MiniDSP UMIK-1 Microphone - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #41 of 887 Old 12-13-12, 04:47 PM
Re: MiniDSP UMIK-1 Microphone
fuzz092888 wrote: View Post
A few db, a few Hz, nothing too significant. I know I read somewhere the UMIK-1 has more information in the cal file, but don't quote me on that.
Thanks for that
The other USB mics dont have any advantages over the UMIK other than few db, few Hz?
Something about ADC, what is this?
Phillips is offline
post #42 of 887 Old 12-13-12, 05:07 PM
Alex
Phillips wrote: View Post
Thanks for that
Actually it's the UMIK that has that advantage over the Dayton. It basically means that it has a built in "sound card" which encodes the audio file at 24 bits and either 44.1 or 48kHz
Philharmonic 3, Custom Center (Jordan Watts Module), Source Technology RC4/8.3, EMP E41B, Jeff Bagby Mandolin, CSS SDX10 Custom Sub (Baby Boomer), Custom LMS Ultra Dual Opposed, Custom 18" Pierce Audio Sub
fuzz092888 is offline
post #43 of 887 Old 12-13-12, 05:18 PM
So you don't use the laptops soundcard at all?
Currently i use the Omnimic with my laptop soundcard which has produced very good results, once the soundcard was produced.
I wonder if there will be any advantages with the new REW update for the Omnimic?
Currently i can only use single sweep, and have no loopback, which i beleive John is looking at.
One thing i like is the portability of the USB mic, which is obvious.
Phillips is offline
post #44 of 887 Old 12-13-12, 05:24 PM
Alex
You don't use the laptop or computer soundcard for input at all, it is all handled by the UMIK. For output you still use whatever soundcard you have.
post #45 of 887 Old 12-13-12, 05:38 PM
Sorry my opologies
So the same as the Omnimic.
Phillips is offline
post #46 of 887 Old 12-13-12, 06:35 PM
Hi all.
Recently received the Umik1 and I am having some problems with my setup in Rew. I have loaded the Mic's Cal file into the REW system and it is recognised
This is what I have.
PC running SOtM PCIe USB3 into USB into Audiophilleo2 into NAD digital Amp. The driver for the SOtM is it's own design. I use JRiver V16 and it runs in Inclusive use with the AP2.
When I go to REW preferences to set up have the following..
Soundcard -
I can select 44.1 - output is Audiophilleo2 - input is Mic Umik1
Using - Main speaker to check levels
Calibration file is - Umik 1
Mic/Metre
C-Weighted ticked (no Z weight available on screen)
Cal file is selected as - Umik1.cal
Analysis - loop back 'Un-ticked"
I can get audio out through my speakers but I get no input reading on either left or right meters
I have nothing to adjust the levels with via the Audiophilleo2.
My soundcard is a realtek but it is bypassed in this config.
Any suggestions?
Regards Cazzesman
cazzesman is offline
post #47 of 887 Old 12-13-12, 11:00 PM
HTS Moderator
Reviewer
AudiocRaver's Avatar
Wayne Myers
cazzesman wrote: View Post
Hi all.
Soundcard -
Mic/Metre
Any suggestions?
Regards Cazzesman
This might not be it at all, if you are using a USB3 interface for the UMIK-1, I have heard elsewhere that some audio devices do not play well with USB3. You would think that with backward compatibility there should be no issues, but others have had trouble running USB2 devices into USB3. Do you have a USB2 that you can try it with? As I said, not a guaranteed fix, just something to try. That is all that comes to mind for me.
Best of luck.
AudiocRaver is offline
post #48 of 887 Old 12-14-12, 10:10 AM
blitzer's Avatar
Brent L
Send a message via Yahoo to blitzer
I just got mine a couple days ago - everything arrived just fine. As previously stated, the sensitivity of this mic is really low. I am currently experimenting with the MiniDSP 2X4 and this Mic. The integration with REW is good. Sooooo much simpler than the typical setup.
blitzer is offline
post #49 of 887 Old 12-14-12, 01:36 PM
REW Author
JohnM's Avatar
John
To control the input volume for the UMIK you will need to use the Windows volume control. You should also untick C weighting, that is only for use with a C-weighted SPL meter.
JohnM is offline
post #50 of 887 Old 12-14-12, 02:21 PM Thread Starter
HTS Hillbilly
HTS Administrator
I'm a redneck!
I received the one I ordered today... 5 days from Hong Kong to Alabama... not bad. All is is good condition here.
Sonnie is offline
microphone , minidsp , umik1
