Simplified REW SPL Meter Calibration for XLR mic. - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 1 Old 09-16-16, 04:14 PM Thread Starter
Attached is a pdf of a simple method to calibrate the REW SPL meter when using a XLR mic and external audio interface (analog IOs). I think this general thought process can be applied to most any common interfaces used with REW. It only requires a suitable loopback cable.
[This method has not been tested with various interfaces so it is possible that one with a much higher max output level may require using a modified version of this method; one that uses less than full output level?]
The absolute accuracy of the method is not likely to be any better than using an SLM or multi-meter. Instead it provides a quick easy way to get a highly repeatable REW SPL cal level from calibration to calibration using only a simple loopback cable. The input level and thus the resulting headroom can also be easily changed without any impact to the REW SPL meter level.
REW SPL Meter Calibration.xlsx.pdf
jtalden is offline
calibration , meter , mic , rew , simplified , spl , xlr
