Doing a RL-p15 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > SoundSplinter
SoundSplinter
Doing a RL-p15
Discuss Doing a RL-p15 in the DIY Speakers and Subwoofers forum; Doing a RL-p15 I am getting ready to do a sub-woofer for my home theater. I've pretty much decided on the Sound Splinter ...
SoundSplinter
Old 07-28-07, 03:00 AM   #1 (Link)
Alias: Adam
User: #10497
Since: Jul 2007
adamt is offline
Doing a RL-p15
I am getting ready to do a sub-woofer for my home theater. I've pretty much decided on the Sound Splinter RL-p15 in a 2' cube sealed enclosure. I leaning towards the behringer 2500 despite their questionable reputation in the music instrument world.
My budget is 800 bucks for the whole gig, amp, enclosure, driver, which means I'll probably spend 1200 before it's all said and done.
I am looking for a reputable cabinet builder that has experience with this type of enclosure and can build it with little or no input from myself on specifics. Can anybody give me some leads? I don't mind paying the shipping as I just had a sub box for my truck built and shipped from Canada. I'm looking for optimal conditions so any input on box design would be great. I'd like to stick with the 2' cube but I'm lenient on size in order to achieve the best sound I can get from the enclosure.
I am running a Yamaha RX-v2600 pre/pro and am curious as to how I should go about connecting the amp to the receiver. I am also unsure of amping the driver with the two voice coils and what impedence to shoot for. Looking for some general ideas of how I should go about getting this thing up and running once I get it all together. I'm pretty much a newbie so any input will be greatly appreciated.
Adam
Old 07-29-07, 03:11 PM   #2 (Link)
Alias: Adam
User: #10497
Since: Jul 2007
adamt is offline
Re: Doing a RL-p15
Okay, I've been doing some reading and I'm feeling a bit embarrassed for wanting to do a sealed eclosure. I think I have enough space for a ported or sonotube enclosure.
I found the sonotube calculator and I'm feeling somewhat confident that I can pull off building a sonosub. We use to use sonotube for pouring concrete pillars when I was building metal buildings a couple of years ago.
I have some more questions about this sonosub stuff. It seems like this page is geared more towards the pros so I'm feeling a bit left out. I have ADD real bad so searching has led me off on quite a few wild goose chases. I must say I have learned quite abit from searching but I still have a ton of questions. I was hoping to find more information before I went ahead and laid them out but I'm more lost then found so I'm firing away.
1.Where do you get the larger sonotube? I'm pretty sure they don't carry the larger sizes at the local home depot or lowes.
2. How do you secure the round inserts to the sonotube? If I remember right that stuff is basically a composite cardboard like material. Construction Adhesive-Strap Clamp?
3. Are there any baby step walkthrough guides to building a sonosub? I haven't really found too many pictures that show the guts of one of these things. I have access to PVC of just about every diameter imaginable so getting the port material should be fairly easy and very cheap.
Anyways, my best intuition says to follow Sound Splinter's optimal recomendations on their website. The RL-p15 recommended vented enclosure volume is 10cubic feet. That's roughly an 18" sonotube 6' tall. I think I can manage that space wise. I have a copy of winisd at home and I can figure port length and diameter to get the fb of 14.5hz they reccomend.
Am I missing anything here. Please somebody throw me some pointers and what not to help me get on my way.
Thanks again
Adam
Old 07-29-07, 05:53 PM   #3 (Link)
Alias: Adam
User: #10497
Since: Jul 2007
adamt is offline
Re: Doing a RL-p15
What did they quote you for shipping? I have a guy that can build the box, but like I said before he is in canada. He does some really nice work but is mostly in the car audio world. I'm trying to keep as many options open as I can at this point.
I have recently started leaning towards the sonotube design because it puts the volume in a vertical location and doesn't take up as much floor space as a larger enclosure would. Cosmetics aren't as important as function.
Where do I buy sonotube if I decide to go that route? I've been looking on the net but haven't found much yet.
Edit: I think I am going to go with a crown xls402 for power
Old 07-29-07, 09:32 PM   #4 (Link)
Alias: Adam
User: #10497
Since: Jul 2007
adamt is offline
Re: Doing a RL-p15
Thanks for replying, I appreciate the input. I will check out the cost of some sonotube tomorrow at a couple of the building supply joints in town. I'm pretty sure I'm going to go this route at this point.
Old 07-31-07, 01:00 AM   #5 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Re: Doing a RL-p15
Look up "concrete" or "concrete forms" in the ywllo pages and make some calls. Someone will point you in the right direction pretty quickly. For the RL-p15, you'd ideally want 22" diameter tube - aim for ~290 raw liters.
If you measure precisely and have good tolerances, you will have to force the end caps in place - with a lot of force. The resulting fit will be air tight and all you'll need is a ring of caulk on the inside seams.
This one is old and uses flush fit endcaps (which I don't care for), but it has lots of costruction pictures. Sonosubs are really pretty easy, no need to be intimidated.
Nah. That's not geared for home use in my opinion. The design that has become the standard for the RL-p15 is effective 260 liters with a 6" diameter port that is ~30" long. Do some searching, it has proven itself well
Forum groupthink is a powerful thing, and certainly ports have their advantages, but I'd never under any circumstances recommend that someone who can't measure the exact drivers that will be used do anything but a simple sealed box. Drivers vary so much (even good lines) that a vented box will basically never turn out as the graphs predict.
Funny you say that, as Ilkka just finished testing a TC 2k LLT and it measured virtually identical to the simulations. It also has a large performance advantage over the same driver in a sealed enclosure.
Old 07-31-07, 10:05 AM   #6 (Link)
Alias: Adam
User: #10497
Since: Jul 2007
adamt is offline
Re: Doing a RL-p15
Thanks Steve. As I mentioned in my "build" thread, I may be getting boneheads RL-p15 sub. He is somewhat close to me and I think he did a really good job on his build. We will see in the coming weeks how that goes.
Old 08-01-07, 04:24 AM   #7 (Link)
Alias: Adam
User: #10497
Since: Jul 2007
adamt is offline
Re: Doing a RL-p15
Just out of curiosity how much power are you guys throwing at these rlp15? I've read that the large vented enclosures will do better with less power in comparison with a smaller sealed enclosure.
Old 08-01-07, 08:29 PM   #8 (Link)
Alias: Steve
User: #263
Re: Doing a RL-p15
Right, as you get much higher low end sensitivity. Seeing as my views on power have changed quite a bit after this latest round of testing by Ilkka, I'd shoot for 1000-2000 watts.
Old 08-01-07, 10:08 PM   #9 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Re: Doing a RL-p15
Im using bridged Behringer EP1500 on my large ported RL-P15 with great results.
« Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter »
Similar Threads
RL-p15 in optimum enclosure Mongrel714 SoundSplinter 15 07-16-08 08:27 AM
How are you using your RL-p15? JorgenMan SoundSplinter 20 01-26-08 12:27 AM
Dual RL-p15 D2 LLT Sub Project... Sonnie SoundSplinter 172 06-06-07 02:52 AM
RL-p15 LLT Sonosubs Geoff St. Germain SoundSplinter 16 04-12-07 05:29 PM
Whats your favorite tune for an RL-P15? Jerm357 SoundSplinter 13 03-07-07 12:11 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
