| SoundSplinter RL-p12 in car modellingDiscuss RL-p12 in car modelling in the DIY Speakers and Subwoofers forum; RL-p12 in car modelling Hello!
In home audio we figure room gain is about 6dB/oct below the lowest room node. How do I figure ... |
Views: 716 - Replies: 26
| RL-p12 in car modelling Hello! In home audio we figure room gain is about 6dB/oct below the lowest room node. How do I figure cabin gain for a small car? I'm thinking of using an RL-p12 for a SQ setup. Nothing very fancy, but definetly no boombox. I'm thinking separates up front and a ported box in the boot. The car is a Mazda 323 GTR, so it's an open cabin. I'll probably go for a cheap'ish amplifier, around 100W or so. Hard to tell, the ratings on the box are usually meaningless. | ||||
| | #2 | ||||
| Re: RL-p12 in car modelling Ricci did a measurement in a Jeep and the cabin gain was extreme. Last graph of the first post show the results. http://www.hometheatershack.com/foru...room-gain.html | ||||
| | #3 | ||||
| Re: RL-p12 in car modelling Yeah. Kinda hard to read anything about rolloff there, with the gain being as it is. Big jump at 70ish Hz and then looks like a 6dB/oct increase as you go down. But there definetly looks like a 'base gain' of about 20dB! Wow! So I think output shoudn't be much of an issue. I' more concerned that I'll have no means of EQ in the car. That's out of my price range, I think. I'll look into this some more. Anyone have experience with the RL-p12 in car for sound quality? Any other drivers that would do a better job on a budget? | ||||
| | #4 | |||||
| Re: RL-p12 in car modelling Quote:
-Chris | |||||
| | #5 | ||||
| Re: RL-p12 in car modelling That's a good idea. Is there no proper 12V parametric EQ that would do the job? | ||||
| | #6 | |||||
If ones goes with the DCX: Using a laptop to set up the DCX with it's GUI while listening in real time will be very useful. -Chris | |||||
| | #7 | ||||
| Re: RL-p12 in car modelling Modelling the RL-p12, it looks like sealed will be the way to go. Ported will give me a huge peak around tuning, and a steep dropoff below. The sealed has a rolloff that almost match the general cabin gain, and the RL-p12 will have incredible headroom for the power I plan to feed it. Is there anything I should think about regarding the 12V->110/230V conversion? What about noise? Could a DCX EQ the front separates as well? How about a BFD? Could that be used? Most amps have an analog crossover anyway, and all the bands of a BFD could emulate shelving and stuff most times, and it would be alot wheaper. Do the DCX have delay adjustment? | ||||
| | #8 | ||||
| Re: RL-p12 in car modelling Your results may vary of course, due to many factors but I'm getting greater than 30db gain in the lowest bass and basically flat response down to 3hz in my Jeep I assume roughly 12db octave gain.I'd go sealed for SQ in a car. Ported always seems to have a rising response with a big boomy peak around tuning. You could pad that down with EQ and have massive headroom. Sealed is smaller and simpler if you aren't worried about rattling other cars license plates as you go by. | ||||
| | #9 | ||||
| Re: RL-p12 in car modelling Yeah, looks like sealed will be a winner. I'm more concerned with blending with the separates up front than with output, to be honest. Ridiculous levels of bass is easy in a car, so EQ and delay is more important, and infinitely harder to get right. With virtually all drivers at different distance, orientation and phase the soundfield gets really complex. I'm starting to think good EQ is the only way to go. I've heard of some automotive headunits have Audyssey built in. Now THAT sounds like a great application for Audyssey! ![]() Edit: I'm currently looking at the Rockford T400-4 amp to drive the sub and separates. It's got very good reviews and the price is very good. Any thoughts? | ||||
| | #10 | |||||
There is a 12V PS unit for the DCX. It has no noise issues. You open the top cover of the DCX, unplug the 120VAC supply, remove it. Put in the new 12VDC supply and plug it in. Replace top cover. As for signal routing... I would use an ART DTI or similar up front and feed the unbalanced RCAs to this. The ART DTI in turn will output balanced XLR lines. Run balanced to the rear of car - this will prevent any noise pickup from occurring. | |||||
| | #11 | ||||
| Re: RL-p12 in car modelling Awesome. I wasn't aware that the DCX was so versatile. I need to read up on that unit for sure! Is the 6 outputs independently EQ'ed as well as assignable to output? Can I create a mono output from two inputs? Going this route I may go for a 6-channel amp and go all active with a single DCX. Now THAT would be awesome. I haven't thought about midbass yet. I don't have the car yet so I don't know how much room I have. If I do get midbass units, I might just use a single channel for those and a single channel for the subwoofer and still get good EQ for all. I guess mono midbass is much preferred to un-EQ'd midbass. One concern, though. The midbass units will most likely be placed in the back, either all the way with the subwoofer, or in the rear seat panels. Would this pull the image rearwards? How high do you usually cross the midbass over? I'm not concerned with rear seat SQ at all, but both front seats should sound good. | ||||
| | #12 | |||||||
-Chris | |||||||
| | #13 | |||||
![]() The DCX definetly sounds like the way to go. Any tips on cheap'ish amps in the $500-$600 range? Edit: Just found a used Precision Power AX606.2 on ebay fro $350. I have owned one PPI amp before and it was truly awesome. Is this the gem I think it is? Last edited by atledreier; 01-12-09 at 05:32 AM.. | |||||
| | #14 | |||||
However, I will urge you to go for the most 'real' power you can afford, even for mids/highs. The inherent noise floor of a car is so high, that I would even suggest 150 RMS for each tweeter and 250 RMS for each mid range. Assuming average sensitivity drivers. This assumes you listen to dynamic music. If you only listen to TOP 50 stuff... not much point considering the pathetic level of dynamics in the overwhelming majority of modern album releases.-Chris | |||||
| | #15 | ||||
| Re: RL-p12 in car modelling So the AX606.2 is too weak to power my entire system? Even in 5-channel mode? | ||||
| | #16 | ||||
| Re: RL-p12 in car modelling Mav... I have a brand new DCX I can let you have for $240 + shipping... still NIB. Check out the Phoenix Gold Xenon amps... the 200.4 is a real 200+ watts x 4 and they are very clean amps. ebay is about the only place you can find them. I have it running my mids/highs active. I also have the 1200.1 for my subs. | ||||
| | #17 | ||||
| Re: RL-p12 in car modelling I had a ZX475TI back in the day on a Boston Acoustics pro6.4/6.0/12.4 system and it totally rocked! ![]() Found an X100.4... | ||||
| | #18 | |||||
I would power the subwoofer in question with an absolute minimum of 500 Watts RMS. If you want to minimize distortion to the absolute fullest extent, then as another poster suggested earlier, use it in a proper ported cabinet system. I would personally target no higher than a 25Hz tuning. Ideally 20Hz. Then use the DCX to flatten the response. This would give you massive headroom, and absolutely minimize non-linear distortion(s). Yes, it would be a sizable cabinet. Be sure to use a slot port and keep air speed well under 20 Meters/second at the target 500 Watts input power for ideal performance. Of course, I understand if you prefer to go sealed due to the substantial space savings and simplified cabinet construction. I don't know what your car power supply system is like, but I would probably add a very large capacity battery on a battery isolator, and a low ESR 1 farad capacitor on this system. -Chris | |||||
| | #19 | ||||
| Re: RL-p12 in car modelling I am aware of the benefits of ported, I use two RL-p15 LLT tubes for my home theater. I was suggesting the sealed before EQ was brought to my attention. I am also aware of the spl and dynamics requirements for automotive audio, and my opinion is that you can't really get good sound quality in a rolling vehicle anyway. I want to be able to stop my car and enjoy good sound while reading a book or having a snack or whatever.. yeah, I'm weird. ![]() I'm one of those that truly love driving for the sake of driving, and music for the sake of it. With a good sound system I can do both, but not at the same time, usually. If my audio system can maintain enough SPL to break out of the road noise I'm fine. I want the system to be able to wow my friends for sound quality, not be the loudest boombox in my street. That is easy, if not cheap. From modeling the RL-p12 with 100W of clean power it can do over 100db even without figuring cabin gain. For my budget I think that's enough. We'll see, I can always switch amps. Right now the car is on my priority list, then I'll build a system for it. Thanks for the help so far, i'm sure I'll have many more questions once I get into this! ![]() | ||||
| | #20 | ||||
| Re: RL-p12 in car modelling Chris... of all people I would have assumed you would have investigated capacitors. No need to waste your money... they do not help and there have been several credible tests completed that prove the same. You can add a second battery, of which any would be superior than even a 100 farad cap. There is a company that actually make a product called BatCap (or something similar) that is actually a small battery for the purpose of extra power in a system. However, adding a battery is really only going to give you longer play time with the vehicle engine turned off. If you need more amps for the system, the only solution is adding a higher output alternator. I run right at 2000 watts in my car and use a Kinetik HC1800 (1900 Amps 81 Ah)... and I really need a HO alternator, but they don't make one for my vehicle at present. | ||||
| | #21 | ||||
| Re: RL-p12 in car modelling did you get my PM sonnie? | ||||
| | #22 | ||||
| Re: RL-p12 in car modelling Yup! | ||||
| | #23 | |||||
-Chris | |||||
| | #24 | ||||
| Re: RL-p12 in car modelling I'm with you on the isolated battery, but in this particular vehicle weight will also be an issue. The subwoofer enclosure needs to be removable for track use, and an extra battery is too much weight to lug around on track. There's enough of that as it is. I think I'll just exchange the normal battery for a high performance one. Is the Optima range still considered high performance? The DSPower unit is sold out. Know anywhere else I can get something similar? Last edited by atledreier; 01-15-09 at 01:09 AM.. | ||||
| | #25 | ||||
| Re: RL-p12 in car modelling Ok, I just bought a PG X200.4 amp to power the mid and highs. I may have to run the mid/highs off the analog crossover for now and have the other two channels drive the sub for about a month, as the car purchase depleted my bank account a little more than I'd hoped. Should be good for a while, though. The 1200.1 seems like overkill for a single 12" driver. I thought a 600.1 would be sufficient for a highpass filtered ported 12". | ||||
