| SoundSplinter IB makeover..........Discuss IB makeover.......... in the DIY Speakers and Subwoofers forum; IB makeover.......... Thanks Steve for all the help!! and thanks to every body the help with the project........positive and negative
Watched Eagles ... |
Views: 13032 - Replies: 175
| | #101 | ||||
| Re: IB makeover.......... Thanks Steve for all the help!! and thanks to every body the help with the project........positive and negative Watched Eagles DVD, Farewell 1 Live From Melbourne, all I can say is WOW the Bass is outstanding, blends very well with the mains, its not boomy just nice, clear, loud, in your face sounded bass. Played the Irene scene again..............only S#@*# ![]() Spoiler Just want to mention couple of things......... The SLLTs has two EP 2500s bridge to 4 ohm load( one on two subs). The IBs had one EP 2500 running 4 ohm stereo. I really don't know the power of the amp @ 4 ohm stereo and 4 ohm bridge When I did the testing between the IB and the SLLT they had the same power. My set up is not a ported IB is a BIG ported box. ![]() When I started the project I wasn't sure about the whole thing, but now that it is finish (almost ) if you can build a set up like this.......... DO IT!! I will not think twice to do it again!!!![]() | ||||
| | #103 | |||||
| Re: IB makeover.......... Quote:
and bridge says mono @4ohms is 2400watts single channel with 1.0% THD.... I assume you are using D4's with the coils in series and the two drivers in parallel... Tripping any breakers? brucek | |||||
| | #104 | |||||||
..........need a very large capacitor!!![]() | |||||||
| | #106 | ||||
| Re: IB makeover.......... | ||||
| | #107 | |||||
![]() Regards, Wayne | |||||
| | #108 | |||||
brucek | |||||
| | #109 | ||||
| Re: IB makeover.......... I don't think my amps will draw that much power.........the gain on my receiver is set -2 and the gains on the amps are set to 28db and still pretty loud. When we played "Irene" the volume was -10 at the receiver and the gain on the amp to 31db, felt like the whole the room it was coming down:holycow: the lights dim real bad but no breaker trip!!I was thinking to put a bigger breaker and run a bigger wire, just need to get my brother to do it ( maybe a six pack will help)....................... well after he finish the job![]() | ||||
| | #111 | ||||
| Re: IB makeover.......... That was when I had the gains at 32db! Here are my out side flares 1" 1/4 and a BIG hole in the wall!! .... | ||||
| | #112 | |||||
Qty x 2 Soundsplinter RL-P15 D4 series coils. 10" port, 35 ft long. 11.93Hz tune. 2400 watt amp. Power curve diagram.............. max power 1864 voltamps @ 12.7Hz..... ![]() brucek | |||||
| | #113 | ||||
| Re: IB makeover.......... ................. ![]() | ||||
| | #114 | ||||
| Re: IB makeover.......... Here is another sweep with the mains and few more filters................ ![]() | ||||
| | #115 | ||||
| Re: IB makeover.......... The thing is, with no low end EQ boosting and the additional headroom he's gained, he shouldn't approach anywhere near the full power of the Behringers with even the most demanding bass material. That said, taking the amps off the light circuit and giving them their own would be a good idea Can't wait to see the additional naturally flat extension when the flares are added. | ||||
| | #116 | ||||
| Re: IB makeover.......... That is just unbelievable response. | ||||
| | #117 | ||||
| Re: IB makeover.......... Rodny, LOVE IT! I have a IB with (2) SS 15's right now and plan to add (2) more once I get the time. Your setup would work out rather well in my room. I am seriouly considering doing something like yours. I hope you don't mind, but I linked to your thread and posted a few of your pics on my HT build thread over on AVS Forum. --Steve | ||||
| | #118 | |||||
Steve, your set up is really NICE, a lot of work How about some FRs ? will love to see some ![]() | |||||
| | #119 | |||||
I'm busy working on my rear sound diffuser/cabinet right now. Once I get that done, I might be able to slip in some tests to see what I'm actually getting.I'm very happy with the (2) 15" SS's I have now but once I add the 2nd pair, I think things will be outstanding. I'll be sure to post my FRs once I get them done ![]() And thanks for the kind words on the room. | |||||
| | #120 | ||||
| Re: IB makeover.......... If you do plan on porting it, you would be best served by measuring the in room FR of the IB before hand so that you'd know what tuning point would work best. | ||||
| | #121 | ||||
| Re: IB makeover.......... Thanks Steve -- will do! | ||||
| | #122 | ||||
| Re: IB makeover.......... Couple of pics of the flares...................... ![]() ![]() ![]() ![]() ![]() | ||||
| | #123 | |||||
brucek | |||||
| | #124 | |||||||
| Re: IB makeover.......... Thanks ![]() Quote:
| | #125 | ||||
| Re: IB makeover.......... It's marvellous what a coat of paint can do - they look great! ![]() | ||||
