MiniDSP UMIK-1 Microphone - Page 69 - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #681 of 887 Old 07-07-13, 05:33 PM
pdxrealtor's Avatar
Matt
Re: MiniDSP UMIK-1 Microphone
Anechoic wrote: View Post
Sorry for not responding to your email about this (it's been a rough couple of days, we had to put out dog to sleep on Friday and things have gone downhill since). I haven't looked into noise floor issues that closely with the UMIK-1 but on first glance that does sound a bit unusual, although perhaps others can speak to their experience. The first question I would ask: is there something on your USB bus or something running in the background of your machine (anti-virus, etc) that correlates with the noise floor irregularities?
Sorry to hear about your dog.. we have two we call our kids, so I understand how hard that must be.
My USB bus consists of the UMIK-1, a logitech wireless mouse adapter, and the USB stick that came with the MIC. I have no antivirus running, except for the software that come with Windows 8.
I even make sure the HVAC is turned off as it does add a few DB.
The only difference is two of my USP ports are 3.0 and one is 2.0. I used to think I had to use the 2.0, but it turns out the 3.0 is working just fine, and I've seen the different floor levels on the 3.0 as well.
I thought maybe it had to do with that sensitivity file, but it's not sounding that way.
Swingin- I will let you know when I get my sens. data over to my cal file. I dont want to change it right now because I have very consistent results just setting my AVR at 10 and my mic level at 25. I'm in the middle of getting my subs FR as flat as possible so until that is done I don't want to change anything that might affect the tons of graphs I've done and plan to do shortly.
pdxrealtor is offline
post #682 of 887 Old 07-07-13, 05:39 PM
swingin wrote: View Post
Maybe I didn't get it right, Sorry. Phillips, or anybody for that matter, could you post some screen shots of the process when you have the time. It's not letting me save anything when trying to copy & paste from the "Sens Factor =-5.929dB, SERNO: 7000896". This is the folder I saved to my desktop with original cal files.
10.054 -6.214461668
10.179 -6.041088351
10.306 -5.870899851
10.434 -5.703954414
10.564 -5.54013152
These are the first few lines of the files they have for my mic, above. Sorry I'm so computer illiterate.
How was your birthday?
Attach the MiniDSP UMIK file + Herbs files and i will do it for you, then we can look at what is happening at your end.
Phillips is offline
post #683 of 887 Old 07-07-13, 06:39 PM
pdxrealtor's Avatar
Matt
FWIW- if you right click on a cal file and select 'open with' from the drop down menu, then select the word pad program you will get a list of cal numbers.
Simply copy and paste your sens data from the minidsp site, and paste to the very top line. Then save.
I just did it on a spare copy of cal files to make sure it works and it does, just fine. If you need anymore help let me know where you're stuck at.
post #684 of 887 Old 07-08-13, 03:01 PM
swingin's Avatar
Don
pdxrealtor wrote: View Post
I completely understand that, glad you got it figured out, thank you my man!!
So far,
this is the oldest
i've ever been.
swingin is offline
post #685 of 887 Old 07-08-13, 03:15 PM
swingin's Avatar
Don
Well this is what I have so far, I try and put up a screen shot but it's in an .rtf format and I cant change it. This is a copy and paste of what I've done. I only added the first few rows, did I do it right? Or do I need to remove some of that first line? If it's right I'll go ahead and do all of the files. This one is the narrow band 0 degree file. Thanks you guys, I really appreciate your help...
4.33 -5.02 0
5.79 -2.96 0
7.24 -2.66 0
8.69 -1.6 0
10.14 -1.15 0
11.58 -0.53 0
13.04 -0.19 0
14.48 0.09 0
So far,
this is the oldest
i've ever been.
swingin is offline
post #686 of 887 Old 07-08-13, 03:30 PM
swingin's Avatar
Don
Phillips wrote: View Post
Thank you Phillips, I did not have a good Bday, lol, but the next day made up for it
Well hopefully I have it right this time If I dont, I will send you both files. Thanks for being patient with me, I know you've already had enough of my ignorance.
I'm still trying to figure out why they dont add this to the cal files in the first place??? and is it a necessary thing to do?? Again, thanks to you that are trying to walk me through this...
So far,
this is the oldest
i've ever been.
swingin is offline
post #687 of 887 Old 07-08-13, 05:49 PM
4.33 -5.02 0
5.79 -2.96 0
7.24 -2.66 0
8.69 -1.6 0
10.14 -1.15 0
11.58 -0.53 0
13.04 -0.19 0
14.48 0.09 0
Looks fine the top line should be the same as whats in the MiniDSP manufacturer original file if you want to check it, below that should be untouched.
Phillips is offline
post #688 of 887 Old 07-08-13, 06:00 PM
Thats no good, but came right thats great.
Looks fine, no worries. You can send the files if you want just for peace of mind if you want to?
Its all good glad to help if i can.
Herb doesn't measure for this so he won't put it on there as he can't clarify if it is accurate for his high standards.
But MiniDSP figures will be accurate enough so this can be added manually by the end user if they want to.
This is for Accurate SPL, so you can use it as a SPL meter as well.
Hope this clears things up.
Last edited by Phillips; 07-08-13 at 06:06 PM. Reason: Sorry this post has doubled up
Phillips is offline
post #689 of 887 Old 07-08-13, 06:02 PM
Phillips is offline
post #690 of 887 Old 07-08-13, 06:22 PM
swingin's Avatar
Don
That is the exact way that I got it, so I did good? SWEET! Finally, lol.. I understand about Herb now, didn't know that part of the story. Thank you so much, Id send you the files, but I'm not sure how to go about that either, go figure.. I have both files saved to my desktop in a folder, one opens with wordpad, the other is, well you know.. Thanks again, both of you guys!!!
I tried to send you a PM but It's in the wrong format so it wont let me load it..
So far,
this is the oldest
i've ever been.
swingin is offline
microphone , minidsp , umik1
