Cross-Spectrum Microphone Calibration Service - USA - Page 28 - Home Theater Forum and Systems - HomeTheaterShack.com
post #271 of 366 Old 05-09-13, 04:57 PM
Re: Cross-Spectrum Microphone Calibration Service - USA
Anechoic wrote: View Post
To be fair, the quality of Dayton EMM-6 mics has also fallen, but not nearly as much as the Behringer mic. The quality of the EMM-6 also started at a higher point.
When did these start to fall off?
Where are the problems with these, the same as Behringer?
Phillips is offline
post #272 of 366 Old 05-09-13, 05:03 PM
Anechoic
There's an earlier thread called something like "state of microphones" (I'm too lazy to look it up right now) where I talk about it. There have been little dips in quality after the EMM-6 was first introduced (I saw zero bad ones in my first couple of hundred, that increased to maybe 1-2 out of every hundred for the next few batches), but in the last year to 18 months it's increased enough to make me pay attention (maybe 5-10 out of every hundred) but still nowhere near as bad as ECM8000's are now.
The problems are basically hum/buzzing, or mysteriously going DOA after a few days of use. I haven't seen the severe LF rolloff that I've observed with the ECM8000.
Anechoic is offline
post #273 of 366 Old 05-10-13, 04:04 AM
The thread was started by you?
You check for these before release?
Have these mics ever been returned back to you because of these issues?
Phillips is offline
post #274 of 366 Old 05-10-13, 10:27 AM
Anechoic
Phillips wrote: View Post
This is the thread.
Buzzing/hums show up in the data when the mics are calibrated, I don't specifically check for them. Mics going dead usually happens after customers have received them.
Yep.
Anechoic is offline
post #275 of 366 Old 05-10-13, 08:40 PM
This is the thread.
Yep.
Thanks for the thread link, had a read. Looked for it briefly last night but couldn't find it. Probably on next page
Many come back in the last 9-10 months?
Phillips is offline
post #276 of 366 Old 05-10-13, 09:06 PM
Anechoic
Around 5 or so.
Anechoic is offline
post #277 of 366 Old 05-21-13, 11:57 PM
Which is the best mic overall between the UMM-6 and UMIK or other USB mic?
Phillips is offline
post #278 of 366 Old 05-22-13, 12:52 AM
Anechoic
I would give the nod to the UMIK-1 over the UMM-6 for two reasons: 1) slightly better low frequency response, and 2) not as fragile (I'm seeing a lot of complaints about UMM-6's either arriving with the barrel broken off, or the barrel breaking off at the slightest bit of stress, such as being dropped on a carpet).
Is there another USB mic out there (other than the OmniMic)?
Anechoic is offline
post #279 of 366 Old 05-22-13, 05:37 AM
True the Omnimic, have you had any dealings with them?
Calibrated Mic (XLR) by you and Pre / Soundcard vs USB mic
Which is the best out of the two, other than USB being convenient?
Phillips is offline
post #280 of 366 Old 05-22-13, 12:27 PM
New Member
See couple pages back:
If money isn't an issue, I'd recommend going with a soundcard + EMM-6 over the UMM-6.
Kisakuku is offline
calibration , cross-spectrum , microphone , service
