Monkey see, monkey do... two RL-P18s for me too! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > DIY Speakers and Subwoofers > SoundSplinter
SoundSplinter
Discuss Monkey see, monkey do... two RL-P18s for me too! in the DIY Speakers and Subwoofers forum; Monkey see, monkey do... two RL-P18s for me too! Well, normally I would hate to be so unoriginal... but in this case I must make an exception! After countless ...
SoundSplinter
Old 10-02-07, 04:23 PM   #1 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
LLT "Lite" with dual RL-P18s (was: Monkey see, monkey do...)
Well, normally I would hate to be so unoriginal... but in this case I must make an exception! After countless hours reading and researching, both here and on AVS, I've reached the inevitable conclusion: the RL-P18 is the way. Hard to argue with 6 liters displacement.
First off, I want to thank Mike@SoundSplinter for fast and courteous service, including prompt and hassle-free shipping. The pair of RL-P18 D2s arrived in my office yesterday and I have to say THE PICTURES DO NOT DO THEM JUSTICE. Those of you who own them know what I mean. They are jaw-droppingly massive and gorgeous drivers.
I also have to give credit to SteveC for his in-depth explanation of the LLT alignment and its many virtues. I was "this close" to building a sonotube, but ultimately decided a box (or two) would fit better in my HT room. To that end, I've definitely been inspired by ScottS, Blaser, and Tjambro and their monster RL-P18 subs.
I'm also impressed by the passion and generosity of guys like Collo that share freely the results of a lot of research and publish handy software programs to assist in building subs. The same goes for the makers of WinISD, Unibox and REW -- although I am not personally acquainted with them. Finally, let me recognize the Home Theater Shack for providing a valuable alternative and more "focused" venue for sharing these passions.
This is my first DIY speaker/sub project. It is similar to what others have done here but perhaps a little more "modest", if you can even use a word like that in this context. Here's the overview:
Two RL-P18 D2 drivers, each in its own 17 ft^3 net cabinet tuned to 14.5 Hz.
Two 6" inch ports in each cabinet, with a 1.5" radius flare at both ends.
Both subs powered by QSC RMX 1850 HD, rated 600W into 4 ohms x 2 channels.
BFD 1124P to be ordered soon.
So, I will be asking questions and posting a lot of pictures in the days and weeks to come. I appreciate all the help I've gotten so for and hope I can return the favor somehow, some way, in due time.
Bradley
P.S. I sold my Def Tech PF15TL+ subs the other night, so I am now 100% subwooferless and therefore highly MOTIVATED to get the RL-P18 show on the road.
Old 10-02-07, 04:42 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Monkey see, monkey do... two RL-P18s for me too!
The RL-P18 is a good choice. There are a lot of people who are happy with them. 17 ft^3 net is a big box. What are the dimensions going to be?
Old 10-02-07, 04:50 PM   #3 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
Box design.
I'm going to install Google Sketchup tonight and start learning how to draw boxes (love the 3D drawings NeoDAN on AVS has posted). Box material selected is 3/4" MDF. Tentative dimensions:
27.5" high
46.0" wide
30.0" deep
Driver to be centered on front panel. Twin 6" ports exiting on side panel. MDF cross bracing throughout: all the way down the middle "long wise" and at 3 places "cross wise" (spaced about 11.5" apart).
The height limit is based on what will fit under my projection screen and fit through a standard 30" doorway (with trim on it). The width is mostly limited by the size of the sheet of MDF, so it could potentially go up to a max of 49". The depth is my preference as to how far forward I am willing to have them "protrude" from where the projection screen is. Pictures of the area in question coming soon.
Edit: I'm at about 19 ft^3 using the internal dimensions, minus about 1.3 ft^3 for the ports, 0.2 ft^3 for the driver, and the rest for bracing. That sound about right? Calculating the actual volume of all the bracing is going take some time once the brace design is worked out in detail.
Old 10-02-07, 05:45 PM   #4 (Link)
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
Scott S is offline
Ahhh, two RLp18's will be a HUGE step up from a single Def Tech 15. I know, I had the same one. (well, not the + version. Same thing but yours has a slightly bigger amp.)
I had to use the full length of the MDF boards, myself. Gotta be careful at the lumber yard. Make sure before you leave to check if they are a full 49".
First off, you are fine shape regarding the alignment. I knew I would have awesome room gain and I love being able to go real low so I opted for an 11hz tune. 14.5hz should get you awesome output. At some point you may want more, get a second amp. I may need to get another as well as I am using a single EP2500 to run both. Havent clipped it once yet but then I may never...heheh.
Don't know a whole lot about shaping a box and all that. I just know how much I need, so you may have to get someone to throw up a box for you if you're unsure.
One thing I would change....go with an 8" port if possible. I think you will be much less likely to run into chuffing if you push them to the extreme. Dont know about your bass habits. EDIT: Ooooh, yeah. I just ran the sims on a single d2 with 600w and the 6" port. Definitely gonna have some heavy airflow in those ports. You dont want that! Not sure if you are gonna be able to see the ports of if its a big deal or not. I got both my 8" ports from a lumber yard. They were 8" sonotubes, actually. Total cost of both cut down to size....about $15. I'd do that if I were you. Unless you just had to have flared ports.
Old 10-02-07, 06:26 PM   #5 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
Hey, Scott!
Scott S wrote: View Post
I had two of those PF15TL+ subs. Bought a second one for parts/troubleshooting after pushing the first one a little too hard and fearing something wrong with it.
There will be two 6" ports in each cabinet. This afford 12.5% more cross sectional area than a single 8" port, and gave me a little more room inside the cabinet as far as staying one port diameter away from the wall(s). With a 1.5" radius flare, I should be in good shape. Collo's testing showed improvement going up to a 40mm flare on a 6" port, so I figured 1.5" (38 mm) was where I wanted to be.
While I have your attention... I have a few questions about your build. What speaker terminals did you use? Happy with them? Did you wind up using the 10-32 size machine screws (instead of 1/4-20) with the hurricane nuts? Any particular reason you used fiberglass insulation inside the cabinet instead of polyfill or some other material? I'm not sure which is best, but I would like to avoid fiberglass if I can help it.
Thanks!
Bradley
Old 10-02-07, 06:46 PM   #6 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
The pic below illustrates approximate placement of the subs relative to the 110" diagonal (8' W x 4.5' H) projection screen.
Please note this is an old pic. None of that furniture is still there. I presently have 9 HT recliners, row of 4 up front, and row of 5 in back. Drop ceiling will most likely be removed and sheetrocked as it buzzes a lot. The HT room is a serious "work in progress"... i.e., a lot of work and very little progress!
Old 10-02-07, 06:59 PM   #7 (Link)
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
Scott S is offline
Oops! I missed the (two) 6" ports per box part. Still in "work-mode" here at the office.
Air speed is much better with the two. For sure. They will be just as long as my 8" ports are...hehe, but it should all work in the end. As long as you have at least 6" from the inner opening of the port to the back end of the box...
Ill have to look at the specific part numbers for my binding posts for you as my brain is at critcal meltdown about now...(long day at the office). I dont know if I even mentioned which ones I ordered in my build thread or not. I ended up using some 10-32 screws from a Parts Express subwoofer installation package. That one is linked somewhere on my build thread. You could take a look if you like. They seem to work fine. I soldered the speaker wire to the posts and they were installed with much ease. Very clean look. Wish the binding posts on my amp were as good.
As for the insulation I used...when I was in the build process and got to the part of insulating them, I wasnt getting any responses on my thread about what to use so I just searched around for people using anything other than egg-crate variety and saw a few projects with the same stuff....ooof! I forgot the number...gosh Im tired. I wanna say R33 or something but I could be wrong. Ill have a looksey. I liked it best cause it was easyish to cut and was really cheap. Got the job done...
So far, other than trying to get a flat FR in my seat I am loving these! Great SQ and awesome extension. The Def Techs barely got into the 20's when I had one...then I had a vented Tempest for about 5 years. That blew away the Def Tech, bar none! Now these....
You're gonna have a lot of fun. *nods*
Old 10-02-07, 09:48 PM   #8 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Congrats on the wise decision!!
Two 6" diameter ports in that size enclosure with a 14.5hz tuning means the ports will be ~38" long - I'd personally stay away from anything 36" or longer unless you are sure you will be crossing over at 60hz and not 80hz, as the port resonance could very well become audible. I think you'd gain flexibility and "safety" by using a single 8" that is 31-32" long, as you could cross over higher without worry, and none of us 18" LLT owners have experienced any chuffing with a single 8". I just don't really see much being gained with the two 6"s at the expense of a potentially audible resonance - just something to think about.
Old 10-02-07, 11:20 PM   #9 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
SteveCallas wrote: View Post
Are you using WinISD or Unibox or something else to calculate port length and resonance? I'm still a little fuzzy about how WinISD changes the port length and resonance frequency based whether you pick zero, one, or two flared ends for the port. My understanding was that you could assume half of the flare length functions as effective port length, as a rough approximation. Obviously, in reality, the flare radius would have to factor into the calculation. So when you pick two flared ends instead of one or zero, the port length value goes down. Does this value refer only to straight section of the port (not including the flares)? Why do I feel like I need to RTFM?!
At what frequency does port resonance become an issue? With this alignment I'm flirting with around 180 Hz. Is there some rule of thumb, like 3 times the crossover freq? I could either use the 8" port or increase the box size to get it closer to 200 Hz if that would make a meaningful difference.
Thanks for your input. Certainly nothing is etched in stone (or MDF) yet.
Bradley
Old 10-03-07, 12:17 AM   #10 (Link)
Alias: Steve
User: #263
I mentioned a first port resonance > 190hz in the LLT explained thread based primarily on various enthusiasts using longer and longer ports until it started to become noticable. When you start using a port longer than 36" and a crossover at 80hz, the resonance can actually show up in the FR with the mains in play.
One note - and I apologize if I am sounding pushy about this port thing, I just don't want to see you end up with something that could potentially be considered a fatal flaw - if you do go with a larger enclosure, say 20 cubes, I think you'd be better served still going with an 8" port and dropping the tune to ~13.3hz as opposed to keeping the 14.5hz an dusing dual 6" ports.
Old 10-03-07, 02:09 AM   #11 (Link)
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
Scott S is offline
I mentioned a first port resonance > 190hz in the LLT explained thread based primarily on various enthusiasts using longer and longer ports until it started to become noticeable. When you start using a port longer than 36" and a crossover at 80hz, the resonance can actually show up in the FR with the mains in play.
Yeah, I gotta say I am in total agreement with Steve here. (whats new? ) If you could possibly go with a tiny bit bigger cab then I would go for it. In the long run you wont run into such hazards as the port resonance gets really close to audible with such long tubes. I was really pushing it with my design. They are about 35-36 inches each and I have yet to hear any effects. Although, I have my xover @ 60hz so maybe I just lucked out.
Also, going with the 8" port will allow for a slightly lower tune and thats always nice. *nods*
Just something to consider if its a doable option for you.
Old 10-03-07, 10:22 AM   #12 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
So at 15 ft^3 you were recommending 16.5 Hz tune but at 20 ft^3 you'd recommend 13.3 Hz? Running the sim both ways, and at several places inbetween, there are significant but not huge differences. Some people seem very concerned with air velocity in the port, but since the 8" port has been used by so many people with good results, I would have to conclude that port velocities well over 17 m/s (and as high as 25 m/s) down in the 12-14 Hz range are not a problem.
I guess I'll chew on all this some more and try to wrap my head around it, so to speak. No matter what, I will not use a port length greater than 35" (193 Hz resonance).
Thanks for the input. I respect the experience you bring to the table and your strong convictions.
Old 10-03-07, 05:21 PM   #13 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is online now
Bradley wrote: View Post
Congrats on your decision! Those RLP18's are definitely awesome and somehow I don't think you'll miss your deftechs. I was a bit concerned about using fiberglass insulation as well. I thought maybe fine particles would fly out of the port and that it may not perform as well as other materials. When budget and accessibility became a factor I decided to use some R-13 and have not been sorry. It's easy to find, cheap, easy to install and it's actually a great sound absorber. In fact when people soundproof rooms they often use double thick walls with more insulation. I've never noticed any dust or particles flying out of my tubes and I couldn't be happier with the sound. Good luck with the build and keep us informed!
Old 10-04-07, 12:54 AM   #14 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
Nothing new to report tonight... but I thought I would post the mandatory picture of the newly arrived RL-P18s! For reference, next to them is a (blown) 15" driver out of one of the Def Tech PF15TL+ subs I just sold.
Just puts a smile on my face every time I look at them.
Old 10-04-07, 02:27 AM   #15 (Link)
Loc: Lower Alabama
Sonnie is offline
That looks like a 12" sitting next to those 18's.
I'm looking forward to some build pics...
Sonnie
Old 10-04-07, 12:43 PM   #16 (Link)
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
Scott S is offline
While working with the fiberglass, handling and cutting...there were some floating particles. I had an opened side to my boxes until I closed them. By then I had dusted and vacuumed the extra particles out. Ive played all sorts of loudness outta them inroom and there is no fiberglass floating around in the room. And for the first month I had the ports pointed INTO the room. So no, fiberglass will not be blowing particles around the room.
Love the pic of the dual 18's next to the whimpy Def Tech.
Old 10-06-07, 01:18 AM   #17 (Link)
Alias: Mongrel
Loc: Cape Coral,Florida
Mongrel714's Avatar
User: #9120
Since: May 2007
Mongrel714 is offline
Man you're in for a treat, I just built my single 18" SS, and yes I used an 8" port, you can pick them up at Lowes in the concrete section, massive port for a massive speaker, make sure you have everything nailed down when you crank those babys up and enjoy!
Oh yeah, the QSC is an excellent choice, I'm running a RMX 1450, a little over halfway shakes the house.
Old 10-07-07, 12:27 AM   #18 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
Got MDF?
Mongrel714 wrote: View Post
I was actually over at Lowes today picking up the MDF and I took a look at the concrete form tubes. They only had two 8" tubes left and they were significantly different in size. It says "8 inch nominal" with plus or minus .5 inch variation, obviously so they can slip one tube inside the other for saving space and lowering shipping costs. Anyway, I hit Home Depot and picked up some Sakrete brand tubes. Cherry picked two identical tubes, which are about 8.25" inner diameter. They're not what I'd call robust, though. I have a feeling genuine Sonotube brand tubes are probably stronger.
Anyway, found somebody helpful with half a brain to cut up the MDF for me so it would fit into my car. He did a pretty good job, accurate to within a 16th of an inch. I felt pretty silly loading 450+ pounds of MDF into the back of my Audi.
I also picked up this used table saw today with a newly installed Biesemeyer rip fence. Should be pretty nice for this project!
Bradley
Old 10-07-07, 01:35 AM   #19 (Link)
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
Scott S is offline
Swwwweeeeeeetttt!
You're on your way to bass heaven.
Old 10-07-07, 10:49 AM   #20 (Link)
Alias: Mongrel
Mongrel714's Avatar
User: #9120
Since: May 2007
HEHEHEHEH, The Audi looks like a fine vehicle to haul MDF to me! The sakrete tubes are a little flimsy wouldnt use them for a main enclosure, but for a port that will be braced it works well what ever sound deadning material you use to line the interior walls with, be sure to wrap the port in also,Good Luck!!
