Cross-Spectrum Microphone Calibration Service - USA - Page 14 - Home Theater Forum and Systems - HomeTheaterShack.com
post #131 of 366 Old 04-10-11, 10:38 AM
Michael
Re: Cross-Spectrum Microphone Calibration Service - USA
Herb,
given that at 5Hz, the error range is 10db, what is the usable frequency range of EMM-6?
Also, taking humidity, temperature and other environmental factors, what would be the real-life precision of the calibrated EMM-6 across that range? Better than 3db? Better than 1db?
If I put the 'wind shield' on the mic, will it reflect the measurements?
thanks
michael123 is offline
post #132 of 366 Old 04-10-11, 11:08 AM
Tony
Anechoic wrote: View Post
However in room acoustics applications where the mic is picking up sound waves that are bouncing off the walls/ceiling/floor and arriving at the mic in arbitrary directions, the additional frequency response correction curves allow the user greater flexibility in using the mics. For room-correction/room acoustics applications, I typically recommend pointing the microphone straight up at the ceiling (with a slight tilt toward the main speakers) and using the 90-degree correction curve.
Received your 8000 a couple of weeks back and I am having a blast using it. I am using the 90-degree correction curve and pointing the mic up with a slight tilt towards the speaker I am testing. I wonder what kind of inaccuracies in the higher frequencies, if any, are there with the interaction of a hard (low, about 7 feet) surface ceiling. Perhaps I should use the 45-degree curve instead?
-Tony
distox is offline
post #133 of 366 Old 04-10-11, 11:16 AM
Anechoic
michael123 wrote: View Post
Herb,
I'm not sure I understand the question. With a correction curve, the usaable range is 5 Hz to 25 kHz. Without a correction curve, it's probably something like 80 Hz to 6 kHz.
Environmental factors won't make a huge different unless you're using them in extremes (0 degrees F, 120 degrees F in the rain, etc). If you are using the mic in a standard comfortable environment (say 60-80 degrees F, 20-70% humidity), the differences in the mic response are on the order of tenths of decibiels.
The windscreen changes the response by about 0.5 to 1 dB above ~ 12 kHz.
Anechoic is offline
post #134 of 366 Old 04-10-11, 11:18 AM
Anechoic
distox wrote: View Post
-Tony
It's going to depend on how diffuse the sound field is in your room. If there's is a lot of energy coming from the ceiling, you might want to experiment with the 45 or 0 curves, but if the reflections are more random and coming in all directions, stick with the 90.
Experiment, and then figure out what sounds better to your ears.
Anechoic is offline
post #135 of 366 Old 04-10-11, 11:39 AM
pepar's Avatar
pepar
Is the orientation/cal used driven by the measurement being taken, e.g. 0° for the FR of an individual speaker, but 90° for decay/RT?
Jeff
is a neverending story!
pepar is offline
post #136 of 366 Old 04-10-11, 11:44 AM
Tony
How do I know how diffuse my room is or how much energy is coming from the ceiling? I don't want to trust my ears first, I want to know what is correct, then I can tell my ears that it is correct and then choose what sounds good to me.
distox is offline
post #137 of 366 Old 04-10-11, 11:48 AM
Anechoic
pepar wrote: View Post
Jeff
Yes.
Anechoic is offline
post #138 of 366 Old 04-10-11, 11:56 AM
Anechoic
Diffuse means that reflections have an equal probability of coming from any direction and it's a matter of how reflective the surfaces in your room are. If you have an empty four-sided with a floor and ceiling, and all 6 surfaces are acoustically "hard" you can consider that to be a diffuse environment (for the pendants out there, I'm simplifying) where reflections will be bouncing around between the surfaces in all directions. At the other extreme, if the four walls and floor are completely covered in absorptive material (thick carpet, thick curtains, etc) but the ceiling is still acoustically hard, most of the reflections in the room will be coming from the ceiling and the room is not diffuse.
The 0-degree curve should be used when the mic is pointed in the direction of the sound source (or the reflection source if it's known and dominant). As the source of reflections become more spread out, you move toward the off-axis correction curves.
Anechoic is offline
post #139 of 366 Old 04-10-11, 11:58 AM
pepar's Avatar
pepar
You probably mean "pedantics", but then I'd be one if I pointed that out.
pepar is offline
post #140 of 366 Old 04-10-11, 02:09 PM
Anechoic
Touché
Anechoic is offline
calibration , cross-spectrum , microphone , service
