| SoundSplinter RL-P15's, Choose D2 Ohm, or D4 Ohm?Discuss RL-P15's, Choose D2 Ohm, or D4 Ohm? in the DIY Speakers and Subwoofers forum; RL-P15's, Choose D2 Ohm, or D4 Ohm? What are the criteria for choosing between the dual 2 ohm and dual 4 ohm versions of the RL-P15's? The ... |
| | #1 (Link) | |||
| RL-P15's, Choose D2 Ohm, or D4 Ohm? What are the criteria for choosing between the dual 2 ohm and dual 4 ohm versions of the RL-P15's? The numbers are different on the drivers, but are those numbers representative of all circuit config of the voice coils? Or, do they represent the coils wired in series, for 4 ohm and 8 ohm loads, respectively? I just want to build what seems to be the standard sonosub design here: a 15" driver with 260 net liters, and a 14 hz tune. I have a Crown Macrotech 1200, which is very stable (and probably under-rated for power) putting out 700 wpc into 2 ohms. I'd like to build a pair of sonosubs for it. Are the two subs mentioned effectively interchangeable? | |||
| | #2 (Link) | |||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? Each coil is 2 or 4 ohms respectively. If you are just planning one sub per channel get the D4 and wire each in parallel for a 2 ohm load on each channel. If you are wanting to bridge it use the same configuration just wire the two subs in series. Last edited by bonehead848; 02-21-08 at 05:59 PM. | |||
| | #3 (Link) | |||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? Thanks, bonehead. But do the technical specs have any impact on the results? That is, what about the different listed Fs, Qts, etc, as seen here: http://www.soundsplinter.com/rlp15_s...formation.html | |||
| | #4 (Link) | |||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? Well, however it works, I hope I can get the dual 4 ohm models to perform to their potential. I say that, because I have just picked up two of them, and I am quite excited about it. 20" x 12' Sonotube (brand) at the local supplier, CMC Services: $93.48, or $7.79/ft. Anyone know about the Precision Port Flares and tubes? I think I could piece together everything for a 34" 6" port with 2 flares for well under $100 (sorry, I don't have enough time to make my own flares). Are the precision ports, etc., quality equipment? | |||
| | #7 (Link) | ||||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? Quote:
I wonder if they model the same.. ![]() Warmon - "know what I mean Vern" | ||||
| | #8 (Link) | |||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? I ran 2 of the D4's in my car and moved them into the HT last year. Each one is in 10cubes tuned around 18Hz. Only getting 400watts each and they sound amazing for music and movies. I know they model a little differently, but in the real world I imagine it makes little difference. My two fav demos are: Godsmack dualing drum solos & depth charges in U-571. One shakes the house to death, the other punches you in the chest with the kick drums. I personally don't care for super low bass that just beats up the house, so I didn't do an LLT. | |||
| | #12 (Link) | ||||
![]() Red-RL-p15 2ohm Green- RL-p15 4ohm We're all in this together! | ||||
| | #13 (Link) | |||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? I would guess, looking at those graphs, that a little equalization would make them about the same. Question: How much does the wiring config affect the curve? Does wiring in parallel create different sonic specs than when wiring in series? Also, if you want a two-ohm nominal load, do you have to choose the D4 and wire in parallel, or is there a way to make the D2 produce a nominal 2 ohm load? Last edited by Chris in Dallas; 02-26-08 at 01:00 PM. | |||
| | #14 (Link) | |||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? Each one is in 10 cubes tuned around 18-19Hz. Someone else modeled it for me. I went with a little higher tune for a little more SPL and a little less real low stuff, just the way I like it. | |||
| | #15 (Link) | |||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? I came across some information that JBL puts out saying that transient response is degraded when wiring subs in series. It was pretty technical, but the jist of it had to do with delays from one sub to the next - like #2 had to wait on #1 before it could do its thing. At the time I was thinking about buying some NOS GTI's. I have three 4ohm Polk DVC's wired in series and I can't say that I notice anything lagging or anything. Chris, in your case I would think you'll want to wire the coils in series and the subs parallel and run your amp bridged. From the graph, looks like the D4 has sacrificed a little on the mid-bass to get more output <20. D4 is a little lower. D2 is a little louder. If Unibox suggest a sealed box, that would mean EBP is closer to 50 than 100, right? Warmon - "know what I mean Vern" | |||
| | #16 (Link) | ||||
I have asked SS directly about the effect of the specs on the sub performance, and why someone might choose one or the other. I'll get back with the response. | ||||
| | #17 (Link) | |||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? EBP is the Efficiency Bandwidth Product - a number derived from dividing Fs by Qes. The resulting number is used to determine whether a particular driver is better suited to a sealed or ported alignment. Closer to 50 - sealed, Closer to 100 - ported. D4 is 27.487 / 0.508 = 54.11 D2 is 23.426 / 0.363 = 64.53 Warmon - "know what I mean Vern" Last edited by Warmon; 02-26-08 at 05:30 PM. Reason: wrong D2 | |||
| | #18 (Link) | ||||
How's that for picking a nit? ![]() | ||||
| | #20 (Link) | ||||
| | #22 (Link) | ||||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? I asked the same thing. Mike basically said 'it depends'... His answer in full: Quote:
| | #23 (Link) | ||||
| Re: RL-P15's, Choose D2 Ohm, or D4 Ohm? I checked for a response from SS among my spam mail, and there, tucked in-between 50 offers of methods to enlarge my "unit" (how did they know?) was the response from Mike: Quote:
