Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > DIY Speakers | DIY Subwoofers > SoundSplinter
SoundSplinter
  Discuss Dual RL-p18 LLT begun in the DIY Speakers | DIY Subwoofers forum; Dual RL-p18 LLT begun Can you tell me how long the port is Tom? Are you using the D4 driver with the two coils ...
Views: 14198 - Replies: 110
Old 04-15-07, 12:50 PM   #41
Alias: brucek
User: #6
  brucek is offline
Re: Dual RL-p18 LLT begun
Are you using the D4 driver with the two coils in parallel?
Old 04-15-07, 12:58 PM   #42
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Thats hilarious
Old 04-15-07, 01:23 PM   #43
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
This guy is nuts.............I love it!
Old 04-15-07, 02:55 PM   #44
Alias: Tom
tjambro's Avatar
Loc: Indiana
User: #5700
Since: Jan 2007
  tjambro is offline
brucek wrote: View Post
It's an 8" diameter port 25 5/8" long, not counting the flare at the end. I used a 3/8" roundover bit for the flare. I was shooting for an effective volume of 550L with a 14.5Hz tuning. Unibox said the port should be 25.94" long. I'm probably gonna be just under 550L by the time it's all done.
Yes, one D4 driver with dual coils in each box running in parallel. Each driver should see 900 watts per channel into 2 ohms with my Carvin HD1800.
-Tom A.
Old 04-15-07, 02:57 PM   #45
Alias: Tom
tjambro's Avatar
Loc: Indiana
User: #5700
Since: Jan 2007
  tjambro is offline
Rodny Alvarez wrote: View Post
I hope your back still in one piece!
Let's just say I won't be getting in the boxes anymore!
-Tom A.
Old 04-15-07, 03:08 PM   #46
Alias: Tom
tjambro's Avatar
Loc: Indiana
User: #5700
Since: Jan 2007
  tjambro is offline
SteveCallas wrote: View Post
Coming from a guy who thinks a couple of 6.5' tall obelisks in the middle of his den which happens to be in an apartment is not enough, I feel like I am among family.
-Tom A.
Old 04-15-07, 04:03 PM   #47
Alias: brucek
User: #6
  brucek is offline
Yeah, I guess the SoundSplinter site show the Re and BL for series coils, so I had to use the trick with WINISD to calculate them when in parallel.
WINISD shows the 8" port at 27.5" inches with one end flared in a 545 liter box tuned at 14.5Hz.
It looks real good at least to my novice playing around. The experts could comment.
Here's SPL of one box with 900 watts applied with a 10Hz, 1st order highpass filter to account for the electronics dropoff down low and a single BFD filter at 48Hz with a cut of -6dB with a Q of 0.7
I guess room gain comes into play and maybe the BFD filter would be less (or none).
SPL
Here's the cone excursion at full power. The Xmax is 27.4, so that looks good to me. It's shows only a bit out of the linear range at full power. The graph goes below Xmax just above 500 watts. That seems good.
EXCURSION @ full power
The velocity exceeds the 5% of speed of sound (~17m/sec) when full power is applied which I'm told is into the chuffing range. But who runs full power. At 500 watts it's about 19 m/sec
VELOCITY
And of course you have two of these monster.
Here's a tip: Don't sit in it when playing full power.
Old 04-15-07, 06:48 PM   #48
Alias: Tom
tjambro's Avatar
Loc: Indiana
User: #5700
Since: Jan 2007
  tjambro is offline
I haven't messed with WINISD much. If it's not too much trouble, can you tell me what tuning I can expect with a 26" port assuming the same 545L?
I don't have a BFD yet. I plan on running it without at first and then pick one up if absolutely necessary. I guess I need to get REW installed so I can measure, huh? I plan on doing a FR on my current pair of Def Tech 2002 (each one has a built in 12" sub) just for kicks. I'm sure the SS's will dig much deeper.
Excellent advice!
-Tom A.
Old 04-15-07, 08:24 PM   #49
Alias: brucek
User: #6
  brucek is offline
>>>> 14.83Hz at 26" with a 8" port with one end flared at 545L.
Old 04-15-07, 09:03 PM   #50
Alias: Tom
tjambro's Avatar
Loc: Indiana
User: #5700
Since: Jan 2007
  tjambro is offline
Thanks, I can probably live with that.
-Tom A.
« Home Theater Shack > DIY Speakers | DIY Subwoofers > SoundSplinter »
Bookmark and Share
Dish Network
