| SoundSplinter Preferred Amp for RL-p 15Discuss Preferred Amp for RL-p 15 in the DIY Speakers and Subwoofers forum; Preferred Amp for RL-p 15 I'm at that point of indecision where I keep flip-flopping back and forth, and each day a different option seems ... |
| | #1 (Link) | |||
| Preferred Amp for RL-p 15 I'm at that point of indecision where I keep flip-flopping back and forth, and each day a different option seems the best. What I'm trying to figure out is what is the best way to amplify a killer sub? Now my current sub uses a plate amp, but it doesn't need a lot of power and wasn't a long cable run. The main benefit I see to using most plate amps is the variable phase, as I found this hugely valuable when I was setting up my sub. On the other hand, there are a lot of more conventional amps that put out serious power for very little money (especially comparatively). On the down side, you may have fan noise to deal with, and I don't think I know of one with a variable phase adjustment. Is there a specific amp that you guys like for this application, or will I eventually just have to sort out my priorities? ![]() | |||
| | #2 (Link) | |||
| Re: Preferred Amp for RL-p 15 Behringer EP2500... I've never used phase other than 180 degrees out and all you have to do is switch the leads to achieve that. Fan noise is a non issue, for $10 you can swap the stock fan out with a quiet fan that you can't hear beyond 2 feet away. | |||
| | #3 (Link) | |||
| Re: Preferred Amp for RL-p 15 Another great option for todays power hungry drivers is the Buttkicker amp. No fan, lots of power, rca input and great price. The only down side is there is only one channel. http://www.amazon.com/Buttkicker-BKA...027218?ie=UTF8 | |||
| | #4 (Link) | ||||
| Re: Preferred Amp for RL-p 15 Quote:
HK 635 Denon 1920 Onix 750 Rockets Sound Splinter RLP15 Sono | ||||
| | #8 (Link) | ||||
Both of those recomendations are assuming you are building one sub. If you are building two, then I would go for the EP2500 because of it's cost advantage. | ||||
| | #9 (Link) | ||||
. I have one, put a quiet fan in... 21db at 1 foot. Quiet enough? It only cost $10. I bought the following fan for a replacement: Panaflo FBA08A24L1A, 24V, 80x25.5, 21dB Digikey P/N P9739-ND, $8.25 All you have to do is buy the appropraite Panaflow quiet fan and swap it out. See how with my thread here: http://ibsubwoofers.proboards51.com/...ead=1145627913 or a resistor mod here: http://www.cwitt.com/epfanmodification/index.html | ||||
| | #11 (Link) | |||
| Re: Preferred Amp for RL-p 15 I can give it a whirl tonight... I didn't take "actual" measurements.. I was going off the specs. I can't hear the fan beyond 2 feet. I can barely hear it when I place my ear near it, that's all the test I really need. Did you want me to take actual measurements tonight? I doubt there will be anything beyond ambient room noise. | |||
| | #12 (Link) | ||||
brucek | ||||
| | #13 (Link) | |||||
| | #14 (Link) | |||
| Re: Preferred Amp for RL-p 15 Well, I'll tell you this, I've never heard a fan quieter than the one I have for this amp. You cannot possibly hear it at more than 2 feet away so I can't imagine it could possibly be an issue for anyone. | |||
| | #15 (Link) | |||
| Re: Preferred Amp for RL-p 15 Ok, here's the scoop. Measured with my Radio Shack SPL meter C weighting: Ambient room noise at 2 feet: wouldn't register Amp fan turned on at 2 feet: wouldn't register Amp fan turned on at 1" from opening: 54db So, if you listen to your music sitting 1" from your amp you might be in trouble otherwise you won't hear it. | |||
| | #17 (Link) | |||
| Re: Preferred Amp for RL-p 15 I was responding to SteveCallas' request of measurement at 1", I'm not sure why he is interested in that measurement either as it really has no value when testing for listening in real world circumstances as you suggested. Maybe he wants it for comparison, not sure. | |||
| | #18 (Link) | |||
| Re: Preferred Amp for RL-p 15 You can extrapolate SPL over distance based on a fixed distance. So comparing two fans both measured at 1" away makes sense. And I don't know about you guys, but my projector fan is supposed to be rated at ~22dB and that's already loud for me, and higher than the ambient room noise. I'll have to take a 1" measurement too; maybe it's not 22dB. | |||
| | #19 (Link) | |||
| Re: Preferred Amp for RL-p 15 Ah yes I remember the days of golden hearing, alas those are days of yore for me. I did hear my EP 1500 this morning when I came into the room and somebody had forgotten to shut it off. It was the only piece of equipment running with no load on it. I guess because I work in a high noise inviorment with ear plugs in that I just have tuned that noise level out. By the way what is that extrapolation formula Josuah? Cheers. | |||
| | #20 (Link) | |||
| Re: Preferred Amp for RL-p 15 So I measured my projector at 58dB@1" from the fan exhaust. The projector is rated at 25dB, which is probably at one meter. I believe the formula is -6dB/doubling of distance. So that'd be 52dB@2", and just about 25dB@1m. I sit about 1m below the projector. It was too annoying and so I built a hushbox that probably decreases the SPL by about 6dB. So I'm guessing it's around 20dB at my seat. It's okay, but I still wish it'd be quieter. | |||
| | #22 (Link) | ||||||
| | #23 (Link) | |||
| Re: Preferred Amp for RL-p 15 It's a DIY hushbox, and still has to remain open to the room because I don't have any other exhaust system. A full-fledged hushbox would do much better. I'm surprised you got equal SPL at 6' and 11' away from your sub. I can easily hear the drop off as I walk away from my sub. | |||
