| SoundSplinter RL-p18 Sonotube thoughts...Discuss RL-p18 Sonotube thoughts... in the DIY Speakers and Subwoofers forum; RL-p18 Sonotube thoughts... Thanks again! Wow I just saw you home & car equiptment list.
Talk about rock'in the Kaspar!... |
| | #27 (Link) | |||
| Re: RL-p18 Sonotube thoughts... I'll just second or third to go with the D2s. A single EP2500 should be fine for now, as dual 18" LLTs being fed with only 100 watts a piece for instance would still be PLENTY powerful. If you do then ever go to dual P2500s, you'll have even more headroom on tap, though hypothetically, you may not even need it ![]() This "Brotherhood of Bass" group as I once referred to it has achieved global expansion pretty quickly. Phase III of my plan will be the....ehh, too soon ![]() | |||
| | #28 (Link) | |||
| Re: RL-p18 Sonotube thoughts... Hmmm, well in that case I've got this http://www.belcantodesign.com/prod_evo4.html hanging around not earning its keep, so maybe I'll start off with it for the test run. What do you think? | |||
| | #29 (Link) | |||
| Re: RL-p18 Sonotube thoughts... OK, just ordered my router... always wanted an excuse to get one. So, what size/type bits do I need for MDF and the SonoTube? Oh yeah, and who makes that really nice circle jig? | |||
| | #30 (Link) | |||
| Re: RL-p18 Sonotube thoughts... Should have put here, so I will.... I looked at the SS 18" as an LLT and shelf was only down 4dB from reference. Could pertain to Rl-p, also. Isn't that too high considering room gain? Is there an accepted shelf goal? My PA P.Audio 18" shelf is -15dB from reference and -10dB with respect to 80hz. I suggest everyone read or re-read your initial LLT post. http://www.hometheatershack.com/foru...explained.html BTW, thanks for personal help, Steve. Saved me from getting kicked out of the house having two subs. Zene Last edited by Zene; 07-31-07 at 06:11 AM. Reason: Added name | |||
| | #31 (Link) | ||||
| Re: RL-p18 Sonotube thoughts... Quote:
I guess it was a bit for me to absorb in all the excitement of planning my build. Ahh, its sinking in now. I had the parallel series thing wrong in my head. Went on an "electrical explained" website with illustrations... now I've got it -Thanks again | ||||
| | #32 (Link) | |||
| Re: RL-p18 Sonotube thoughts... If you have a current sub, measure it close mic'ed and then again at your seat - the difference in gain, ignoring peaks and nulls, is the room gain. You can determine an ideal tuning for yor LLT based on that ![]() | |||
| | #33 (Link) | |||
| Re: RL-p18 Sonotube thoughts... Well, right now I only have the four 7" woofers in my B&W 605's fed by the two 130W plate amps. Do they count? I have a sub demo disk and can get an RatShack spl meter. Is that how you do it? | |||
| | #34 (Link) | ||||
You will need to get REW working though, because you'll require it to set up an EQ when you're done the sub. brucek | ||||
| | #35 (Link) | ||||
ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #37 (Link) | |||
| Re: RL-p18 Sonotube thoughts... well well well do not underestinate the power of tuning and box volume...Also there are 4 of them... But I don't know... here is a simple room gain similation program...it works pretty accurate with my room.ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #38 (Link) | |||||
brucek | |||||
| | #39 (Link) | |||
| Re: RL-p18 Sonotube thoughts... Well Bruce if you insist,I am not talking specially of the drivers above (I don't know them) but 15Hz is reachable by a 7" driver or even smaller (driver parameters will vary from a driver to another depending on which will be how good the driver will produce 15 Hz signal, and not its size). 4 * 7" will have about 36% more cone area compared to a single 12" driver, and if all other parameters are equal, and if the 4* 7" drivers are suitably ported or "LLTed" they will basically put some serious 15 Hz signal. But again I don't know about the case of this thread ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review Last edited by Blaser; 08-02-07 at 04:21 PM. Reason: correction 36% more cone area instead of 50% | |||
| | #41 (Link) | |||
| Re: RL-p18 Sonotube thoughts... therefore you have to follow the precious advice of Brucek ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #42 (Link) | |||
| Re: RL-p18 Sonotube thoughts... Let's try this ... isobaric (clam shelled) PL-p 18's in Sonotube LLT. 1/2 the size and all the benefits of coupling, guessing around 200 L. Only a 4" port required. Four of these in a room though rather silly for us cheapies would certainly smooth things out. 200 watts could get the job done? Zene | |||
| | #43 (Link) | |||
| Re: RL-p18 Sonotube thoughts... Just wanted to put my two cents in on the choosing between the d2 and the d4, because this comes up alot. I think it all depends on how many drivers you are going to run. My rule of thumb is to always get a 4 ohm load and run the amp(s) in bridged mono for max output,(as long as the amp you choose can run bridged mono) So, one driver, buy the D2, two drivers buy the D4. I.E. witht the D4 you would wire the coils in series for 8 ohms, and then run the two drivers in parrallel for a 4 ohm overall load. Connect to the amp in bridged mono for maximum output from the amp. With an EP2500 it would be approx. 2000 watts. | |||
| | #44 (Link) | ||||
I do see what you mean though. My plan (today) is to go D2 and wire the Vcoils in series and use my Bel Canto bridged mono (600W@4ohms) to start. If I do the second Sono I'll probably get the EP2500 and run it 2 channel, so the D2's will still be the way to go. (right?) | ||||
| | #45 (Link) | ||||
If you are sure you are going to eventually have 2 drivers, get the D4's. You can run the Bel Canto bridged into 8 ohms, until you get your second driver. | ||||
| | #46 (Link) | ||||
http://www.stereotimes.com/amp100702.shtml http://www.belcantodesign.com/prod_evospecs.html | ||||
| | #47 (Link) | ||||
| | #48 (Link) | ||||
only has one balanced sub output. Do I just get a one to two splitter from say Guitar Center to get the LFE to both sides of the amp, or do I just run the single ended sub1, sub2 outputs? I'd rather run the balanced output with its greater signal strength so as to not have to run the amp quite as hard. | ||||
