The Official $1,000 Speaker Evaluation / Home Audition Event Results - Page 14 - Home Theater Forum and Systems - HomeTheaterShack.com
post #131 of 158 Old 09-16-13, 08:50 PM
Plain ole user
lcaillo's Avatar
Tech Guru
Re: The Official $1,000 Speaker Evaluation / Home Audition Event Results
Remember what the goal was. Sonnie wanted optimum soundstage and resolution, in his room, with the listening parameters that he uses. Really, as you say, there are infinite room conditions, so what ever one chooses is somewhat arbitrary. Having the speakers well into the room does minimize variables, and since the priorities were what they were, and since we were comparing the speakers at their best position for these parameters, one could argue that taking much of the room variable out is useful in itself.
Also, Sonnies room simply does not allow conventional placement of another set of speakers because of the rather intense installation of the HT system.
lcaillo is offline
post #132 of 158 Old 09-16-13, 09:58 PM Thread Starter
HTS Hillbilly
HTS Administrator
I'm a redneck!
While I would like to be able to place them 2-3 feet from the wall and give them a go, it would require quite a bit of alterations in the room to make it similar to what most people would have in a two-channel setup. Such as moving the big ML Prodigy's out of the room... and moving the big dual 18" subs out of the room. I did try placing some of the speakers about 4' out from the wall with the listener being about 9' away, but they sounded terrible there. There are also the time constraints... we only have time to do so much.
I believe if readers are looking for that ideal critical music listening setup, they should really try to get their speakers out from the wall while they are listening. If it is just casual listening, then positioning does not really matter. If you are critical listening, chances are you are in a room by yourself and really getting into the music... most likely no one else is around. I guess what I am trying to say is I don't think critical listeners are going to have their wife and a couple kids in the room with them when they are doing serious listening. Therefore, why not get the speakers out from the wall where there is little to effect their sound... and try to get the most out of their sound. I have tried for years to get good sound out of my speakers in my various great rooms with them near a wall and I was never able to get the sound I can get with the speaker out into the room. Of course I realize this may not be feasible with some speakers, if they are big and heavy, but then you probably have a dedicated listening room if you got those kind of speakers.
Cedar Creek Cinema
PremierHomeAudio: Denon, Marantz, Onkyo, Yamaha, Sony, Pioneer, Def Tech and more. Shoot me a PM!
Sonnie is offline
post #133 of 158 Old 09-17-13, 06:01 AM
Plain ole user
lcaillo's Avatar
Tech Guru
That is exactly what I do. My speakers are near the walls, out of the way most of the time and it does not matter until I sit down to just listen. The reality is that the room is shared with other purposes and most listening is very casual. When I do want to just listen, they come way out into the room, but they could not live there all the time.
It takes a lot of time to find the right spot in any room, and they are all different. Once you do, however, there is a balance to the system that you don't otherwise find. All of the speakers we listened to were positioned for their best presentation of the music. I don't think there is a more fair way to do it.
lcaillo is offline
post #134 of 158 Old 09-21-13, 02:17 AM
HTS Moderator
Reviewer
AudiocRaver's Avatar
Wayne Myers
Echoing what Sonnie and Leonard have already said, our process of trying to find ideal speaker location relative to the set listening position did in some cases involve trying locations closer to the movie screen wall, as you suggest. I believe the Tekton Lore's ended up the farthest away from the LP of them all at one point, a desperation move. But none of them ever sounded very good at that distance in Sonnie's room. The "mid-field' distance was what worked best for depth of soundstage. Don't know if that could be considered a rule of thumb or not.
And I echo the idea that for critical listening the speakers should go where they sound their best. That is the way we feel they should be evaluated and reported anyway, realizing that practicalities of all kinds are at play in most listening rooms. We appreciate the suggestion, though.
AudiocRaver is offline
post #135 of 158 Old 09-21-13, 07:31 AM
HTS Moderator
Reviewer
Wayne Myers
Have to correct myself on the previous post. "None of them ever sounded very good at that distance" of course is highly relative. In reality, the more flexible models - ML, Arx, Klipsch, even the Maggies - all sounded very nice anywhere in the room, you almost can not MAKE them sound bad. Just not with the expansive soundstage we knew they were capable of. I can think of no reason any of them would not transfer to a smaller room, except perhaps the completely dipole Maggies, and that is only a guess. Anyone have experience to share on that?
Edit: I am actually very interested in experiences others might have had with Magnepans in a smaller room. I have a family member thinking about under-$1K 2-channel speakers for a smaller listening room and am pushing him to consider Sonnie's Magnepans from the $1K weekend.
post #136 of 158 Old 10-02-13, 03:25 PM
mpednault's Avatar
Read through most of the reviews for the individual speakers and like the "classification" type descriptions you guys have given. All too often we read too much into the measured data and less into the subjective listening experiences with speakers. I am happy to say that I own a pair of the Klipsch RF-62 II's and plan on buying a third to utilize as my center in a matched LCR configuration in my dedicated HT (20% music, 70% movies, 10% games) . I'm also happy to read about the impressions you guys had of them. I'm currently in the building stages of my room and so my speakers haven't been used all that much. I've got them sitting in my office, not connected and covered with a bed sheet just waiting to make their way down to the basement. And congrats to the winner of the giveaway!
mpednault is offline
post #137 of 158 Old 10-02-13, 03:34 PM
Plain ole user
lcaillo's Avatar
Tech Guru
While the priorities in this listening experience were focused on stereo, the fact that the Klipsch performed well regardless of placement makes me think it is a great choice for LCR for HT.
lcaillo is offline
post #138 of 158 Old 10-02-13, 06:17 PM
B- one's Avatar
Brandon
mpednault wrote: View Post
I have to say the RC-64 would be good for you for a center channel, any reason you aren't looking that direction? Just curious because I love mine.
B- one is offline
post #139 of 158 Old 10-08-13, 11:31 AM
mpednault's Avatar
B- one wrote: View Post
Three reasons:
1. Having the room and ability to use the same exact speaker for all three locations is beneficial in voicing, timbre, level matching, etc., etc.
2. Price. The RC64 is well over $800 while I can buy a single RF62 for under $400...
3. I've read that horizontal configured speakers present "issues" and are a compromise in speaker design that was developed due to the need of a speaker to easily fit above or below a TV. I'll be using an AT screen and therefore have the space to use three matching towers as my LCR speakers.
post #140 of 158 Old 10-08-13, 11:38 AM
Bryan
I totally agree with you on this. If you have an acoustically transparent screen and the room to have a tower center channel, that is the ideal way to go. That's how my next setup is going to be too. Having the center channel behind a good AT screen and having an exact match across all three channels will make a substantial difference. Also avoiding an MTM design for the center channel is a good thing.
bkeeler10 is offline
$1 , 000 , audition , evaluation , event , home , official , results , speaker
You may not post new threads
You may not post replies
