| SoundSplinter What Amp?Discuss What Amp? in the DIY Speakers and Subwoofers forum; What Amp? What amp should I look into getting to push a RL-P 18D2? I was looking at the PE Plate amp,The ... |
| | #1 (Link) | |||
| What Amp? What amp should I look into getting to push a RL-P 18D2? I was looking at the PE Plate amp,The Berhinger,QSC or Crown. The sub will be in a sonotube that is 550 liters and tuned to 14.5 hertz? Help me pic. | |||
| | #3 (Link) | |||
| Re: What Amp? I'd personally stay away from plate amps for this application, largely because it will be difficult to integrate it into the sonotube. You can also get more bang for your buck (power-wise) from pro amps. I've had good luck with Crown and QSC as a gigging musician and use a Crown XTI2000 for HT sub duty, but it's hard to beat the price/power ratio of the Behringer EP series amps for home use. | |||
| | #9 (Link) | |||
| Re: What Amp? I'm still waiting for my 2500 to get here to replace my PE 1000 so I can't give an opinion on anything but prices. I paid 250 shipped for my amp used but like new. The plate amp is on sale for 330 sometimes, plus shipping. The Behringer is more than likely not only the much better amp but has more power too. Keeping the amp separate from these bad *** subs is probably a good idea too. The vibration all the time could conceivably take out your amp. Btw the 250 costs littlel more than the 1500 and wattage is good to have. | |||
| | #10 (Link) | |||
| Re: What Amp? Never! with this sub size and tune, you will never have to worry on program material. Indeed, If you can afford a stronger power for each, I would encourage... ![]() Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #11 (Link) | |||
| Re: What Amp? Why the PLX over the more affordable RMX? I know the PLX series weigh a lot less, but for the HT, you obviously aren't going to be hauling it around from gig to gig (as it was designed for). After watching War of the Worlds the other night with my newly built RL-P18 sub, I am very hesitant to run my amp (QSC RMX 2450, similar specs to the EP2500) bridged and feed it over 2000 watts. At 750 watts, it was scary enough. Plus, isn't the driver rated 1000 watts RMS? All that said... the QSC PLX 1804 looks very attractive to me right now for the purpose of driving my two subs. You can't bridge that particular model, but it will deliver 900 watts into 4 ohms in stereo mode which isn't too shabby. Plus I believe it has a solid state power supply (no transformer) and weighs a mere 13 pounds. Somebody please tell me what good and/or compelling reasons there are to push this thing with more than 1000 watts and convince me no harm -- either short term or long term -- will result from doing so. Bradley | |||
| | #12 (Link) | |||||
| Re: What Amp? Quote:
You can get a new one for $70 more. Also has SMPS instead of transformer and is rated for 1100W per channel @ 4ohms. I'll be getting one soon. I hope to send it to Chuck for testing. Quote:
| | #13 (Link) | |||
| Re: What Amp? Ack... why is that Crown rated from (only) 22 Hz to 22 kHz? If that's truly the case, and you can't do a simple mod to "fix" it, I'll take a pass on that one. The QSC has great specs:http://www.qscaudio.com/products/amp...ifications.htm Can probably get a new one for $600 delivered and sell one or both of the RMX amps I have. Last edited by Bradley; 11-06-07 at 10:38 PM. | |||
| | #14 (Link) | |||
| Re: What Amp? What? You think its some brickwall at 22Hz? It is the +/- point for the top and bottom end. Every amp manufacturer does this. Even the QSC you're looking at has it: 20 Hz-20 kHz, -0.5 dB In neither case does it mean the amps don't go below 20Hz, it just means the FR is guaranteed to be within a +/- .5 or 1dB deviation at/below 20Hz. You'd have to mod the QSC as well if you want flat to DC. ![]() | |||
| | #15 (Link) | |||
| Re: What Amp? I'm new to pro audio amps and am wondering why spend more than what the Behringer costs? I buy quality whenever I can but in this case I don't see what you gain by using a Crown, QSC or Crest. Being as so many people are happy with the Behringer amps they must be reliable. Other Behringer components I have work fine. Wish I'd never have sold the DEQ 2496 with mike but it worked perfectly for 2 years and I happen to know alot of people in high end audio like them, like me. I knew I'd regret it. | |||
| | #16 (Link) | ||||
| | #17 (Link) | |||
| Re: What Amp? Yes, I was. Only because I was confused as to why you were acting like the spec'd low-end FR of the Crown is so horrible, when I see no reason to suspect it is. But forget it, get the QSC. | |||
| | #19 (Link) | |||
| Re: What Amp? Odd because it is 22Hz and not 20Hz or odd because the +/- 3dB point isn't present? It appears that is a common thing for Crown to omit from their specs, but it hasn't stopped anyone else from using them (CE4000, K2 but we know it has a highpass at 8Hz, XTi lineup). | |||
| | #20 (Link) | |||
| Re: What Amp? Mostly because it was specified as 22 to 22kHz, instead of 20 to 20kHz like "everbody" else does. The -3 dB points would be nice to have also. Probably nothing to worry about for the sake of driving a subwoofer, though. If low frequency response is limited, it is probably being done intentionally with a simple RC HPF. So I'd think that in the worst case scenario you'd only have to change some capacitors (and/or resistors) in the amp to get the lowest frequencies to pass. The Crown is an interesting option. $569 with free shipping is a pretty good deal. I guess that's because it has been discontinued and is now on clearance? | |||
| | #21 (Link) | ||||
When I went from a Parasound hca 1500a (205/ch) to the used QSC PLX 1602 (300/ch), it woke up my pair of VMPS original subs. | ||||
| | #22 (Link) | ||||
edit: Just sent David Glass an email. We'll see what he has to say. | ||||
| | #23 (Link) | ||||
Edit: OK, scratch that. Looks like the Parasound has excellent FR down low and super high damping factor. Go figure. Were/are your subs 8 ohms? You ever try bridging the Parasound? HCA 1500A SPECIFICATIONS Continuous Power Output - Stereo: 205 Watts RMS x 2, 20 Hz-20 kHz, 8 Ω, both channels driven 315 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven Continuous Power Output - Mono: 630 watts RMS, 20 Hz - 20 kHz, 8 Ω Current Capacity: 60 amperes peak per channel Slew Rate: > 130 V/µsecond Frequency Response: 5 Hz - 100 kHz, +0/-3 dB at 1 watt Total Harmonic Distortion: < 0.03% at full power; < 0.01 % typical levels IM Distortion: < 0.03 % TIM: unmeasurable Dynamic Headroom: > 1.5 dB Interchannel Crosstalk: > 80 dB at 1 kHz; > 60 dB at 20 kHz Input Impedance: 33 k Ω Input Sensitivity: 1 V for 28.28 V, THX Reference Level; 1.2 V for full output S/N Ratio: > 110 dB, input shorted, IHF A-weighted Damping Factor: > 800 at 20 Hz Power Consumption: 500 watts | ||||
| | #24 (Link) | ||||
I still like the QSC PLX 1804, but another 200 watts per channel (into 4 ohms) and somewhat lower price certainly is tempting. | ||||
| | #25 (Link) | ||||
The PLX is rated 300/8 ohms 500/ 4 ohms so it has a good amount of headroom. I could bridge the PLX too. I think the subs would like a little more juice ![]() | ||||
