how much to pay for a used SS RL-P 15? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > SoundSplinter
SoundSplinter
Discuss how much to pay for a used SS RL-P 15? in the DIY Speakers and Subwoofers forum; how much to pay for a used SS RL-P 15? How much would you pay for a used SS RL-P 15? I came acroos one for sale with an enclosure ...
SoundSplinter
Old 10-04-06, 11:58 AM   #1 (Link)
Alias: Mr. Lamb Fries
Loc: Pittsburgh
Mr. Lamb Fries's Avatar
User: #2639
Since: Sep 2006
Mr. Lamb Fries is offline
How much would you pay for a used SS RL-P 15? I came acroos one for sale with an enclosure made for a car. I would not need the enclosure and wanted to know how much should I offer for the driver. I was told it was in good condition and was only a few months old. I wasnt sure how these drivers were as far as retaining their value.
Searching for DIY Sub...Driver, Amp, and Box Design!
Old 10-04-06, 01:15 PM   #2 (Link)
SS Mod
Alias: Mike
Loc: California
User: #1126
Since: Jun 2006
SoundSplinter is offline
Arrow Re: how much to pay for a used SS RL-P 15?
That decision is up to you my friend! As I am already selling these drivers on the super cheap, I would venture to suggest that if the product is in good working order that it will resell for close to its original value. Ultimately, it will come down to what you are willing to pay for it and not what someone else may be willing to pay.
Old 10-04-06, 01:54 PM   #3 (Link)
Loc: Pittsburgh
User: #2639
Since: Sep 2006
Thanks for the reply...I completely understand...I guess I should have asked the question, how much do these subwoofers go for used (if you can find one), or how much do they depreciate in value (if still in good condition)? Before I buy something I like to make sure I am getting a fair price. There are no "blue books" I can reference to get a better understanding. Certainely someone has bought one used, or sold one, and I was looking for a ballpark price.
I also understand your position, that is having a vested interest in the company, you would like to generate more business. I have a strick budget and want to get the most bang for my buck (as ALL do). I have read nothing but great reviews on this sub, and would be fortunate to get one within the budget that have. That is what is holding me back from a purchase on-line. I came across this opportunity to get one used and thought I would ask around so I could have a bettter frame of reference.
Old 10-04-06, 04:18 PM   #4 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Hmm...this is local right? For a RL-P 15 in relatively good condition, I would pay around $230-245, locally.
Old 10-04-06, 11:13 PM   #5 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Used is used I would pay no more then $240 shipped. Buying used speakers is scary stuff. You have to ask your self is getting a cheap speaker worth the chance of getting a dud
Old 10-05-06, 08:55 AM   #6 (Link)
Loc: Pittsburgh
User: #2639
Since: Sep 2006
Thanks for all the help...the driver is local and I am planning on seeing/hearing it this weekend. I am sure that will determine a good price point. I was looking for a point of reference which you have provided!!!
One question, It is the d-4 version. (if I decide to get it) I was planning on using the behringer 1500 which should be plenty of power, but I have read that the stability at 2 ohm's is in question. I am not sure if I should wire in parrell, series, or look for a plate amp to do the job. the oaudio 500 watt plate amp should be enough power, but is it stable at 2 ohms?
Old 10-05-06, 09:12 AM   #7 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
[quote=Mr. Lamb Fries;13483]One question, It is the d-4 version. (if I decide to get it) I was planning on using the behringer 1500 which should be plenty of power, but I have read that the stability at 2 ohm's is in question.[\QUOTE]
So d-4 means dual 4 ohm voice coils, right? If you run either side of the EP1500 to each of the two voice coils, you will have a 4 ohm load per channel, which will be fine. Or you could run them in series for an 8 ohm load, then bridge your amp. I think you'll be OK one way or another with that driver.
FWIW, I'd offer him $200. A bit low, he'll counter offer, and you'll end up somewhere south of $250.
-- Otto
Old 10-05-06, 09:47 AM   #8 (Link)
Loc: Pittsburgh
User: #2639
Since: Sep 2006
DUH!!! I hadnt thought to run in stereo (newbie alert!) I had been looking at the bridged mono specs.
Old 10-05-06, 10:49 AM   #9 (Link)
Alias: Ben
Loc: Manitoba
User: #739
Bent is offline
I'd prefer to avoid running an amp bridged, you wind up halving your damping factor and amp distortion rises as well
(or so I'm told).
Old 10-05-06, 12:12 PM   #10 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
The Ep1500 is a good match for a D4. Run each channel to a VC and you will get 800 watts.
Also you might want to read this about the D4...........
http://www.avsforum.com/avs-vb/showthread.php?t=723720
« Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter »
Mach 5 Audio
