking it is in a bigger enclosure (or something like that). | ||||
