MiniDSP UMIK-1 Microphone - Page 68 - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #671 of 887 Old 07-06-13, 05:19 PM
Dwight Angus's Avatar
Dwight
Re: MiniDSP UMIK-1 Microphone
pdxrealtor wrote: View Post
And did you include your mics serial number in that sens factor line?
Yes I loaded the SN into the Sens factor line.
Mains- Goldenear Triton One's
Center Channel- Goldenear Super Centre XL
Surrounds- Goldenear SuperSat 50's
Back Surrounds- Goldenear SuperSat 50c's
Atmos -Goldenear HTR 7000's
Amps- Bryston 4Bsst2/Emotiva XPA-5/Marantz M7025
Processor-Marantz AV7703 Preamp
Projector- Sony VPL-HW55ES
Screen- Elunevision 140 inch 4K Audio Weave
Bluray/Universal player-OPPO 105D
Dwight Angus is offline
post #672 of 887 Old 07-06-13, 06:41 PM
pdxrealtor's Avatar
Matt
Dwight Angus wrote: View Post
I only included the sensitivity data in the one file "zero band response zero degrees" as thats the file I was using for room measurement using REW and I am pointing the mic directly at the speakers being measured. If you are using all six files then load the sensitivity data into all 6 files.
Got it. One last question, I'm a bit nervous because I don't want to mess up a cal file.
Did you use a text editor like word pad to add the file?
pdxrealtor is offline
post #673 of 887 Old 07-06-13, 09:55 PM
swingin's Avatar
Don
Pass me a paddle buddy cause I'm in the same boat with you I have the file, I just dont know how to add it, Thanks..
I did it, when you hit, file save as, then hit the drop down box and save it as a text file, that worked for me. REW said something when I tried to load it but it still loaded. Good luck... I could not get this file and the 0 degrees file to load at the same time though..
Save it to your desktop, then open REW and you can load it..
So far,
this is the oldest
i've ever been.
swingin is offline
post #674 of 887 Old 07-06-13, 10:08 PM
pdxrealtor's Avatar
Matt
HA! Glad I'm not alone. Someone will come along and set us straight!
post #675 of 887 Old 07-06-13, 10:39 PM
swingin's Avatar
Don
So far,
this is the oldest
i've ever been.
swingin is offline
post #676 of 887 Old 07-06-13, 11:53 PM
REW will accept FRD, TXT files. You can just load the file that Cross Spectrum produce.
Best thing to do is make a copy/s then there if a mistake is made you have spares quickly.
From the original (MiniDSP) UMIK file, copy the first line (SN + Sens Factor)
Insert a row in the Cross Spectrum UMIK file then paste
File > Save
Done
Phillips is offline
post #677 of 887 Old 07-06-13, 11:57 PM
pdxrealtor's Avatar
Matt
Phillips wrote: View Post
From the original UMIK file, copy the first line (SN + Sens Factor)
File > Save
Done
Thank you sir! While it seems I have set my windows machine to open the cal files with word pad it seems they are still labeled as .FRD files.
Sounds like either way it will not be an issue. Again, thanks guys. I will post results, but it may be a bit.
post #678 of 887 Old 07-07-13, 10:44 AM
Anechoic
Even if you somehow mess up the original file, I have copies of the cal files I produce, so just email the mic serial number and I can send you the original cal files.
Anechoic is offline
post #679 of 887 Old 07-07-13, 10:46 AM
swingin's Avatar
Don
File > Save
Done
Maybe I didn't get it right, Sorry. Phillips, or anybody for that matter, could you post some screen shots of the process when you have the time. It's not letting me save anything when trying to copy & paste from the "Sens Factor =-5.929dB, SERNO: 7000896". This is the folder I saved to my desktop with original cal files.
10.054 -6.214461668
10.179 -6.041088351
10.306 -5.870899851
10.434 -5.703954414
10.564 -5.54013152
These are the first few lines of the files they have for my mic, above. Sorry I'm so computer illiterate.
So far,
this is the oldest
i've ever been.
swingin is offline
post #680 of 887 Old 07-07-13, 10:54 AM
Anechoic
I keep getting different floor levels when plugging min my mic, without changing the level input in Windows. Sometimes it will be ~40, others 9, and others in the 15s. Is there something wrong with my mic that the floor level keeps changing?
Unless the floor level is ~40 I can't calibrate the SPL meter in REW without having to set the volume so high that REW tells me I'm clipping. Lately I've just been skipping the calibration and setting the AVR at -10 and input level at 25 to keep the DB level consistent in my subwoofer FR testing. However I would like to have an accurate SPL reading that is identical every time (for identical graphs, etc), via the SPL calibration tool.
Sorry for not responding to your email about this (it's been a rough couple of days, we had to put out dog to sleep on Friday and things have gone downhill since). I haven't looked into noise floor issues that closely with the UMIK-1 but on first glance that does sound a bit unusual, although perhaps others can speak to their experience. The first question I would ask: is there something on your USB bus or something running in the background of your machine (anti-virus, etc) that correlates with the noise floor irregularities?
Anechoic is offline
microphone , minidsp , umik1
