Car Stereo to Home Theater (Ported Box Plans Needed) I have pics - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > SoundSplinter
SoundSplinter
Discuss Car Stereo to Home Theater (Ported Box Plans Needed) I have pics in the DIY Speakers and Subwoofers forum; Car Stereo to Home Theater (Ported Box Plans Needed) I have pics Well the topic pretty much sums it up. After having (2) RL-P 12" in a car for several years I ...
SoundSplinter
Old 06-12-07, 05:01 PM   #1 (Link)
New Member
Alias: SmoothBass
User: #9536
Since: Jun 2007
Shinisa is offline
Well the topic pretty much sums it up. After having (2) RL-P 12" in a car for several years I have decided to put the subs inside the house. This frees up the space restrictions, and I have been enticed to build a ported box. So with all the experience most of you guys have on this board, I would appreciate some feedback or advice on building a ported box.
Here is some info about what i got/need
-I listen to mainly rap/R&B
-Would like a strong balance between Home Theatre Use and Music listening
-I will be using a EP2500 Amplifier (This gives me 500 watts if I run it at 8 ohms or 1200 watts if i choose to run it at 2 ohm) I would prefer to run it off 8 ohms and rely on a damm good box instead of power to extract everthing the sub has got.
-Relatively large room
-Slot port preferred
Let me know if there is anything else I haven't listed. I have been fumbling around with WINISD, but I'm embarrassed to admit I'm having trouble trying to get it working properly.
Old 06-12-07, 05:05 PM   #2 (Link)
New Member
Alias: SmoothBass
User: #9536
Since: Jun 2007
Shinisa is offline
Re: Going from Car Stero To Home Theatre (Ported Box Plans Needed), I also have pics
As promised here are the pics of the old set-up. It was in a Subaru Impreza with about 1.2^3 ft per sub. (Not nearly as much as I wanted but small trunk size prevented anything bigger. The frontstage are CDT Audio HD series powered by A US-Amps 600X. 2 RL-P's powered by a US AMP DE-1000
See the DE hiding in the spare tire well?
Old 06-12-07, 09:31 PM   #3 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
The RL-P12 Is a hard one to do ported. The problem is that it wants to see such a small box that its hard to fit a port in there. But playing around with Winisd, If you did two enclosures each with 3.5 cubic feet (net) with a 4" port tuned to 16hz fed with 450w each (The Ep2500 20hz-20kh rating at 8ohms) it does not look to bad. Im getting 113db at 17hz and about 117.7db at 80hz. The air velocity in the port should not be too bad since its just a few ms faster than my RL-P15 LLT and I have had no problem with mine. Now this is with two of these side by side or stacked on top of each other so you can take advantage of the 6db of gain from having two. Plus room gain will add a few more decibels. But do remember that these drivers are not the best choice for HT subs, But this design is not too bad at all.
Old 06-12-07, 09:33 PM   #4 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Do you have the D2 or the D4s?
Old 06-12-07, 09:43 PM   #5 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Re: Car Stereo to Home Theater (Ported Box Plans Needed) I have pics
Im guessing he has the D4 if he was going to try to get 500w from his Ep2500 in 8ohms.
Old 06-12-07, 09:53 PM   #6 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Jerm357 wrote: View Post
Aye, that occurred to me.
Old 06-12-07, 11:07 PM   #7 (Link)
New Member
Alias: SmoothBass
User: #9536
Since: Jun 2007
Shinisa is offline
yeah that DVC 4Ohm. If going ported is that much of a hassle, i wonder if giving it the full 2 Cubic feet will give me better sound quality vs the 1.2 its sitting at now. Is going ported really that much of a constraint on this subwoofer
Old 06-13-07, 12:16 PM   #8 (Link)
Alias: Brian
Loc: Oklahoma City
User: #5872
Since: Jan 2007
bonehead848 is offline
it shouldnt be, just make sure you plan carefully and it should be fine. Something else you could consider is making the ports outside the box, its usually not as pretty but maybe you could think something up. If you are wanting the extension of a ported box, as i would, then you can definitely find a way
Old 07-28-07, 03:29 AM   #9 (Link)
Alias: Adam
User: #10497
Since: Jul 2007
adamt is offline
I couldn't help but to revive this thread with a little graphic depiction of the last statement.
This is an online acquaintance's box for 2 10" RF subs in a hatch back. The box was known as frankenport. I thought it was trendy
Old 07-29-07, 12:26 PM   #10 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
:holycow: What's that???
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 07-29-07, 03:57 PM   #11 (Link)
Alias: Adam
User: #10497
Since: Jul 2007
adamt is offline
This guy can definitely build a sub enclosure
« Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter »
Similar Threads
DIY car stereo install? basementjack DIY Subwoofers 5 01-26-07 10:36 PM
How hard to install a Car stereo in a Honda odyssey? basementjack Chat Box 4 01-26-07 05:07 PM
Need advise on how to put plans and photos onto home theater construction ???? alan monro Home Theater Design and Construction 2 01-09-07 09:12 PM
Yamaha Bows New One-Box Surround System (YSP-1100) and Home Theater Receiver (RX-V2700) Chris Boylan Home Theater, Audio and Video News 0 10-01-06 12:25 AM
Sharp @ CEDIA - Blu-ray home theater in a box - BD-MPC10 HDBeat Home Theater, Audio and Video News 0 09-14-06 03:40 PM
Mach 5 Audio
