MiniDSP UMIK-1 Microphone - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #31 of 887 Old 12-12-12, 05:11 PM
Re: MiniDSP UMIK-1 Microphone
wow awesome results Fuzz, thanks for posting that
Patzig is offline
post #32 of 887 Old 12-12-12, 05:12 PM
REW Author
JohnM's Avatar
John
EarlK wrote: View Post
- Will there ever be a way ( & are you able to create a soft-patch within future releases of REW ) to use these new USB based microphones in conjunction with, REW's option to "Use loopback as a timing reference" ?
It might be possible to use ASIO4All to make a composite ASIO device that uses another soundcard path for the loopback return, but I haven't had a chance to try that yet.
JohnM is offline
post #33 of 887 Old 12-13-12, 02:46 AM
Steve
AudiocRaver wrote: View Post
Longer sample length gives better signal-to-noise ratio, better immunity from the effects of minor background noise. Using the multiple sweep option is another way to get the same effect.
Edit: I have no explanation for the weird frequency response with the 256K sample length, that is a head scratcher. Have you gotten the same result more then once that way?
Yep. With the Mac Mini over several sessions and my Macbook Air.
Going to longer samples makes it even worse as the roll- off starts at 2k.
I hope it is a REW/Umik thing that can be fixed in an update (since Fuzzmeasure is fine) but now I've worked it out at least I can work around it by doing multiple sweeps.
sfdoddsy is offline
post #34 of 887 Old 12-13-12, 06:03 AM
Steve
Patzig wrote: View Post
Indeed. In spite of the issues I've mentioned, the performance of the mic seems great.
My ECM8000 is not individually calibrated, and the generic REW cal file actually makes the response worse. The Umik out of the box does not have its deficiencies and tracks my calibrated ARC mic well.
Once you add the cal file it feels even more trustworthy.
My only other beef is the short USB cable. 2m is nowhere near enough.
sfdoddsy is offline
post #35 of 887 Old 12-13-12, 06:19 AM
Steve
In spite of the issues I've mentioned, the performance of the mic seems good.
It is extraordinarily close to my ECM8000, with a somewhat more accurate top end.
sfdoddsy is offline
post #36 of 887 Old 12-13-12, 02:26 PM
fuzz092888 wrote: View Post
UMIK on top calibrated behringer on the bottom.
EMP-E-41B/Crown XLS2500/macbook pro soundcard
Interesting difference
Phillips is offline
post #37 of 887 Old 12-13-12, 02:59 PM
Alex
UMIK on the top Behringer on the bottom, this time in the sub frequencies. Outlaw LFM-1 EX. I also had the sub connected to an anti-mode dual core. I'm still getting the hang of the anti-mode, but you get the idea. Pretty similar.
1m
1in
LP
Philharmonic 3, Custom Center (Jordan Watts Module), Source Technology RC4/8.3, EMP E41B, Jeff Bagby Mandolin, CSS SDX10 Custom Sub (Baby Boomer), Custom LMS Ultra Dual Opposed, Custom 18" Pierce Audio Sub
fuzz092888 is offline
post #38 of 887 Old 12-13-12, 03:51 PM
What would be the difference between USB mics, i use the Omnimic?
Phillips is offline
post #39 of 887 Old 12-13-12, 04:09 PM
Alex
Phillips wrote: View Post
A few db, a few Hz, nothing too significant. I know I read somewhere the UMIK-1 has more information in the cal file, but don't quote me on that.
post #40 of 887 Old 12-13-12, 04:12 PM
Alex
As a quick update, I contacted miniDSP about getting a new box and they told me it would be easier to just send me a new mic, but that I'd have to return the one I have. I asked them a question about the return process and they haven't responded since. It's been about about a day since I sent the e-mail, hopefully they get back to me soon so we can get this over with.
microphone , minidsp , umik1
