Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > SoundSplinter
SoundSplinter
RL-P 15 Project (PICS)
Discuss RL-P 15 Project (PICS) in the DIY Speakers and Subwoofers forum; RL-P 15 Project (PICS) Heres the response graph of the sub before and after EQ and no smoothing added. 15.5hz tune....
SoundSplinter
Views: 8775 - Replies: 53
Old 03-03-07, 07:12 PM   #26
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Re: RL-P 15 Project (PICS)
Old 03-03-07, 07:56 PM   #27
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
That's awesome...
Old 03-23-07, 06:49 PM   #28
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Heres with and with out EQ together. Finaly, I can now work on matching it with the mains.
Old 04-09-07, 08:36 PM   #29
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Latest sweep with Mains from 10hz to 200hz. Measured with 80hz crossover and 1/3 smoothing.
Last edited by Jerm357; 09-21-08 at 12:59 AM.. Reason: more accurate graphs, will get real sweeps soon
Old 04-09-07, 08:46 PM   #30
Alias: Geoff
Geoff St. Germain's Avatar
Loc: Winnipeg, Canada
User: #4919
Since: Dec 2006
  Geoff St. Germain is offline
Now that looks nice!
Old 04-09-07, 09:14 PM   #31
Alias: Rodny
Rodny Alvarez's Avatar
Loc: Millbrook AL
User: #158
  Rodny Alvarez is offline
Excellent!!!
Old 04-10-07, 03:54 PM   #32
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
Superb response trace and a really nice project!
Good point about the Art Clean Box too.
There is around 6dB lower output from a domestic preamp compared with a pro power amp's input needs.
I used my active crossover to do the same job by increasing the gain by +6dB for the sub channels.
The speaker channels were left flat (0dB) since they are driven by a domestic stereo power amp.
Can the BFD be used to increase overall gain to feed a pro power amp from domestic AV kit?
I thought the BFD balanced itself out at neutral gain regardless of the filter settings?
Old 05-11-07, 05:53 PM   #33
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
grjohnso wrote: View Post
That's funny Geoff, I was thinking the same thing when I saw the sub and iguana in the same pic... Hope he likes bass...
Jerm, question about the Art cleanbox... I'm assuming you have it between the Onkyo and the Behringer.. Were you just using RCA to 1/4" connects before?
The reason I ask is I've picked up a BFD to throw between my old Onkyo (TX-SR504) and Audio Source AMP, which means I'll be going from unbalanced, to balanced, back to unbalanced again... Am I just asking for a bit of trouble, or?
I'll check the rest of the forums to see if I see more info on the ART, as it's not something I had thought about previously.
*edit* --- Thinking and reading a bit more, I should be able to deal with this by playing with the BFD's gain. Still, this little box would have been nice back when I was using an old Carver rack mount amp directly from by receiver to my sub converting RCA to XLR... It just never put out like similarly rated consumer level Carver amps I demo'd using native unbalanced connections.
Anyway, killer looking sub. Can't wait to work on my next one...
I dont know what happened but after I installed the BFD I no longer need the clean box. I can now get a good signal without it. It might be just because now I have the LED signal lights assuring a full signal and never realy needed the cleanbox in the first place. I think the reason I thought The cleanbox was so great was because I could run the sub much hotter with it, But when It was at the same level as the rest of the speakers it made no difference. Since the BFD at maximum level (when using the -10dBV switch setting) puts out 1.26volts I know Im good since my amp has a sensitivity of 1.15volts.
Old 05-11-07, 06:03 PM   #34
grjohnso
Inactive
Alias:
User: #
Posts: n/a
Yes, the BFD seems to take care of the gain issues and takes care of any need for a cleanbox...
The first step I did was match the gain from my AV Receiver to the BFD going through the BFD guide and all is well. No clipping, and plenty of juice to the amp. I'm definitely not line-level impaired now...
Back on track, that's still a nice sub... Can't wait 'til I can sneak something bigger than 6cf past the wife... Someday..
Old 01-12-08, 12:24 AM   #35
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Thought Id ad a small update since I upgraded my receiver to the new Onkyo TX-SR705. I ended up getting rid of my BFD since after running the auto setup on the receiver (Audyssey MultEQ XT) I ended up getting outstanding results. Heres a graph showing the sub before and after.
Im pretty happy with my frequency response.
Old 02-12-08, 01:09 AM   #36
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
  atledreier is offline
Awesome, dude! This is what I had in mind to do, but I think I'll make two...
Did you notice much difference with and without the padding? What do you 'experts' say about not flaring the port?
Also, the box is pretty narrow, and as wide as it is deep. Is that a problem? Would it be better to go with a slightly bigger footprint and lower box?
Old 05-31-08, 02:12 AM   #37
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Just finished Painting my sub again with some Rustoleum Stone spray paint. Check it out, I think it turned out great. It realy looks perfect even though the first picture makes it look worse then it does in real life. I also made and installed a flair to the bottom of the port but I forgot to take pictures of it.
Old 05-31-08, 03:27 AM   #38
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Looking good! How many cans did it take to spray the box?
We're all in this together!
Members DIY Subwoofer Database
Old 05-31-08, 10:41 AM   #39
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
4 cans of this.
Old 05-31-08, 12:28 PM   #40
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
WOW!
I am enthralled by the finish of the sub. Do you have a link for that spray?
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 05-31-08, 04:03 PM   #41
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Blaser wrote: View Post
WOW!
Here you go...
http://www.rustoleum.com/CBGProduct.asp?pid=79
Old 06-27-08, 12:30 PM   #42
reedwesd
Inactive
Alias:
User: #
Posts: n/a
You mentioned that after you got the 705 you no longer needed the BFD. I have the 805, the RLP-15 you have, and an EP2500. Would you recommend getting a BFD or just let the 805 do the EQing?
Thanks
Old 06-27-08, 01:21 PM   #43
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Well it all depends what you want the EQ to do. If you just want a flat frequency response I would say just use Audyssey, But if you would like to set up a house curve a BFD is still a great tool for that.
Old 06-29-08, 04:38 PM   #44
Alias: Darrell
Loc: Austin, Tx
User: #10940
Since: Aug 2007
  darrellh44 is offline
Can't Audyssey do house curves as well as flat?
Old 09-21-08, 01:19 AM   #45
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
darrellh44 wrote: View Post
Not on my Onkyo 705 unless I get creative with my crossovers and my sub trim. On other receivers there might be an option for an Audyssey house curve, but I dont know. Im pretty happy with a flat sub response though.
Old 09-21-08, 01:37 AM   #46
Alias: Maverick
User: #7168
Since: Mar 2007
I agree. With a flat curve that goes all the way down, it feels fast and agile. With a heavier bottom it feels a little bloated and soggy.
Old 09-21-08, 02:04 AM   #47
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
atledreier wrote: View Post
Funny you responded, I was just walking my way through you RLP build thread. You did a very nice job by the way.
Old 09-21-08, 02:29 AM   #48
Alias: Maverick
User: #7168
Since: Mar 2007
Hehe! Thanks! I love them!
BTW, I'm redecorating my theater... Current status:
Old 12-30-08, 01:16 PM   #49
Alias: Redduck
Loc: Cumberland, MD
User: #27527
Since: Oct 2008
  redduck21502 is offline
Looks great, I would have been tempted with that much box to make a coffee table. Although, cups would probably bounce off of it!
Did you spray clear acrylic on that when it was finished? Those special paints can peel off if not protected by a clear acrylic coat. Also, 3 or more coats makes a really hard coating.
I'm still trying to figure out this whole Art clean box, it's cheap enough from what I have seen, but I wonder if I should have one.
Old 01-04-09, 05:27 PM   #50
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
No, I never did put any clear coat over the paint. I dont realy feel its needed in my room since it never gets toutched, banged or scratched. I could see it being useful in a higher risk room with kids and pets running around though.
About the cups jumping off it if it were a coffee table you would be surprised. There is realy no moving going on at all. I have placed a dime hanging half way off the top edge and started pumping out some heavy bass and the coin never even moved.
About the clean box All I can say is I have found that there is no need for one with Onkyo receivers and I have tried them out twice. A good way to realy see if one is needed is to try a Behringer Feedback Destroyer (BFD) and look at the signal leds and see if you can get it in to the red with it set to the -10dBV setting. If you can you will know that your receiver can at least put out 1.26volts which should be enuff for most amps. With my Onkyo I could even hit the red led with it set to the +4 dbu setting.
« Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter »
