Cross-Spectrum Microphone Calibration Service - USA - Page 18 - Home Theater Forum and Systems - HomeTheaterShack.com
post #171 of 368 Old 04-28-12, 07:37 AM
Jim
Re: Cross-Spectrum Microphone Calibration Service - USA
Anechoic wrote: View Post
There are two issues with calibrating the omnimic microphone:
  1. 2
  2. The version I saw last year only worked with the Omnimic software. I've heard rumors that has changed with recent versions and that now the Omnimic shows up as a USB audio device - if that's true, than I can use it with my rig, otherwise I can't measure it (at least not easilly)
  3. The diameter of the Omnimic mic I played with wasn't a standard diameter (I don't understand why mics manufacturers do this, the industry has standardized on 1/4", 3/8", 1/2", and 1" for decades now), which makes it harder for me to use in my low-frequency jig.
Assuming the mic does show up as a USB audio device, if someone wants to send one to me, I'll check it out.
Tell me where I should measure for the diameter of the mic. If its one of the standardize ones you listed, I'd be interested in sending it in for testing. It is the more recent version of the mic, not the original one.
JimP is offline
post #172 of 368 Old 05-24-12, 11:48 PM
Anechoic
JimP wrote: View Post
At the "business end" of the mic, at the capsule (it's just over 1/4-inch IIRC).
Anechoic is offline
post #173 of 368 Old 05-25-12, 09:23 PM
I must be doing something wrong
Hi Herb,
I am a recent owner of a calibrated Galaxy meter (verified +).
How reliable is calibration at the extremes supposed to be, specifically in the sub-10Hz region?
The reason I am asking is that results I am getting do not look realistic at all.
As you can see in the attached REW measurement snapshot I am getting 30dB jump from 70db at 15Hz to almost 100dB at 5Hz. Is it even theoretically possible?
The calibration file I amusing with REW is called "one_third_octave_band_response_random-incidence_C-wtd.frd". Is this correct file to use?
Here's the content of the file:
5 -30.49 0
6.3 -23.99 0
8 -19.35 0
10 -15.72 0
12.5 -12.62 0
16 -10.03 0
20 -7.9 0
25 -6.16 0
31.5 -4.74 0
40 -3.58 0
50 -2.66 0
63 -2.01 0
80 -1.65 0
100 -1.29 0
125 -1.04 0
160 -0.83 0
200 -0.73 0
250 -0.62 0
315 -0.5600000000000001 0
400 -0.48 0
500 -0.4 0
630 -0.28 0
800 -0.07000000000000001 0
1000 0 0
1250 -0.24 0
1600 -0.38 0
2000 0.44 0
2500 0.38 0
3150 0.36 0
4000 1.54 0
5000 2.55 0
6300 3.05 0
8000 2.2 0
10000 -0.19 0
12500 -5.07 0
16000 -10 0
20000 -15.2 0
25000 -19.97 0
I am not sure what it is that I am doing wrong. Any guidance you can offer is much appreciated.
Cross-Spectrum Microphone Calibration Service - USA-problems-measurements.jpg
zheka is offline
post #174 of 368 Old 05-25-12, 09:40 PM
Anechoic
Re: I must be doing something wrong
zheka wrote: View Post
Hi Herb,
[snip]
I'm not an REW expert, but I would recommend trying the "narrow_band_response_random-incidence_C-wtd.frd" instead of the one-third octave band file. Also, do you have the meter set to C-weighting when you make the measurement? The data you quoted looks plausible - the Type 1 C-weighting value at 5 Hz is -25 dB, at 8 Hz -17.7 dB, at 10 Hz -14.3 dB, at 12.5 Hz -11.3 so it's certainly in the right ballpark.
What is the serial number of your meter?
Anechoic is offline
post #175 of 368 Old 05-25-12, 09:58 PM
SN 110508226
I am using C weighting and response slow.
I will try the narrow band cal file and report back.
Thank you very much!
zheka is offline
post #176 of 368 Old 05-25-12, 10:30 PM
results using both cal files look very close to me.
Cross-Spectrum Microphone Calibration Service - USA-one-thir-octave-5-50.jpg
zheka is offline
post #177 of 368 Old 05-26-12, 12:10 AM
Anechoic
The cal files for your meter look kosher. Try checking in the REW forum to make sure there isn't something wrong with the software settings. If that's not it, maybe your meter went bad - if the REW forum folks can't clear it up, you can ship the meter back to me and I can take another look.
(also, did you take advantage of the HTS discount for your meter?)
Anechoic is offline
post #178 of 368 Old 05-26-12, 12:40 AM
sounds good, thank you very much.
no, I did not
zheka is offline
post #179 of 368 Old 05-26-12, 02:01 AM
Anechoic
no, I did not
Check your PMs.
Anechoic is offline
post #180 of 368 Old 05-26-12, 07:20 AM
Check your PMs.
Thank you!
zheka is offline
calibration , cross-spectrum , microphone , service
