| SoundSplinter IB makeover..........Discuss IB makeover.......... in the DIY Speakers and Subwoofers forum; IB makeover.......... What's nice is that if for some unexpected reason Rodny doesn't like it (which I see no reason why it ... |
Views: 13045 - Replies: 175
| | #26 | |||||
| Re: IB makeover.......... What's nice is that if for some unexpected reason Rodny doesn't like it (which I see no reason why it should happen), it's very easy to go back to the previous state. Quote:
Also, if he finds he wants to try boosting the 30-50hz range to get more punch, the additional low frequency headroom will definitely be more beneficial as it will be better equipped to keep up. | |||||
| | #27 | |||||
| Re: IB makeover.......... Quote:
| | #28 | ||||||
| | #29 | |||||
Other tactics? I'm off on a trip, I'll respond to this in 3 weeks (only to never respond to it again), proposing new, unrelated questions in a blatant attempt to get out of the hot seat, questioning the legitimacy of ground plane measurements (cause we all know testing on a 40' pole is the ONLY way to get accurate results ), inferring that an amp's metal casing determines its quality, talking about sick family members to try and gain pitty, talking about drinking martinis to try and seem "cool", talking about how much more money I have than everyone else, and so on and so forth. Each more ridiculous than the next, yet it has become common fare ![]() | |||||
| | #30 | |||||
If you made a triangle, mine are ~7' apart and the seat is ~9' back. I keep the tweeters pointed at the seats to the right and left of me rather than right at my ears. If things were ideal, I'd have no TV, center tower speaker, or equipment between them, allowing for even better soundstage and imaging. The best I can do is keep the LCD 1' back behind the front of them though. Two discrete rooms - one for stereo music listening and one for HT would be great, but I can't complain for now ![]() | |||||
| | #31 | ||||
| Re: IB makeover.......... My VRs are 9' apart and 10' from my seat and the center CH is 10.5', there is nothing between the mains, the screen is at least 2' back and they are pointing to the side of my head not my ears, I like it this way because even when you seating on the other two side chairs it sounds pretty good.I love Boston Acoustics, home and car audio!!!! I see you guys move to Sonnie's arena to ![]() Last edited by Rodny Alvarez; 04-07-07 at 11:47 PM.. | ||||
| | #32 | |||||
Back to the SLLT... The comparison is between just one IB and one SLLT.... would not the output be even more noticeable since there are TWO SLLT's and there is double the increase in ouput??? | |||||
| | #33 | |||||
brucek | |||||
| | #34 | ||||
| Re: IB makeover.......... I did advise him of this... I suggested a raw unfiltered response from the listening position and a couple of nearfield responses... say 3" and 12" (or whatever you pros deem appropriate)... for each sub type. This is a must IMO! | ||||
| | #35 | ||||||
| | #37 | |||||
| | #38 | ||||
| Re: IB makeover.......... I'm going to build one side first and compare the measurements with the ones I have now. There is nothing wrong with my IBs! when I heard Sonnies LLT, to me it sounded better, I know that Sonnies room is better build then mine(solid) he has dual 5/8 sheet rock and mine is only 1/2", some people think this is not an issue, but in my opinion it is, if the room is well insulated it will make a big difference(sound and spl) maybe I'm wrong ![]() anyway...the only way to figure this out is to build one of the SLLT When playing some movies with bass it gets real loud in the attic, you can hear it everywhere, is because the IB plays as loud in the attic then it is in the room, so I'm trying to eliminate some of that sound traveling through the attic I'm not trying to start a war between people that follow IBs and the ones the follow the LLTs some will be and some will be so by doing this, we will answer a lot of questions. Here are some measurements .......... I think this is right!! Both IBs listening position ![]() Left side IB listening position ![]() Right IB listening position ![]() Left IB Near field 12" from the sub ![]() Right IB Near field 12" from the sub ![]() | ||||
| | #39 | |||||
One on each side of the room (Line Arrays) and no additional drivers.Last edited by Rodny Alvarez; 03-15-07 at 10:57 PM.. | |||||
| | #40 | ||||
| Re: IB makeover.......... So which side are you doing first? The response from the left one looks like it would be a little easier to work with. | ||||
| | #41 | ||||
| Re: IB makeover.......... Left side first! | ||||
| | #42 | ||||||
I have a very similar situation to you. I am now running 4 RLp-15's in a manifold for an IB. Yes, the sound will now go through the attic and around the house just like you describe. (That works to my advantage cause I tell the kids to go to sleep and turn off the system at night). When I first built the IB, I got advice on the cult and was mostly told that you don't need as much power as a sealed or ported sub to get the same level. I found out that was not true. My IB with 4 drivers did not play as loud as my tube sub with 1 driver! I used to run my tube sub with 1200 watts per voice coil. I had extra amps so I put them to use and purchased another amp to bring the 4 drivers up to the equivalent of 1200 watts per voice coil. Now the IB plays much louder and sounds better than the tube. After wondering why and asking some questions, people asked about my room, so I took pictures and showed them. Sure enough, all were in agreement and said lossy room. I went, huh? Basically once a room gets to a point that it will not hold sound (not sure of the right terminology) because of windows, opening to other rooms, thin sheetrock, etc. the difference must be made up somehow. Either more drivers or more power to the existing drivers if they will handle it. I can now hit 120 db peaks in the 15 to 80 Hz range and the amps don't clip and it is very, well shall we say, enveloping. I never listen at that level but do have the capability. Have you ever thought of putting battens across your attic to slow down the annoying back sound off the drivers that your wife complains about? 3 rows of insulation hanging across the attic would knock the db down enough to be acceptable to the rest of the house and you would still get your IB. Quote:
Here is my install............. ![]() ![]() ![]() And I am still working on tuning it. Chuck | ||||||
| | #43 | ||||
| Re: IB makeover.......... I have the 10" pvc cut to 33", this thing is "BIG" and heavy , I have all the wood cut ready to be install , I don't know if I have time to finish the left side this weekend work tomorrow and going to the Atlanta aquarium on Sunday with the family .One question..... do I need to make both flares the same or can I make the front bigger then the back? is this going to affect the tuning or............ ?? | ||||
| | #44 | |||||
Ok, here it is, it's out of the Loudspeaker Design Cookbook. "Asymmetrical inlet and exhaust ports with a shallow radius on the inlet end and a larger radius on the exhaust end provide the best balance of lowering distortion and compression." | |||||
| | #45 | |||||
| | #46 | ||||
| Re: IB makeover.......... Thanks Geoff!!! I was thinking on a 1" on the inside and 2" or 3" on the outside. Here is the port .......![]() ![]() | ||||
| | #48 | |||||
| | #49 | ||||
| Re: IB makeover.......... It's funny, tubes we'd use for subwoofers a couple years ago are becoming the ports for subwoofers tomorrow... That being said, I have a couple of 12" wide X 60" long PVC tubes just lyin' around. ![]() Last edited by Bent; 03-16-07 at 11:52 PM.. Reason: I'm an idiot and can't spell | ||||
| | #50 | ||||
| Re: IB makeover.......... ****, you went for PVC? Nothing at all wrong with that, but as you commented, it's going to be significantly heavier than say 10" Sonotube. Collo's work shows that a 1.5" flare on a 10" port should keep you totally safe. I don't see any problems with having one flare larger than the other - currently my sub only has a flare on the outlet, so you should have no issues. | ||||
