| SoundSplinter 8-10Hz LLT with a pair of RL-p18'sDiscuss 8-10Hz LLT with a pair of RL-p18's in the DIY Speakers and Subwoofers forum; 8-10Hz LLT with a pair of RL-p18's Well, this seems like a pretty good place to make my first post. I was directed to this forum from ... |
Views: 1132 - Replies: 22
| 8-10Hz LLT with a pair of RL-p18's Well, this seems like a pretty good place to make my first post. I was directed to this forum from another after inquiring about the construction of a sub-subwoofer. I read about the LLT designs, and decided that a pair of the Soundsplinter RL-p18's in a really big box would do the trick nicely. I'm currently designing in 3d Autocad the addition to our home in Dallas, and, of course, it will have a dedicated theater room. The LLT will serve a second purpose as a raised structural platform for the second row seating. I reckon on a couple dozen cubic feet within. I have in my possession an eager Crown Macrotech 1200 that would like to take it to those big 18's. The sub-sub will actually take over the lowest end from my pair of Polk PSW 1200's which I will cut off at 28 Hz. I'd like to tune the LLT for 8-10 Hz. From the specs on the Soundsplinters, I think I should be some pretty high SPL's that I'll hear mostly with my bones! Thanks to the Shacksters for providing this forum. I plan to be around here a lot and will post updates on the design/construction of my dream theater. | ||||
| | #2 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's Hey Chris!!! welcome to the SHACK How many watts on the amp?? Steve is going to love this, single digits tune , my LLT is tune to 11Hz two 15" RL-ps 35cft its BIG!! and I have to build the other side , two EP 2500 bridge .You need to check Sonnie's LLT....... http://www.hometheatershack.com/foru...b-project.html Spoiler | ||||
| | #3 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's Thanks for the welcome, Rodny! The Crown is conservatively rated at 495 WPC at 4 ohms, and 700 wpc at 2 ohms. I guess I'll run the Soundsplinters in parallel (I assume they are 4 ohm nominal drivers) to get the 2 ohm load (I just want OUTPUT from 28 Hz on down). Here's the specs: http://www.gbaudio.co.uk/data/ma1200.htm I am pulling the plate amps out of my PSW 1200's, selling them, and using a Hafler P-7000 to drive them in stereo. I'll have one behind each LS50. The Hafler is rated at 350 wpc at 8 ohms, which is how I'll run it, to maintain lower distortion levels in the 28 to 80 Hz range it will be responsible for. Looking at the truck in your avatar, I'd bet that you'd appreciate my second ride: a lght metallic blue 84 Chevy Silverado 4x4. I'll have to post a pic of that sometime... | ||||
| | #4 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's Spoiler Yeah... I would definitely say Chris deserves his very own thread for this discussion. Hi Chris and welcome to the Shack! 8-10Hz LLT... that will be awesome indeed... ![]() You've found the right spot and we'll certainly be looking forward to seeing some pics and following your progress. | ||||
| | #5 | |||||
| Re: 8-10Hz LLT with a pair of RL-p18's Quote:
brucek | |||||
| | #6 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's I'm gonna suggest (I'd bet, but I won't gamble even for a cola) that after hearing the LLT, there will quite possibly be no PSW1200's in the picture anymore. The CX2310 could do the job. | ||||
| | #7 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's Spoiler ![]() I'm not an expert but you probable need another amp, so you can run one amp on each sub, using the 4ohm dual voice coil parallel for 2ohm load 700watts on each sub My truck is a 96, a lot of and time Spoiler | ||||
| | #8 | |||||
As for the subs, I don't see much benefit tuning lower than 10hz, and even that is extremely low (I'd personally shoot for a wee bit higher tuning myself). The best bet would be something like Rodny's project, enclosing an adjacent space, because these drivers like a LOT of volume for a LLT. Let me know if that is an option or if these have to be discrete boxes o tubes within the room. | |||||
| | #9 | |||||
As far as smoothness, the SMS-1 could easily take care of that. | |||||
| | #10 | |||||
BTW, in case anyone googles the SMS-1, the software update lets you defeat the subsonic filter for a response down to 5 Hz. Bass eq still is restricted to 15 Hz, but after that, I figure you just take whatever you can get! ETA: Thanks for giving me my own thread! The reason I took so long to respond is that I was no longer updated via email after the thread was moved. Sorry if that appeared rude. Last edited by Chris in Dallas; 04-06-07 at 07:37 PM.. Reason: Forgot to be polite | |||||
| | #11 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's Oh yes, I thought about just letting the one big super-sub do the job, but I really like having dual subs with my mains in the audible range, and I like having them right up front where they are needed. I've found that down to about 40 Hz, a single sub placed anywhere else is distracting; it draws the ear toward that area, especially if it is placed beside just one of the front speakers. But maybe I'm just imagining things. | ||||
| | #12 | |||||
I suppose I could also just put all my rack gear in the plinth, and build a stage in the front that could contain the mondo sub, and then I wouldn't mind letting it run clear up to 80 Hz like you say. I could even use a pair of the 18's down low on each side of the stage... Then I could sell the PSW-1200's and use that for financing the SS stuff. Hmm... | |||||
| | #13 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's I think the Crown should be adequate. The 18's suggesting power supply is 500-1000 watts, and if I use two of them in the 4 Hz model, in parallel (2 ohm load) the Crown pushes 700 wpc. My theater will only be about 14' x 19.5', so I figure that should do the job. Correct me if there is something out of whack about my figurin', please. | ||||
| | #14 | |||||
| | #15 | ||||||
Sorry about the thread thingy... I thought it would notify you. I guess I need to start posting my response first so that it will notify you and then moving the thread/post, etc. Then it would redirect you. Quote:
| | #16 | ||||||
| | #18 | |||||
http://www.polkaudio.com/homeaudio/products/psw1200/ | |||||
| | #19 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's There's only so much I can try to convince you without just letting you hear the final results yourself and then choosing to ditch the Polks, so I'll give up on that front for now If going for a very low tuned LLT using 18" drivers, you will definitely NOT want to use the Velo SMS, as even with the 5hz highpass the response is down considerably at 15hz and even more at 10hz. It's not well suited to such a project, it's better used for something like the Polks which don't have any real low end. And I'm not saying this to be a jerk or sound arrogant or anything like that, I'm just being a straight shooter in order to help you achieve what you really want. As for discrete enclosures, I'd be looking at ~650 effective liters and a 13hz tune using an 8" diameter port with 800-1000 watts. SS's recommendations are for more "traditional" ported subs, and won't give you the linearity into the low teens I'm pretty sure you desire. | ||||
| | #20 | |||||
ETA: And you don't sound at all like a jerk, just like someone with good knowledge giving straightforward and welcome advice. ETAA: I see the Re on the dual 4 ohm model is 6.26 ohm, so I guess that makes it an 8 ohm driver, nes pas? I'm going to find one of those calculator thingies and plug those numbers in and get back. Last edited by Chris in Dallas; 04-07-07 at 04:37 PM.. Reason: 'cause | |||||
| | #21 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's I downloaded Unibox, and have been toying with it. I tried an 18 cft box with a 10" Schedule 80 PVC pipe (really thick walls would limit resonance and would allow carving a flare of sorts). Some of the parameters I didn't know, and left as the numbers that came with the program. This setup delivers a nice graph that delivers nicely to 12 Hz, and drops 2 dB from 12 to 10 at 980 watts. Single driver, btw. Soundsplinter RL-p18 8 ohm Fs 21.50 Hz Re 6.26 Ohm Qms 4.50 Qes 0.55 Sd 1188.0 cm2 Vas 276.0 l Xmax peak 27.40 mm (Le) 4.34 mH (Le2) 0.00 mH (Re2) 0.00 Ohm Nominal Power 980.0 W I left the following as they were: Rs 0.20 Ohm (Lco1) 0.00 mH (Rco1) 0.00 Ohm (Cco1) 0.00 uF (Lco2) 0.00 mH (Rco2) 0.00 Ohm (Cco2) 0.00 uF Vented Box Port No of ports 1 Inside port dia. 24.29 cm Port area 463.39 cm2 Port end correction 0.732 (I have no idea about this one) Design by Vb, Fb and Q Physical Vb 500.0 l Absorption, Qa 80 Leakage, Ql 15 Port, Qp 80 Alpha, a 0.543 Vb 508.7 l Fb 12.00 Hz F3 23.33 Hz Response peak 0.00 dB Peak at none Port min dia. 23.39 cm Port length 172.93 cm Port 1. resonance 95 Hz What do you think of my first run? ETA: My excursion maxes out at 10.9 Hz, then proceeds through the roof. Hmm, is 10.9 Hz low enough? Last edited by Chris in Dallas; 04-07-07 at 09:20 PM.. Reason: mas info | ||||
| | #22 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's and....I'm right about where Steve Callas is. The best solution is a 6.5' long 24" Sonotube with an 10" schedule 80 pvc port, 68" long. On its side, that could go right behind the second row seating. The problem I'm having with the 8" tube is the velocities get too high down low, and I have to bump it up to 10". How hard and fast is that rule for clearance around the port? | ||||
| | #23 | ||||
| Re: 8-10Hz LLT with a pair of RL-p18's A 68" long port will very likely create audible resonances, I'd try to go no longer than 36". An 8" port should be able to handle the air movement of such a project without any problems in a ~650 liter enclosure with a tuning in the ~13hz range. And that would require 28" diameter tube that is about 70" tall, 24" tube won't be large enough. The enclosure and power recommendations were for a single driver. I'd go with 700 watts x 2 at 2ohms if possible with that amp. For more potential wiring configurations, don't forget they also have a dual 2 ohm version. | ||||
