Cross-Spectrum Microphone Calibration Service - USA - Page 20 - Home Theater Forum and Systems - HomeTheaterShack.com
post #191 of 366 Old 07-09-12, 06:18 PM
New Member
Re: Cross-Spectrum Microphone Calibration Service - USA
I would like to upgrade my current RS mic and built in PC audio for a USB external with a Calibrated EMM-6 from Herb.
I am using an IB for sub and would like to be capable of messuring down to 5hz hopefully. Does someone have a recomendation for an external (USB) sound device with a midi interface if at all possible which can handle down that low? OS is Windows 7 or Linux.
Thank you....
Ngtybear is offline
post #192 of 366 Old 07-10-12, 11:54 AM
John
Ngtybear wrote: View Post
Tascam US-122/144mkII are popular, have MIDI, and quite flat--look to be down about 3dB at 5 Hz. I may finally buy one as there is a $10 rebate at most music retailers at the moment (and I'm employed which I was not when I started using REW, LOL). You can find the calibration curve for this interface right here.
aackthpt is offline
post #193 of 366 Old 08-29-12, 01:42 AM
JimP wrote: View Post
Is it possible to get the omnimic run through your calibration process and provide a correction file????
Hi Jimp did you get the Omnimic re-calibrated?
Which version do you own?
Phillips is offline
post #194 of 366 Old 08-29-12, 10:23 AM
Jim
No, I didn't.
Got sidetracked with changing out my display and calibrating video.
Not sure If I'll get the Omnimic recalibrated as I was only planning to use it on REW. I can use it on the omnimic software and import the settings which gets me there...I think.
JimP is offline
post #195 of 366 Old 08-29-12, 03:50 PM
No, I didn't.
Thanks Jimp
Did you have any feedback (after) from Cross-Spectrum about being able to calibrate your mic?
Which version Mic do you have?
Phillips is offline
post #196 of 366 Old 08-30-12, 02:30 AM
Hey, great forum. Thanks for sharing. Now for my first post: I am curious if someone could speak to the sensitivity of the Dayton microphone, I am hoping to do some very low-noise measurements and wanted to see if there was a suitable mic that wouldn't break the bank. I was hoping to get in to the 20 dBSPL range, but not sure if that is realistic. Anyone care to comment?
Also, I was looking at using the Motu 4Pre as my Mic -> USB solution. Any users care to comment?
Really like fooling around with REW; thanks for that! I hope to learn more in the coming months.
Thanks!
EDIT: can REW do simultaneous multi-mic RTA? The Motu 4pre has 4 mic inputs...would be nice.
roognation is offline
post #197 of 366 Old 08-30-12, 03:16 AM
Anechoic
roognation wrote: View Post
Yeah, you're not going to get a 20 dB noise floor without spending some serious coin. The noise floor on Dayton mics range from 30 to 35 dBA (note the "A") and maybe 40-45 dB. Behringer mics range from around 35 to 40 dBA, perhaps 45-50 dB linear.
To put this in perspective, my quietest ANSI/IEC class 1 mics (1/2-inch BSWA MP201 & PCB 308B02) have noise floors around 15 dBA, 20 dB linear. To get much lower than that on a measurement mic, expect to pay well over $1,000 for a 1-inch B&K/Gras/etc capsule + pre-amp and power supply.
Anechoic is offline
post #198 of 366 Old 08-30-12, 06:49 AM
Hi
Has anyone had their Omnimic re-calibrated, is it possible?
Phillips is offline
post #199 of 366 Old 08-30-12, 09:30 AM
John
I asked similar questions in this thread and didn't get any great answers. However I've just done a bit more searching and perhaps can be a bit more specific than anechoic was above.
Earthworks (least expensive model M23 ~$450) is spec'd at 22 dBA self noise.
DPA 4006A is spec'd at 15dBA typical 17 dBA max (though they also list 27-29 dB per ITU-R .468-4, I'm not sure what that means at the moment)-this is a $1925 mic. (!)
B&K 4955 is spec'd at <6.5dBA self-noise, but their (and, it appears, THE) ultimate setup is 4179+2660pre, the 2179 is spec'd for -5.5dBA. But this stuff isn't available at retail so is probably "If you have to ask, you can't afford it" sort of pricing.
The GRAS that anechoic mentioned is here. I haven't looked at it in any detail.
ACO stuff looks to be here and here, I again haven't reviewed it or looked for pricing (would be glad to see it if you look into it).
Looks like you can get the "SoundFirst SF101a" from http://www.testmic.com/ at 13dBA for $890, they say the SF111a should be ~10dBA for $1415. Also interesting what that site says of their Josephson mic: "This is the mic that many manufacturers copied the body from, but not the performance." It does indeed look much like the Behringer and Dayton mics most of us 'round here use.
I also found LinearX M53 for $350 at 18 dBA.
There's also some stuff from Scantek that I haven't looked at much.
So predictably the costs appear to be pretty well exponentially increasing the lower the desired noise floor beyond an "average" level.
There was also some discussion of preamp noise levels there, however it looks to me that they are all rated in dBFS so as long as you don't have a lot of dynamic range in the measurement I'm guessing reducing the input gain will mitigate that problem.
aackthpt is offline
post #200 of 366 Old 08-30-12, 11:22 AM
Anechoic
aackthpt wrote: View Post
ITU-R .468 is another frequency weighting curve, similar to A-weighting.
Yep. My old firm has that setup, it's used for measuring noise levels at very remote locations where there are no man-made noise sources for dozens of miles. I don't remember the pricing, but I'm guessing it's at least in the $2,500 range. It was only used for very special occasions .
I have the ACO Pacific price list, current as of last winter, if someone has a specific question, let me know. I own the 7052, the noise floor for my capsule is in the low 20's, which is typical for a Type 2 mic.
There's also the used-equipment inventory at Modal Shop.
That's a really good price if that spec actually holds up.
That's where I got my BSWA MP201 from, the 1/2 inch Class 1 mics will all have noise floors in the 15-17 dBA range. They also off Class 0 mics that probably have lower noise floors (probably not lower than around 8 dBA though), but you don't want to know that pricing.
With regard to IEC/ANSI-rated equipment, the mic usually determines the noise floor moreso than the pre-amp unless the mic floor is really quiet (~5 dBA or lower).
Also remember that the noise floor of the mic will have to be at least 8 to 10 dB lower than the noise level to be measured, so to measure noise levels at 20 dBA, the mic will need a noise floor of 8 to 10 dBA.
Anechoic is offline
calibration , cross-spectrum , microphone , service
