Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > SoundSplinter
SoundSplinter
My RL-P15 Infinite Baffle system
Discuss My RL-P15 Infinite Baffle system in the DIY Speakers and Subwoofers forum; My RL-P15 Infinite Baffle system I'm using 8 of the RL-P15s. The Vas turned out to be just right for my IB space which is ...
SoundSplinter
Views: 721 - Replies: 4
Old 06-05-08, 10:56 AM   #1
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
  RobertR is offline
I'm using 8 of the RL-P15s. The Vas turned out to be just right for my IB space which is 3 feet behind the front wall. It sounds wonderful:
Old 06-05-08, 11:23 AM   #2
Alias: Ben
Loc: Pinawa. Manitoba
User: #739
  Bent is offline
Re: My RL-P15 Infinite Baffle system
I have nothing good to say - except I'm jealous.
this looks really good.
Old 06-05-08, 12:22 PM   #3
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is online now
Looks like it's going to be a very nice set-up. What's the amplification for the RLP's? Also what are your mains and center speakers going to be?
Old 06-05-08, 12:34 PM   #4
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
  RobertR is offline
I'm using the Behringer EP2500 into 2 ohms per panel. My LCRs will be VMPS. Here are the front L and R:
Here are the specs:
Frequency response: +0, -3dB 16Hz-40kHz; average THD 0.9%/1W drive
Driver complement: Two 12" carbon fiber woofers, 12'' slot-loaded, mass-loaded PR subwoofer; 52'' ribbon panel midrange, dual spiral ribbon tweeters.
Nominal impedance: 4 ohms
Sensitivity: 89dB/1W/1m
Recommended amplifier power: 350W RMS, 20W min
Performance: 115dB/1m SPL for 5% THD
Dimensions: 14 1/2''W x 68''H x 17 3/4''D plus the width of the ribbon panel
Weight: 375lbs
Old 06-05-08, 02:50 PM   #5
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
  atledreier is offline
That's wicked! Looks awesome! Knowing what two RL-p15's can do, well... Rock on!
« Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter »
