The Official $2,500 Speaker Evaluation / Home Audition Event - Page 61 - Home Theater Forum and Systems - HomeTheaterShack.com
post #601 of 1075 Old 11-06-13, 02:40 PM Thread Starter
HTS Hillbilly
HTS Administrator
I'm a redneck!
Re: The Official $2,500 Speaker Evaluation / Home Audition Event
My thinking is they would be at least as good as the Motion 12's... and should be better. It will be interesting to get Wayne's take on them once he gets them in house.
Cedar Creek Cinema
PremierHomeAudio: Denon, Marantz, Onkyo, Yamaha, Sony, Pioneer, Def Tech and more. Shoot me a PM!
Sonnie is offline
post #602 of 1075 Old 11-06-13, 03:17 PM
Thanks for doing the reviews i like to compare my opions with others
jmhenrie is offline
post #603 of 1075 Old 11-06-13, 03:21 PM
HTS Moderator
Reviewer
AudiocRaver's Avatar
Wayne Myers
Sonnie wrote: View Post
An interesting side-effect of getting a "problem" pair of speakers for the evaluation is getting to play with a good pair at home for awhile. Can't say I am too broken up about that. I have had some good times with the HTD Level THREE Towers - review to be published in a few weeks, probably - and am not saddened in the least to have to put up with a pair of Martin Logans for a bit. My wife was excited, too.
Leonard and Sonnie have both mentioned the benefits of taking measurements early on to see what one is working with. That is now our first step in the process. In fact, Sonnie even thought of doing it next round before starting burn-in when speakers first arrive. It can save a bunch of frustration, confusion, and wasted time. I recommend that ANYONE buying speakers have basic frequency response measurement capability to see that a pair of speakers matches well. Since the measurements are relative, even an uncalibrated omni will give the information needed (if you are going to buy one, always get a calibrated one.)
Edit: We always swap L and R positions to make sure any "problem" follows the speaker.
AudiocRaver is offline
post #604 of 1075 Old 11-06-13, 05:44 PM
Norcuron's Avatar
The heavy metal music is an interesting subject because most of the old good stuff was not recorded very well. If you are looking for some heavy metal that is recorded well for back in the day try Winger and the song "Can't get Enuff" and also try the Mortal Combat CD Various artists where the first track is "A Taste of Things to Come". Track 5 "Control" is a good demo song. The Metallica Black CD has a couple of good tracks too. I wish I was going to be there to listen to everything.
Norcuron is offline
post #605 of 1075 Old 11-06-13, 06:07 PM
AudiocRaver wrote: View Post
How would i know if this is calibrated
http://www.sweetwater.com/store/deta...Fcw9Qgod5VMAAg
Thank you
janick is offline
post #606 of 1075 Old 11-06-13, 06:59 PM
Savjac's Avatar
Jack
One of the good things about the ML's is the way they open the music up and let it float about the room in a way similar to watching Anna Pavlova move about the stage to some speakers Bill Murray. They are not as adept in the home theater when it comes to some of the more heavy handed action films, but they sure try. My wife liked them a good deal for looks and sound which is almost a first. I truly hope you enjoy them.
Good Listening
Jack
"For those who believe no proof is needed for those who don't believe no proof is possible"
Savjac is offline
post #607 of 1075 Old 11-06-13, 09:25 PM Thread Starter
HTS Hillbilly
HTS Administrator
I'm a redneck!
janick wrote: View Post
Thank you
If it does not state that it is calibrated and that they are including a calibration file, then it won't be calibrated. Buy from Cross-Spectrum Labs or straight from miniDSP (UMIK-1) if you need it to be calibrated, which is the only way I would buy one anyway. I think what Wayne was suggesting is that any mic you have lying around will work for comparing each speaker, but if you have to buy one, buy it calibrated.
Cedar Creek Cinema
Sonnie is offline
post #608 of 1075 Old 11-07-13, 03:29 AM
HTS Moderator
Reviewer
Wayne Myers
Precisely. Thanks, Sonnie.
post #609 of 1075 Old 11-07-13, 04:12 AM
|Tch0rT|'s Avatar
Ryan
Savjac wrote: View Post
Well recorded music is just magical on the ML's. I don't notice what you describe with action movies with mine however I'm much more picky about music than HT. I do have a separate amp on mine and that seemed to wake them up a little bit more than running them off a receiver for the dynamic parts. My issue with the ML's is the center image is very touchy. Any slight positional movement and it pulls to a side, mine tend to pull to the right and it drives me nuts. I do think my kids plopping down hard on the couch makes it slide a little bit possibly causing that.
|Tch0rT| is offline
post #610 of 1075 Old 11-07-13, 05:17 AM
HTS Moderator
Reviewer
Wayne Myers
|Tch0rT| wrote: View Post
We noticed that sensitivity working with panel speakers: the Magnepan 1.7's and the 12's back in August, some with Sonnie's big M.L. Prodigy's (right model?) and with another unnamed pair fairly recently. Depending upon placement, the sweet spot - although marvelous when occupied - can be slipped out of with just a few inches or even less of head movement. Our experimenting has shown that for stereo/music use the soundstage depth and depth acuity are best with the panels (any speaker type, for that matter) away from the front wall and roughly 1/2 (or more - depending on speaker) way to the LP, plus some amount of angling outward from straight-on pointing at the LP (very little for panels/dipoles, a lot for cone speakers). With panels specifically, as they get closer to the LP and soundstage gets better, sensitivity to head movement gets worse. With most models, the allowable movement has been acceptable, but not with all. It is possible for the LP movement sensitivity - or even the ability to locate it at all (and that is one seriously restrictive sweet spot - kinda takes the sweet right out of it) - to become unacceptable without the panels even reaching the point (distance from front wall/closeness to LP) where soundstage really opens up and takes on that magical depth factor.
Does that echo your experience?
$2 , 500 , audition , evaluation , event , home , official , speaker
You may not post new threads
You may not post replies
