| SoundSplinter Rlp18 sealed enclosure.Discuss Rlp18 sealed enclosure. in the DIY Speakers and Subwoofers forum; Rlp18 sealed enclosure. Is the Rlp18 the best choice for a sealed enclosure in it's price range? This sub will be used 90% ... |
Views: 553 - Replies: 2
| | #2 | ||||
| Re: Rlp18 sealed enclosure. The RLp-18 is unavailable until May, the last I heard. The Exodus Audio Maelstrom-X has a higher power handling and more output. | ||||
| | #3 | ||||
| Re: Rlp18 sealed enclosure. The exodus looks to have the same basket as my rlp-18. I noticed the single spider? As well as a triple joint cone,coil,spider set up with non sewn in leads and foam surround?. The rlp-18 uses 2 spiders and 3 individual glue joints with sewn in tinsil leads and the cool tall rubber surround. The exodus's motor is beefy looking though, i'll give it that. The rlp has more quality to it I'de say. | ||||
| Bookmarks |
| Tags |
| enclosure., rlp18, sealed |
| Thread Tools | |
