Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > SoundSplinter
SoundSplinter
Scott's Dual RL-p18 'LLT' twins finished
Discuss Scott's Dual RL-p18 'LLT' twins finished in the DIY Speakers and Subwoofers forum; Scott's Dual RL-p18 'LLT' twins finished Lookin' good!!! How big is your screen? Your next goal should be to hide those pesky cables , and the ...
SoundSplinter
Views: 12967 - Replies: 27
Old 07-16-08, 04:06 AM   #26
Alias: jagman
Loc: Sacramento, CA
User: #1455
  jagman is online now
Re: Scott's Dual RL-p18 'LLT' twins finished
Your next goal should be to hide those pesky cables , and the best cheap mod for a front projector... paint the walls and ceiling dark! Go with your better half and let her choose the colors... but be sure the are dark. Also have her choose the color of new window coverings... if you (or she) sews them, they can also be cheap but really improve the look of the room and the quality of the picture. Of course the other main thing is passive acoustic room treatments. I made a ton of them for my room and they make a huge improvement in sound quality. I'd say the only thing more important than good acoustics are good speakers, and if you make your own treatments they can be downright cheap.
Old 07-16-08, 02:37 PM   #27
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
  Scott S is offline
Thank you! It's 100" diagonally.
The cables aren't too big of an issue at the moment. It's only because I have to use analog outs from my HD decks (with a audio switcher) that it is such a MESS behind the equipment. The cables in the back of the room aren't really noticed at all. But these things will be even cleaner soon.
After I get my car's windows tinted, I will be lining the majority of the walls with homemade acoustic treatment. All wrapped in black cloth to bring the reflectivity of the light from the walls down. All the side walls will have treatment and the upper side walls and ceiling will even get treatment too. All that is probably a month or two off from now though.
Old 07-16-08, 03:50 PM   #28
Alias: jagman
Loc: Sacramento, CA
User: #1455
Awesome . You'll really notice the difference. Both are relatively inexpensive ways to have a dramatic effect on visual and acoustic performance. A bit of warning from someone who did this already... be prepared for it to take a long time to do the work. It's worth every penny and fun, but it is labor intense.
« Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter »
