MiniDSP UMIK-1 Microphone - Page 60 - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #591 of 887 Old 05-19-13, 10:34 PM
Anechoic
Re: MiniDSP UMIK-1 Microphone
Phillips wrote: View Post
I don't for my other mic.
I would email or post Herb, depends if he used it when he calibrated it. I would doubt that he would off.
I don't use the windscreen when making the measurements. It basically makes a roughly 0.5 to 1 dB difference above 15 kHz or so:
Anechoic is offline
post #592 of 887 Old 05-20-13, 11:30 PM
Anechoic wrote: View Post
Thank you for the info, good to know that.
Herb, thanks for the mic and your cal. service!
redsandvb is offline
post #593 of 887 Old 05-21-13, 10:54 PM
The purpose of windscreen, other than protection?
Phillips is offline
post #594 of 887 Old 05-21-13, 11:54 PM
Anechoic
Ostensibly to reduce turbulence-induced noise if the mic is used in windy conditions. However, it's so small I doubt it would offer any real protection (although I haven't tested it).
Anechoic is offline
post #595 of 887 Old 05-23-13, 01:09 PM
monomer
I kinda thought it was also to reduce breathing noises from humans that are speaking/singing directly into the mic... which is also turbulence related.
monomer is offline
post #596 of 887 Old 05-23-13, 07:16 PM
Anechoic
monomer wrote: View Post
For vocal mics (which the UMM-6/UMIK-1/EMM-6/ECM8000 are definitely not) true, although again, the one that comes with these low-cost measurement mics are so small I doubt they would provide any benefit.
Anechoic is offline
post #597 of 887 Old 05-24-13, 03:01 PM
Mightywetfoot's Avatar
Matt
I am really disappointed I ordered mine from miniDSP and not CSL ( was before they sold them). After my order was placed I contacted CSL and found out they were going to provide calibrated UMIK-1, what a bummer. It's not cost effective to send mine in for a calibration at $55.
Mightywetfoot is offline
post #598 of 887 Old 05-24-13, 04:32 PM
Wayne Myers
Protection is the only reason. The mic is certainly calibrated without windscreen in place. With a calibration mic, breath noise is not an issue, and wind noise is not an issue unless making speaker measurements outside to escape room effects.
I would leave it on, though, for a little extra protection from dust and gunk, and from me accidentally bumping or dropping it on a klutzy day. The minor rolloff above 10 KHz is annoying but of little actual consequence. My 2 cents worth.
AudiocRaver is offline
post #599 of 887 Old 05-24-13, 06:56 PM
AudiocRaver wrote: View Post
Agree
Probably a good idea would be to take measurements with on and off and see the difference with your individual mic and keep that in mind for future measurements.
Depending on measurement frequency targets e.g. 15 - 500hz use the windscreen vs 500 - 20.000hz remove the windscreen.
Phillips is offline
post #600 of 887 Old 05-24-13, 07:02 PM
Mightywetfoot wrote: View Post
Depends what batch you have.
Maybe you can send back to MiniDSP if the deal hasn't expired?
If it has i would email them and explain you were not aware of the problem until now etc, plead your case carefully.
Worth a go.
Phillips is offline
microphone , minidsp , umik1
