Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > SoundSplinter
SoundSplinter
Dual RL-P18 LLT for my 2000 cu ft HT soon
Discuss Dual RL-P18 LLT for my 2000 cu ft HT soon in the DIY Speakers and Subwoofers forum; Dual RL-P18 LLT for my 2000 cu ft HT soon blaser wrote: I have received and connected my new 2 KW amp. The subs are now connected/wired 8 ohms briged. ...
SoundSplinter
Views: 10321 - Replies: 182
Old 10-12-07, 06:31 PM   #176
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Re: Dual RL-P18 LLT for my 2000 cu ft HT soon
blaser wrote: View Post
I have disconnected the fans but did not like the amps heating. So I decided to reconnect these fans.
When I opened the amp top cover to disconnect the fans, I was chocked when I saw the huge power supply as well as 8 * 10000 uF * 80V capacitors... (I don't know if this is big in the pro amps world though....what about the EP-2500 for ex.?? any ideas...
The EP2500 has eight 12000 uF caps.
http://home.pacbell.net/lordpk/proam...r_EP2500-1.jpg
- Running the amps 2 ohm briged, knowing that the amps will never be "a hair" hot when the 4 (variable speed) fans are running.
You can try it for sure. If you feel that 2 ohm bridged sounds better than 8 ohm bridged, use it.
- Having the subs configured as a single 4 ohms sub, then feeding this 4 ohm terminal with both amps in parallele. What is the possibility of such a configuration if of course the amps are both at exactly the same output level (max for ex) and fed with the same split signal from the receiver.
That would be same as 8 ohm bridged (power wise). But the output level isn't necessarily exactly the same even though both gains are maxed out. So therefore I would use bridged instead.
Old 10-12-07, 06:52 PM   #177
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Ilkka wrote: View Post
Well, I know these amps are very similar, while the EP-2500 has a bit more caps, the power supply of the T-amp is slightly larger. Thanks for the info!
I will try for sure...You know that I like playing with my toys
I sure believe you but why?
Why?
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 10-12-07, 07:26 PM   #178
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
http://en.wikipedia.org/wiki/Bridged_amplifier
Because when connected in bridge, each amplifier sees half the load impedance. So 4 ohm stereo/parallel is same as 8 ohm bridged.
Why?
Because they are analogue attenuators, not necessarily very accurate. When connected in bridge, it isn't a problem because only channel A gain is active.
Old 10-15-07, 06:08 PM   #179
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Ilkka,
You were correct with your expectations... Running the amps at 2 ohm bridged didn't add a thing at all. It is about the same power as amps bridged 8 ohms (not a single db gain), but I didn't like the sound of the 2 ohm configuation... With some exageration I would say to my ears I felt the sound was a bit boomy and not as tight as the 8 ohm configuration.
Appearently, (as you told me before), this is the capability of the power supply, it will propably not exceed 2000W by much be it 8, 4 or 2 ohms
And therefore, I am just happy to have followed your advice and added to my equipment rack another amp
ASME AI
Old 01-07-08, 06:55 PM   #180
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Hey Steve!
I decided to upgrade the display. I have been looking around and I found a 50" Viera Panny (Th-50PV70) middle-East10th generation model. It has a very good PQ, it is a 1366*768, but will accept 1080p (has a 1080P processing chip).
I am dreaming of having it at home, but I am afraid I will have to wait about 2-3 months...
Well, I changed my mind. I wanna enter the BIG PICTURE WORLD. I am now about to order a 102" Carada BW screen:raped: and the new Epson TW-2000...Just waiting for some more reviews of it.
ASME AI
Old 01-12-08, 11:44 AM   #181
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
  Bradley is offline
DO IT!
Go as big as you can on the screen, too. I run a 110" fixed frame screen (VuTec) but if I had to do over again would go a little bigger (as much as to 150"). I could never go back to those silly "little" screens.
That projector is getting good reviews so far. It sells in the U.S. as the Epson PowerLite Home Cinema 1080 UB for about $2,699.
Old 01-13-08, 12:23 AM   #182
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Thanks Bradley...what's your watching distance? I have opened a thread in the home theater design and construction area...check this http://www.hometheatershack.com/foru...html#post73086
ASME AI
Old 02-08-08, 08:45 PM   #183
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Cool Re: Dual RL-P18 LLT for my 2000 cu ft HT soon
SteveCallas wrote: View Post
Very nice work, I bet those things can give you a massage in that room! Please tell me the next planned upgrade is the tv though
Steve... Check this!
http://www.hometheatershack.com/foru...ld-thread.html
ASME AI
« Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter »
