| SoundSplinter Tall, wide and shallow box?Discuss Tall, wide and shallow box? in the DIY Speakers and Subwoofers forum; Tall, wide and shallow box? I've considered building a LLT for some time now. In a year or two I will start construction of my ... |
| | #1 (Link) | |||
| Tall, wide and shallow box? I've considered building a LLT for some time now. In a year or two I will start construction of my new house, and I'm planning on a serious build then, but in the meantime i'd like to get some building experience and try a few things out. So, in the back of my room I have a double french door to my office. The office has another entrance, so the doors are pretty much just there to mess up my acoustics. I have a PB12+/2 behind my couch, and it works pretty well there. So I thought I might remove the door blades and build a big subwoofer instead, filling the hole in the wall. The opening is 150cm wide by 210cm tall. So if I make this box 40cm deep I'm getting some 1200l volume. I'm concerned about the shallow box, though. Will be great for looks and not using much floorspace, but will such a shallow box work at all? I'm planning on using two rl-p15 and a behringer 2500, and maybe keeping my pb12+/2 if it's needed to even out the response. Is this at all feasible? Any tips? | |||
| | #2 (Link) | |||
| Re: Tall, wide and shallow box? Yes it will work,the port will need to bend(or you use a slot port). You line the cabinet with acoustic material inside and I do not see an issue. The cabinet will have to be well built,other than that you should be A ok. When the driver fits(depth wise) you are fine. Measure how tall the driver is,and be sure it fits,back of magnetic structure clears the back wall (bu an inch or more). | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Moderno in-wall 10" - To Box or Not To Box | billmd | Home Audio Speakers | 1 | 12-02-07 09:10 PM |
| Building IB box | peteaimee | DIY Subwoofers - Infinite Baffle | 17 | 10-30-07 09:02 AM |
| Need help with box | auburnu008 | DIY Speakers | 13 | 09-09-07 08:19 PM |
| Sub Box Design | Danny | DIY Subwoofers | 15 | 06-14-07 10:54 PM |
| My Box Design | Danny | DIY Subwoofers | 14 | 02-21-07 08:11 AM |
