Go Back   Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter
Register
SoundSplinter
RL-P18 D2 LLT in a 350-400l enclosure?
Discuss RL-P18 D2 LLT in a 350-400l enclosure? in the DIY Speakers and Subwoofers forum; RL-P18 D2 LLT in a 350-400l enclosure? I see that most RL-P18 D2s are in 550-650l enclosures. That is too big for me. What about a 400l ...
SoundSplinter
Old 10-04-07, 04:27 PM   #1 (Link)
Alias: Max
Loc: Indy
User: #7359
Since: Mar 2007
coctostan is offline
I see that most RL-P18 D2s are in 550-650l enclosures. That is too big for me. What about a 400l sono tuned to ~13.5-14hz? Would this be advisable over a RL-P15 D2 in 300l sono tuned to ~15hz?
My models show the 15 flatter, but more output from the 18 and more extension. Would my room ~3000cu ft room help out?
I really don't know what a good curve should look like. Thanks.
Old 10-04-07, 11:55 PM   #2 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
Re: RL-P18 D2 LLT in a 350-400l enclosure?
I am/was somewhat in the same boat as you are... arriving at the conclusion that a 650 liter sonotube wouldn't integrate well into my HT space, and instead looking at box in the neighborhood of 15 ft^3 (425 liters). I looked at a 15" driver solution but ultimately decided on the RL-P18 because of the large advantage it has in displacement, with only a modest increase in cost. The exact tuning frequency seems to be a matter of opinion and preference, assuming you stay within the handful of well established guidelines concerning port length, port air velocity, and cone excursion. At 15 cubit feet, SteveC suggested a 16.5 Hz tune with the RL-P18 D2. You can go lower as long as port length doesn't get too long and raise the specter of a first port resonance less than 190-200 Hz. I don't know that the 3000 cubit foot room will help or hurt. My understanding is that it will have a bit less room gain at low frequences than, say, a 2000 cubic foot room. But I don't know how to measure or quantify that. Either way, the 18" driver will produce ample output and presumably you can use a BFD to EQ it to a fairly flat in-room FR response curve.
Hope that helps.
Old 10-05-07, 03:42 PM   #3 (Link)
Alias: Max
Loc: Indy
User: #7359
Since: Mar 2007
So which is better:
RL-P18 - 425 liter - 16.5hz - 8 in dia port
or
RL-P15 - 300 liter - 15hz - 6 in dia port
Obviously the 18 is a little bigger, but that would still be doable for me. I know it won't have the extension of a 600 liter enclosure, but it looks pretty similar to the 15 with more output.
Old 10-05-07, 05:31 PM   #4 (Link)
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
Scott S is offline
If youre just making one woofer and SPL is important Id go for the 18. Personally, I wouldnt go that small. I would go for at least 500 liters for the 18 and tune around 14-15hz but thats me. I did two RLp18s each in a 725liter box tuned to 11hz.
Old 10-05-07, 06:09 PM   #5 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
"What Scott said."
If you can swing it, go with the RL-P18. It can move/sweep 6.5 liters of air, compared to about 4 liters for the RL-P15. Here is the transfer function for the two subwoofer alignments as you described:
Above 15 Hz the 18" driver walks away from the 15" handily. At 15Hz the RL-P15 is about done and the RL-18 is dropping off too due to the 16.5 Hz tune (and box size). But one potentially serious problem I see with the 15" plan is the port air velocity. If you feed it 500W, your port air velocity hits 34 m/s which is twice the ideal maximum of 17 m/s (5% the speed of sound).
Old 10-05-07, 06:25 PM   #6 (Link)
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
Scott S is offline
Yep! Thanks Bradley for supplying those charts!
The 8" port and bigger box will surely come in handy, especially when considering port speed. If you had the choice Id go with a slightly bigger box and/or a lower tune. At least 14hz (15hz max unless youre a SPL hound) with the 18. *nods*
Old 10-05-07, 11:12 PM   #7 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Even in the 425liter enclosure I'd drop the tune to 15Hz.
Old 10-12-07, 05:34 PM   #8 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
With only 425 L, I would tune the box to 17-18. This is more reasonable and will be easier to build. Bear in mind that most commercial subs are tuned even higher and still many of them sound very good.
Depth is fine but say 13 Hz is not a priority when using 425 L. You might even be unable to hear a difference between a sub tuned 13 and the other tuned 17 Hz, but there will be a noticeable SPL difference though (in a 3000 cu ft room).
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 11-02-07, 04:48 AM   #9 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Max,
Any news? What did you decide? Any pics? Your experience may be useful for people who would like to have RL-P18s but do not want a 600L box...
« Home Theater Shack > DIY Speakers and Subwoofers > SoundSplinter »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Scott's Dual RL-p18 'LLT' twins finished Scott S SoundSplinter 23 04-25-08 01:58 PM
Sealed or LLT sub enclosure for these drivers? William_Wilson DIY Subwoofers - Sealed and Ported 6 03-21-08 03:40 PM
Dual RL-P18 LLT for my 2000 cu ft HT soon Blaser SoundSplinter 182 02-08-08 07:45 PM
Dual RL-p18 LLT begun tjambro SoundSplinter 103 12-02-07 01:32 PM
Want to build an LLT enclosure for my 13W7 ambs275 DIY Subwoofers - Sealed and Ported 27 06-21-07 09:17 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
