MiniDSP UMIK-1 Microphone - Page 78 - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #771 of 887 Old 03-05-14, 10:49 PM
toniok
Re: MiniDSP UMIK-1 Microphone
Got it, thanks!
toniok is offline
post #772 of 887 Old 03-06-14, 07:52 AM
GCG
GCG's Avatar
Patrick
sandworms wrote: View Post
I went to the Minidsp forum and found I wasn't the only one with this issue, seems you have to push really hard on the usb cable where it enters the mic until it clicks. So now my rew is seeing the mic, but when I do the next step in set up (per the umik1 set up guide w/hdmi) for the output dropdown, I don't have 8 channels to choose from, only 2, and when I hit the generate tab I get no sound through my onkyo 1010 with the hdmi hooked to it's front panel
Things to try:
  1. Check the ASIO control panel. Make sure the HDMI output is selected and the normal audio device output is not.
  2. Recheck the sound properties in Windows and make sure the HDMI is setup for 7.1 output.
  3. If that is not an available option you may need to enable multi-channel capability in the BIOS.
Let us know how you do either way.
7.1 System
Center - Infinity Video 1
Surrounds -
(in ceiling)
Rears -
(in ceiling)
Content source - WDTV Live Hub Media Server
GCG is offline
post #773 of 887 Old 03-06-14, 07:58 AM
Jeff Grucella
I have the same problem -no 8 channels to choose from and no sound out of my HT speakers but I do get sound out of the laptop speakers instead , did you ever figure out what the problem was?
flamingeye is offline
post #774 of 887 Old 03-08-14, 04:45 PM
Jeff Grucella
^I'm still having this problem didn't anyone ever figure it out on what there problem was ? I sure would like to use REW +UMIK-1 + HDMI on my room
post #775 of 887 Old 03-08-14, 05:51 PM
flamingeye wrote: View Post
Why not post ( about your challenges ) in a more appropriate thread ? That would be the one called Using the UMIK-1 & REW with HDMI output
Some Important Points :
(i) HDMI ( multi-chnl ) output only works when REW is using ASIO mode ( & this is a Windows only option, btw ) .
(ii) One typically needs to have ASIO4ALL loaded onto ones computer ( & it must be setup properly ) to get signals into the HDMI outputs .
(iii) ASIO4ALL must be chosen as the ASIO driver ( from within REW's preferences window ) .
This ( & other important info ) is covered at the miniDSP link that is mentioned in Sonnie's sticky .
EarlK is offline
post #776 of 887 Old 03-08-14, 07:28 PM
sandworms's Avatar
todd
I did check all my settings, I even removed asio and reloaded it, booted, reloaded REW. I actually took 2 steps back. Now it doesn't see the mic ( umik ) nor does it acknowledge 8 channels. This is very frustrating, I get the emails from htshack touting their new relationship with minidsp and I figure they finally have the bugs worked out from a year ago when I first saw the umik1 thread. Apparently not
sandworms is offline
post #777 of 887 Old 03-08-14, 07:34 PM
Jeff Grucella
sorry I saw it being discussed here so thought this was a good place , I have gone through that link and all you have suggested and like sandworms I'm having the same problem has him, but I will start over over at the proper place the thread that you so kindly provided for me, thanks'
post #778 of 887 Old 03-08-14, 07:37 PM
I am having the same problem. This is a shitty system that does not work. wth
kutlow is offline
post #779 of 887 Old 03-08-14, 09:43 PM
If REW and ASIO4ALL are configured properly, Does this help...?
If you're on WIN7 open the Control Panel-->Sound.
In Playback tab, if your computers Speakers are listed above your AVR try right-clicking them (computer's Speakers and/or any other entries listed above your revceiver) and clicking Disable.
Tip-also click Show Disabled Devices so they don't disappear.
redsandvb is offline
post #780 of 887 Old 03-12-14, 09:13 AM
Blueleader's Avatar
Beat Down and Broken
Just ordered a UMIK from CSL. This is gonna be fun.
REW...REW...REW your Sound Boat, gently down the Audio Stream
Blueleader is offline
microphone , minidsp , umik1
