| SoundSplinter Doublecheck my calcs...RLP18 SonosubDiscuss Doublecheck my calcs...RLP18 Sonosub in the DIY Speakers and Subwoofers forum; Doublecheck my calcs...RLP18 Sonosub 2 Questions
1) Would someone more expereienced please check my measurements before I pull the trigger...
RLP 18, 650 liters....28 ... |
| | #1 (Link) | |||
| Doublecheck my calcs...RLP18 Sonosub 2 Questions 1) Would someone more expereienced please check my measurements before I pull the trigger... RLP 18, 650 liters....28 inch diameter x 70 inches tall Tuned to 13hz..... 8 inch port x 29 inches 2) How long should I cut the dowels? (ie distance between driver and baseplate). thanks | |||
| | #2 (Link) | |||
| Re: Doublecheck my calcs...RLP18 Sonosub I'd go with at least 5" legs - I went with 8" ![]() The design looks solid, though in real life I don't think it will take a 29" long port to get a 13hz tune. I know the simulations may say that, but my own port is something like 24" long in a 70" tall, 28" diameter tube, and my tuning came out to be ~13hz. As has been said elsewhere though, it's much easier to trim down a port then add to it, so I'd start with 29". | |||
| | #3 (Link) | ||||
| Re: Doublecheck my calcs...RLP18 Sonosub Quote:
| | #4 (Link) | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Is a baseplate necessary for a sonosub? | Mattlock | DIY Subwoofers - Sealed and Ported | 5 | 11-29-07 09:45 AM |
| sonosub software | scott | DIY Subwoofers | 8 | 09-14-07 04:48 PM |
| Decided: sonosub, Help! | lvisneau | DIY Subwoofers - Sealed and Ported | 53 | 08-20-07 01:49 PM |
| Sonosub Construction Question | letzleta | DIY Subwoofers - Sealed and Ported | 3 | 02-16-07 05:42 PM |
| SPL and Screen Size Calcs | Ayreonaut | General Discussion | 3 | 11-10-06 01:03 AM |
